I would get a 15 to 17 inch rim from a junk yard. Cheap, steel, plain. Then, get a stub axle and hub from Tractor Supply or the like with at least a 2000 lb load rating. No need for guides. No need for swivels. Axis of rotation for the wheel to be horizontal, running side to side. Your pull off angles to the side (for the anchor, or the glider while climbing) will never be more than a few degrees, and the rope will not want to climb out of the deepest part of the wheel. Don't add more complication than is needed. With 8000 feet of ramp, you probably don't need much more than 6000 feet of rope.
If you are anchoring the pulley (say, to a parked car), still no need for a swivel. Keep your life simple! Just my two cents worth. Steve Leonard |
On Tuesday, July 26, 2016 at 8:38:31 AM UTC-6, Steve Leonard wrote:
I would get a 15 to 17 inch rim from a junk yard. Cheap, steel, plain. Then, get a stub axle and hub from Tractor Supply or the like with at least a 2000 lb load rating. No need for guides. No need for swivels. Axis of rotation for the wheel to be horizontal, running side to side. Your pull off angles to the side (for the anchor, or the glider while climbing) will never be more than a few degrees, and the rope will not want to climb out of the deepest part of the wheel. Don't add more complication than is needed. With 8000 feet of ramp, you probably don't need much more than 6000 feet of rope. If you are anchoring the pulley (say, to a parked car), still no need for a swivel. Keep your life simple! Just my two cents worth. Steve Leonard Steve, that is exactly what I was planning to do at first. As I looked at other applications, I began to think that I was making it too simple, and needed more precision. Maybe some other designs are overly complex. |
vortex ring state at any point during an auto?? | Greg Johnson | Rotorcraft | 18 | August 30th 04 09:12 PM |
Auto Fuel Residue | Stu Gotts | Restoration | 4 | May 12th 04 08:52 PM |
Auto conversions & gear boxes | Dave Covert | Home Built | 56 | April 1st 04 06:19 PM |
Arrow auto gear extension oddness | Roy Smith | Owning | 10 | March 8th 04 02:27 AM |
VOR & Reverse Sensing | mrwallace | Piloting | 1 | August 21st 03 03:08 AM |
