At higher G loading as in steep turns many if not most gliders run out of elevator authority making them difficult if not nearly impossible to stall. Airplanes on the other hand have the propeller wash influencing elevator authority.
Le mardi 2 août 2016 22:07:26 UTC+2, a écritÂ*:
At higher G loading as in steep turns many if not most gliders run out of elevator authority making them difficult if not nearly impossible to stall.. Airplanes on the other hand have the propeller wash influencing elevator authority. If your talking bank angles beyond 60 degrees, maybe. Anything below - absolutely not. That is, if you respect max mass in the seat. Actually, if you stall a 25+ m ship at 60 deg bank, spin entry is much more violent than at 30 deg bank, and stopping the spin takes significantly more time. I've done that, and I won't do it again. So, relating to patterns where you probably don't do more than 45 degree banks, your statement is senseless. |
I haven't flown any 25 m gliders. I've flown about 35 types, a lot of trainers... The vast majority of them are much easier to stall and spin from shallow bank angles then from medium and steep bank angles. If I am alone in this perception that's news to me.
On Tuesday, August 2, 2016 at 3:03:43 PM UTC-7, wrote:
I haven't flown any 25 m gliders. I've flown about 35 types, a lot of trainers... The vast majority of them are much easier to stall and spin from shallow bank angles then from medium and steep bank angles. If I am alone in this perception that's news to me. Seems to me that if you are in danger of spinning from a shallow turn in the landing pattern, you are going much too slow. If you are going that slow, won't a sudden steep turn put you below the stall speed? And won't that cause you to fall rather quickly from the sky? |
Can we agree that stalling is directly related to angle of attack and secondarily related to airspeed?
Le mercredi 3 août 2016 01:43:20 UTC+2, a écritÂ*:
Can we agree that stalling is directly related to angle of attack and secondarily related to airspeed? Absolutely. At moderate bank angles, say below 60 degree, all gliders I've flown so far do have enough elevator authority to stall them. As the g-loads increase with banking angle, the momentum created by one wing stalled and the other sill flying increases, so departure into spin will be more violent. Now, if you moce the center of gravity forward, the you will limit the elevator authority needed to stall the glider. Seats are typically limited to 242 pounds due to the maximum allowable stress on the harness attachment points and exceedig this, you often can't stall the glider even with wings levelled. In trainers, this is more pronounced as part of the backseat load counts towards the effective load in the front seat (in a Duo, it's about one third). So, having two stately mammiferes on board will drastically increase spin resistance, and decrease the maximum bank angle where you can still stall the glider. But the typical single seater glass ship flown within the CoG range defined by the manufacturer has no increased spin resistance whatsoever at bank angles used during pattern. |
Why is it always the guys who are wound to tight, the ones that accuse others of being wound too tight? (Generally doing so with the excessive use of capitals).
:O |
"Seems to me that if you are in danger of spinning from a shallow turn in the landing pattern, you are going much too slow."
Exactly. Or, if you are going much too slow you are in danger from spinning from a shallow turn in the landing pattern. If you are going much too slow you are in less danger from spinning from a medium/steeper turn in the landing pattern because at low speed most gliders run out of up elevator authority before reaching critical angle of attack. |
Just repeating this nonsense doesn't make it become true...
Downwind to final turns | Jonathan St. Cloud | Soaring | 18 | June 7th 15 02:19 PM |
Base to Final - Fatal | Orval Fairbairn[_2_] | Piloting | 0 | August 8th 10 03:23 AM |
The Art of Racing - Final Turn.jpg (1/1) | Mitchell Holman[_4_] | Aviation Photos | 0 | February 27th 10 12:42 PM |
Final Approach, pt 3 - KFME final.jpg (1/1) | Mitchell Holman[_3_] | Aviation Photos | 0 | April 8th 09 12:56 PM |
Turn to Final - Keeping Ball Centered | skym | Piloting | 224 | March 17th 08 03:46 AM |
