Boy Who Flew With Condors - Dick Johnson? Other Comments
Old August 28th 16, 03:09 AM posted to rec.aviation.soaring
Default Boy Who Flew With Condors - Dick Johnson? Other Comments
On Friday, April 1, 2016 at 6:35:28 AM UTC-6, wrote:
R Buck, thanks for the post. It also brought back many good old memories. That movie was one of the major influencers when I was a 14 year old kid learning in the 2-22. I felt I was in heaven the day I solo'd in the 1-26! 40 years later I ended up acquiring that self same 1-26 serial number 225 and am reworking all the badges.
As to low thermalling, I've made saves routinely from 200 ft. Its not the dangerous big deal that many make it out to be, and in the "old days" of flying low performance ships, its something of an essential skill needed if you intend to get anywhere xc. The issue is not "turns at low levels", its improper turns. I turn 8 to 14 hours a day, all day long at below 200 ft with an insainly high wing loading (2000 lbs of fertilizer) and I do it safely. Those that make arbitrary rules about thermalling are missing and stunting a natural progression of soaring education that should occur. Most that make these rules have never learned themselves.
Yes its a good starting place rule for new students. As a cfi-g I also discourage newby's and pilots with undeveloped airmanship from low saves. But at the same time we work and work and work on proper turning and recognizing "feeling" and knowing exactly what is happening in every portion of the turn, so when they find themselves in a "bind", they're not in a freak out sense of anxiety, they turn properly and either make a save or land out, neither of which is a big deal to the guy who is prepared.
My hubby, John, is the proud owner of SN#226 and is in the process of cleaning it and restoring it!
Old August 28th 16, 04:45 AM posted to rec.aviation.soaring
Margaret Birsner MAY now be Margaret Rapaport and living in New York.
Dick Johnson Video Interview Kemp[_2_] Soaring 3 August 7th 08 07:37 PM
Dick Johnson is gone. Burt Compton - Marfa Soaring 23 July 27th 08 05:38 PM
Updated Boy Who Flew With Condors page Paul Remde Soaring 0 June 28th 08 03:56 AM
Contacts of Dick Johnson Francisco De Almeida Soaring 1 January 1st 06 06:07 PM
SSA Dick Johnson sailplane reviews: available to all Martin Gregorie Soaring 13 September 27th 05 06:41 PM
