F-4 w/AIM-9 and bombs carriage question
Old June 15th 04, 09:18 PM
Guy Alcala
Chad Irby wrote:
Guy Alcala wrote:
snip
OTOH, I'm pretty sure I've seen photos of F-4s with TERs, AIM-9
launchers _and_ ALE-40s on the I/Bs (the AIM-9 launch shoes
definitely clear the dispenser; I assume the missile tail fins would
also), so it appears that the problem isn't physical clearance,
although I suppose there might be safety limits due to the proximity
of the missile(s) motor nozzle to the pyrotechnics in the ALE-40.
The casing of the ALE-40 was streamlined, far enough back, and thick
enough that a second of flame from a rocket motor shouldn't have caused
any issues, especially since the Sidewinders were further out than the
dispensers. The box was only a foot or so tall, about six inches
through, tapered, and the carts were pretty nicely sealed (and
electrically fired).
Here's a couple of pics of the master dispenser on the left side with a
flare adapter mounted:
http://www.b-domke.de/AviationImages/Phantom/1340.html
http://www.b-domke.de/AviationImages/Phantom/1341.html
Thanks for the links. The only photos I have of ALE-40s on a/c lack the
slanted fairing at the aft end (I assume this is the flare adapter you refer
to). I have one shot from the rear side of the pylon where you can see the
aft end (I/B side dispenser) tilted down with what's clearly the 15
compartment flare interior (the O/B side dispenser has the 30 compartment
chaff setup, and comes back level), but the cover plate bolts and aft side
don't look the same as the one in the photo. Probably just a slightly
different model of ALE-40.
Here's one of an F-4F, with live Sidewinders (but no flares loaded):
http://www.b-domke.de/AviationImages/Phantom/2992.html
You can tell there's no flares on the dispenser because the flare
adapter is visible between the top two rear fins on the closer AIM-9
(and no safety pin, either).
However, ISTR that such shots tend to be of the airshow/museum
"everything we might ever _think_ of putting on an a/c" variety, so I
don't know if such photos represent an operationally allowed loadout.
Anyone know if AIM-9s were allowed to be fired if you had
chaff/flares in the ALE-40s?
What good would a chaff/flare system be if you could only use it if you
gave up your short-range missiles?
Beats not having them at all, I guess, especially if the main threat was SA
systems and you were going to use the decoys on every mission but might never
need the AIM-9s (and then most likely on egress), but I agree it would be less
than ideal. If push came to shove, I'm sure the pilot would say 'screw it'
and fire anyway, if their were no interlocks which prevented that.
As it was, the USAF fought most or all the Vietnam War with F-4s that couldn't
carry bombs and AIM-9s at the same time, leaving the strikers to rely on
(typically) a pair of AIM-7s (and a gun if E models) if they got jumped. That
seems pretty dumb too, but we did it.
I'm pretty sure the times we took the dispensers off were for carrying
missiles with really large tail fins,
snip
Yeah, they seem to be missing when carrying GBU-15s or Walleyes, and I'm not
sure about Standards or Paveway I (non-folding fin) Mk.84s.
Guy
Old June 15th 04, 11:41 PM
Chad Irby
Guy Alcala wrote:
Chad Irby wrote:
Guy Alcala wrote:
snip
In the "1341" photo above, the wedge-shaped part with "LH" on it is the
left hand flare adapter (from the rear of the pylon). There was a
right-hand adapter for the right side of the pylon (we always loaded
chaff outboard and flares inboard on the George AFB F-4s), and we only
put them on the dispensers when specifically requested to. The wedge
was to make sure the flares went down and away from the speed brakes
(although there was a switch that was supposed to prevent firing when
the speed brakes were extended). The chaff didn't need an adapter,
since the cartridges were smaller and didn't have much solid stuff in
them. When installing the wedge adapters, you had to flip the "F-C"
switch on the side (at the little aluminum square with "F" and "C" just
aft of "2771"), which made the box "think" it had chaff or flares.
The dispenser itself only goes back to the four Phillips screws running
vertically in the 1341 shot. The inboard slave dispenser was even
smaller, and was about 1/3 the volume of the master.
was SA systems and you were going to use the decoys on every mission
but might never need the AIM-9s (and then most likely on egress), but
I agree it would be less than ideal. If push came to shove, I'm sure
the pilot would say 'screw it' and fire anyway, if their were no
The only interlock on the ALE-40 was the speed brake switch (with the
safety pin on the master dispenser itself). You could (and people did)
accidentally fire them on the ground. There was *no* direct tie between
the ALE-40 and the rest of the active systems on the plane, the
dispenser control panel just went straight to the ALE-40 (although a mod
to allow the ALR-69 to fire the chaff was possible, we didn't have
that).
When we did tests of the system, we just slapped a power unit on the
plane, fired everything up, turned the ALE-40 on, and used a tester to
see if the individual cart pins were getting firing voltages (through
the high-tech method of looking at a bunch of light bulbs on a box and
counting them as they lit when we pressed the button).
cirby at cfl.rr.com
Remember: Objects in rearview mirror may be hallucinations.
Slam on brakes accordingly.
Did the Germans have the Norden bombsight? Cub Driver Military Aviation 106 May 12th 04 07:18 AM
Mosquito fighter-bomber tactics question Kari Korpi Military Aviation 6 April 5th 04 09:09 AM
Hiroshima/Nagasaki vs conventional B-17 bombing zxcv Military Aviation 55 April 4th 04 07:05 AM
Viggen armament question Kari Korpi Military Aviation 0 March 5th 04 09:47 PM
#1 Jet of World War II Christopher Military Aviation 203 September 1st 03 03:04 AM
