Buying a glider, advice on type and prices
Old August 29th 16, 09:40 PM
Kevin Brooker Kevin Brooker is offline
Junior Member
First recorded activity by AviationBanter: Jun 2010
for he greatest investment in your soaring enjoyment, buy the absolute best trailer you can find. No issues and well equipped to make rigging so simple a child can do it blindfolded. Buy the trailer and fly whatever is inside.
Old August 29th 16, 10:58 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Default Buying a glider, advice on type and prices
Wow, thanks everyone for taking the time to help, just the kind of information I need. I'm not familiar with the LAK17 so will google it now.
I'm not low time or rusty in any way so just need a briefing on flaps really. Rarely flown with retractable undercarriage so that does concern me slightly and a good warning system would be handy.
My main limitation in a few years may be lifting, so light weight CF wings and easy to rig is important to me. And yes, it must be comfortable for tall pilot and long flights.
New to forums so hope I have posted correctly.
If light wings are important, the SZD-55 is a good candidate. Late 80's standard class (no flaps) 15 m span design; 105 lb wings (no one runs away at assembly time); automatic control hook-ups. Comfortable for tall pilots. Still being produced new; good factory support (recently granted EASA life of 12,000 hours). If you're in the east, works well in weak weather, and if you fill it with water, good out west; can be ordered with an award winning stall warning system (SP-3). Very pretty as well, which should count for something! Availble with polyurathane paint (never a gelcoat finish problem). About the same performance as ASW-24 and original Discus B (less than Discus 2). The North American dealer (and others) flew a number of 1,000 km flights at the Ridge in PA. Less expensive new than other choices...
http://szd.com.pl/en/products/szd-55-1 (factory link)
http://www.windpath.ca/index.php/products/szd-allstar (NA dealer link)
I love my 55! The 24 and Discus are also good choices, and a good trailer makes all the difference, as others have said. Lots of performance, good handling, and safe.
Dan
Old August 30th 16, 05:47 AM posted to rec.aviation.soaring
Tango Whisky
Nonsense.
Buy the best glidee you can afford, ans adapt the trailee if needed.
Bert
Ventis cM "TW"
Old August 30th 16, 06:52 AM posted to rec.aviation.soaring
John[_37_]
Dan
Looking it up thanks. I'm in Northern UK and poor lift comes as standard!
Light wings and low price for new is a definite bonus.
The site says something like approved life of 3000 hours with extensions so maybe that's the one that's now been upgraded to 12,000 hours. (will check) That's one reason I was looking for a more recent model in case GRP gliders do have problems in later life. Just about anything will outlast me but I'm thinking resale value.
Question: Do all GRP and CF gliders have similar life spans to each other or does it vary considerably?
Old August 30th 16, 06:53 AM posted to rec.aviation.soaring
John[_37_]
whatever is inside.
Kevin Brooker
Lol, nice SOH
Old August 30th 16, 08:24 AM posted to rec.aviation.soaring
If light wings are important, the SZD-55 is a good candidate. Late 80's standard class (no flaps) 15 m span design; 105 lb wings (no one runs away at assembly time); automatic control hook-ups. Comfortable for tall pilots.. Still being produced new; good factory support (recently granted EASA life of 12,000 hours). If you're in the east, works well in weak weather, and if you fill it with water, good out west; can be ordered with an award winning stall warning system (SP-3). Very pretty as well, which should count for something! Availble with polyurathane paint (never a gelcoat finish problem). About the same performance as ASW-24 and original Discus B (less than Discus 2). The North American dealer (and others) flew a number of 1,000 km flights at the Ridge in PA. Less expensive new than other choices...
Dan
Most of them seem to be similar - they start out with 3,000 hours and then keep getting extended as the fleet ages and experience is gained. The Pegase is one exception - but only under the aegis of the FAA. If I had your budget and was returning to soaring after a time off I would go with the ASW-28 or Discus 2. Hard to beat a nice friendly standard class (or 18 meter) for pure fun and ease of flying. In the price range you're looking at odds are the gliders will be in a good clamshell trailer which is a wonderful thing. Those of us in the bargain basement have to contend with choosing ships which may come with all sorts of oddball contraptions. There's a privately owned SZD-55 in my club. While I haven't flown it I can attest to the wings being nice and light and the ease of assembly. The build quality seems top notch too. The type certificate in Canada lists a stall warning device as mandatory equipment and two of the three 55's I've seen didn't have them so if the authority where you fly also requires it make sure it's in any 55 you're looking to buy.
Old August 30th 16, 12:53 PM posted to rec.aviation.soaring
Dan Daly[_2_]
http://szd.com.pl/downloads/4fdeffe8...l-10039816.pdf is the document which extends the life of all SZD-55 to 12k. The associated Flight Manual must be amended with the 2012 changes, which is noted at the end of the EASA document. Mainly they talk about what inspections have to be done periodically, and change the bits of the manual that talk about the authorized lifespan of the glider.
Most gliders get an initial 3,000 hr approval, then as they approach that, they are assessed by the factory to see if they have problems. If not, additional 3,000 hrs. As they approach 6,000, same, etc., until design life is reached. I don't know what the design life of Schempp-Hirth, Schleicher, etc are (I know ASK-21's are at 18,000 hrs). I think of most GRP gliders as having infinite lives, though gelcoat must be refinished periodically.
Old August 30th 16, 07:48 PM posted to rec.aviation.soaring
John[_37_]
Dan
Thanks for the nice reply. I'm not wealthy at all, sold my house and bought a caravan when the ex. left me. I love my caravan, it's in a fantastic location and then I found a really exciting ridge soaring site nearby and here I am! May as well spend it whilst I can and have some fun. Thought a decent glider will be as good as money in the bank just now. Really appreciate the friendly help from everyone.
Old August 30th 16, 08:27 PM posted to rec.aviation.soaring
Papa3[_2_]
This has the makings of a great Country Music song. Ed Kilbourne, where are you?
Old August 30th 16, 08:37 PM posted to rec.aviation.soaring
John[_37_]
Brilliant idea, yes it does!
Student Pilot needs advice on buying 172 Cessna mcannon Owning 2 September 5th 05 03:43 PM
Advice on buying a 182 Robbie S. Owning 26 February 11th 05 10:28 PM
Advice on buying a 152? rajek Owning 27 June 21st 04 08:09 PM
I need some advice on buying my own plane BEFORE training... Anthony L Piloting 6 April 22nd 04 11:13 PM
Advice request -- buying an airplane Casey Wilson Owning 4 April 19th 04 03:22 PM
