In reply to (re-ordering for clarity's sake)...
On Tuesday, August 30, 2016 at 7:20:26 PM UTC-4, Bob Whelan wrote: On 8/30/2016 2:42 PM, It was written: Aerodynamics isn't the issue - gelcoat failure can progress until it's a structural issue. In the spirit of seeking genuine knowledge - and readily acknowledging widespread *concern* that cracking/flaking gelcoat can "somehow" morph into a "premature" structural issue - can anyone cite solid information (data, links, etc.) shedding light on the mechanism(s?), location and quantity of UV-exposed plastic sailplanes thrown onto the garbage heap after failing structural tests, etc.? It's a serious - not rhetorical - query. There's plenty of engineering data, as well as "common-sense/observational data", around indicating UV is a catholic attacker/degrader of all manner of materials, but have sailplane manufacturers, or (say) the LBA, or anyone else, set about obtaining such data for GRP/CRP sailplanes? Hard data eagerly welcomed! Bob W. ....On 8/30/2016 8:11 PM, Papa3 wrote: Failed gelcoat absolutely "prints" down into the glass/epoxy substrate. We've just refinished two gliders in our club which were left to go beyond minor crazing to full-on gelcoat failure. Once the gelcoat is totally stripped, you're left with visible lines in the glass/epoxy. Under a 4x loupe you can see that there is an edge to these lines where there are small voids in the epoxy. Long-ago memory sez I/we saw similar "lines" in?/atop? the first cloth layer beneath cracked gelcoat on our club's G-103 wings that we refinished (mid-90s-ish). At the time, and under the supervision of a highly-experienced plastic glider repair person/DER (with "hand-in-hand" signoff authority of an FAA-blessed A&P w. IA), I believe their working conclusions (after loupe-aided inspection) we a) the lines were in/on the epoxy only and did not extend into the cloth; and b) the outermost cloth was a thin, fine-weave, layer intended less for structure than to provide a "relatively smooth" underlayer for the gelcoat to interact/bond with. Does this materially affect the integrity of the wing/fuselage/control surface structure? That's beyond my pay grade. Gerhard Weibel's take is as follows (from the Schleicher Technical Note on "paint cracks"): Owing to the UV-radiation the gel coat of the paint surfaces grows brittle and shrinks; at the same time the UV-light destroys paint ingredients. So moisture (rain, dew) working in on long term will wash the decomposed paint ingredients out off the paint. The paint starts chalking and gets hairline cracks owing to the concurrence of embrittlement and shrinkage. Furthermore, these hairline cracks gather dirt which through its aggressive effect and its stronger heating-up from sun radiation further precipitates the degradation of the paint. Owing to this the intended protective effect for the fiber composite structure against moisture and UV-radiation is no longer granted. Certainly a good care with hard wax can slow down the above process distinctly, but it cannot be stopped completely. For this reason a repainting of the aircraft will always become necessary at some point of time. However, we point out explicitly that paint cracks - even deep cracks - do not represent damages to the aircraft structure if as of their first appearance immediate correct maintenance and care is given furthermore to the aircraft. As all the outside skin of the aircraft is dimensioned for stiffness, there are no critical mechanical strength problems, even if some cracks have gone down into the fiber composite structure and have already attacked the resin matrix base. The unknown ageing effects caused by the influence of moisture and UV on the unprotected fiber composite structure are more dangerous. P3 Thanks for Dipl. Ing. Waibel's thoughts! Opinions from those with his background and experience ought not be taken lightly. As I interpret the above, his thoughts seem in alignment with our thoughts "from the 90's." Paraphrasing: taking care of a ship's exterior finish is a good idea if extending the life of the factory-applied finish is a concern. The last two sentences of his second paragraph passingly touch upon the question raised in my earlier post. I infer from the closing sentence, that at the time his thoughts were put on paper, he was no more "structural life informed" then than I seem to be today...though he also (and, almost certainly, rightfully) had serious respect for the power of UV to eventually degrade the structure...key word being "eventually." I'd love to see GRP/CRP glider-based engineering data allowing "even-semi-informed" inferences to be made as to whether "eventually" is (say) one year, or (say) 10 years. My interest stems simply from being by nature disinclined to worry about "stuff" that can be safely ignored and that isn't simultaneously "good for one's soul." If it's good for one's soul and pocketbook to "keep after" a ship's factory finish, have at it! But don't agonize over structure if it's unnecessary. Life's full enough of real worries without inventing imaginary ones. Bob W. |
Student Pilot needs advice on buying 172 Cessna | mcannon | Owning | 2 | September 5th 05 03:43 PM |
Advice on buying a 182 | Robbie S. | Owning | 26 | February 11th 05 10:28 PM |
Advice on buying a 152? | rajek | Owning | 27 | June 21st 04 08:09 PM |
I need some advice on buying my own plane BEFORE training... | Anthony L | Piloting | 6 | April 22nd 04 11:13 PM |
Advice request -- buying an airplane | Casey Wilson | Owning | 4 | April 19th 04 03:22 PM |
