On Thursday, September 8, 2016 at 6:12:37 AM UTC-5, joesimmers wrote:
Since you are snug in the G103, the roomiest cockpit out there is the Genesis. Now that I think about it, I recall that the G103 had some crazy thick pads in the seat. At the time, I was fairly new to gliders, so it didn't occur to me that the pad thickness could be changed out. I think what I should do is: 1. Test the seat with no pads. If it's too tight, then that ship is off the list. 2. Test it with whatever pads the owner has. If I still fit, great. If not, then I know that a thinner pad will probably allow me to fit. 3. Research the availability of thinner pads for the glider described in #2 above. As long as I don't have to pay $2k for some custom-stitched job, I can get along. Now parachutes are another story. Unless I have an acro bird, I do not plan to wear one. I hate them. And the thickness of a chute is likely to create insurmountable fit problems. Does anyone want to rebut these points? Or do I seem reasonable? |
Le jeudi 8 septembre 2016 13:54:56 UTC+2, a écritÂ*:
On Thursday, September 8, 2016 at 6:12:37 AM UTC-5, joesimmers wrote: Since you are snug in the G103, the roomiest cockpit out there is the Genesis. Now that I think about it, I recall that the G103 had some crazy thick pads in the seat. At the time, I was fairly new to gliders, so it didn't occur to me that the pad thickness could be changed out. I think what I should do is: 1. Test the seat with no pads. If it's too tight, then that ship is off the list. 2. Test it with whatever pads the owner has. If I still fit, great. If not, then I know that a thinner pad will probably allow me to fit. 3. Research the availability of thinner pads for the glider described in #2 above. As long as I don't have to pay $2k for some custom-stitched job, I can get along. Now parachutes are another story. Unless I have an acro bird, I do not plan to wear one. I hate them. And the thickness of a chute is likely to create insurmountable fit problems. Does anyone want to rebut these points? Or do I seem reasonable? The roomiest cockpit by far (for modern gliders) is the DG-1000 / DG-1001 two-seater. Aerobatic with the 18 m tips, better performance of course with the 20 m tips. Even with a chute, it should be no problem at all. |
Have you considered a Schweitzer 2-32 ? Roomy, high canopy, great load carrying capability. Can fit two people in the back seat if they're real close and less than 300 lbs total.
I'm 6'3" and 230 lbs and fit quite nicely in my Kestrel 19 (and the H.401 Kestrel has the same fuselage), and I wear a parachute. Odd (to me) that you complain about the G103. I fit quite nicely in a Twin Astir T, Twin II and Twin II Acro, but with very thin cushions. No parachute; I'd be too heavy. I don't like the fit of the K-21; I pull out the seat back and the sides press into my shoulders. I don't fit at all with my parachute on, but again, too heavy. |
On Thursday, September 8, 2016 at 3:56:37 PM UTC+3, wrote:
Le jeudi 8 septembre 2016 13:54:56 UTC+2, a écritÂ*: On Thursday, September 8, 2016 at 6:12:37 AM UTC-5, joesimmers wrote: Since you are snug in the G103, the roomiest cockpit out there is the Genesis. Now that I think about it, I recall that the G103 had some crazy thick pads in the seat. At the time, I was fairly new to gliders, so it didn't occur to me that the pad thickness could be changed out. I think what I should do is: 1. Test the seat with no pads. If it's too tight, then that ship is off the list. 2. Test it with whatever pads the owner has. If I still fit, great. If not, then I know that a thinner pad will probably allow me to fit. 3. Research the availability of thinner pads for the glider described in #2 above. As long as I don't have to pay $2k for some custom-stitched job, I can get along. Now parachutes are another story. Unless I have an acro bird, I do not plan to wear one. I hate them. And the thickness of a chute is likely to create insurmountable fit problems. Does anyone want to rebut these points? Or do I seem reasonable? The roomiest cockpit by far (for modern gliders) is the DG-1000 / DG-1001 two-seater. Aerobatic with the 18 m tips, better performance of course with the 20 m tips. Even with a chute, it should be no problem at all. DG1000 is very roomy in the back, but a bit narrow in the front! I've sometimes contemplated throwing a bunch of ballast in the front and flying it solo from the back. But I've always managed to find a victim willing to sit in the front... |
A 6'3" friend of mine flies with a parachute in his ASW-24 (no seat back) and in my previous DG-101 with seat back (and I have to assume the identical cockpit of the 100/200/300 series).
On Thursday, September 8, 2016 at 11:29:19 AM UTC-4, Bruce Hoult wrote:
On Thursday, September 8, 2016 at 3:56:37 PM UTC+3, wrote: Le jeudi 8 septembre 2016 13:54:56 UTC+2, a écritÂ*: On Thursday, September 8, 2016 at 6:12:37 AM UTC-5, joesimmers wrote: Since you are snug in the G103, the roomiest cockpit out there is the Genesis. Now that I think about it, I recall that the G103 had some crazy thick pads in the seat. At the time, I was fairly new to gliders, so it didn't occur to me that the pad thickness could be changed out. I think what I should do is: 1. Test the seat with no pads. If it's too tight, then that ship is off the list. 2. Test it with whatever pads the owner has. If I still fit, great. If not, then I know that a thinner pad will probably allow me to fit. 3. Research the availability of thinner pads for the glider described in #2 above. As long as I don't have to pay $2k for some custom-stitched job, I can get along. Now parachutes are another story. Unless I have an acro bird, I do not plan to wear one. I hate them. And the thickness of a chute is likely to create insurmountable fit problems. Does anyone want to rebut these points? Or do I seem reasonable? The roomiest cockpit by far (for modern gliders) is the DG-1000 / DG-1001 two-seater. Aerobatic with the 18 m tips, better performance of course with the 20 m tips. Even with a chute, it should be no problem at all. DG1000 is very roomy in the back, but a bit narrow in the front! I've sometimes contemplated throwing a bunch of ballast in the front and flying it solo from the back. But I've always managed to find a victim willing to sit in the front... Are there many DG1000's available for less than $30,000? |
On Friday, September 9, 2016 at 7:29:11 AM UTC+12, PGS wrote:
On Thursday, September 8, 2016 at 11:29:19 AM UTC-4, Bruce Hoult wrote: On Thursday, September 8, 2016 at 3:56:37 PM UTC+3, wrote: Le jeudi 8 septembre 2016 13:54:56 UTC+2, a écritÂ*: On Thursday, September 8, 2016 at 6:12:37 AM UTC-5, joesimmers wrote: Since you are snug in the G103, the roomiest cockpit out there is the Genesis. Now that I think about it, I recall that the G103 had some crazy thick pads in the seat. At the time, I was fairly new to gliders, so it didn't occur to me that the pad thickness could be changed out. I think what I should do is: 1. Test the seat with no pads. If it's too tight, then that ship is off the list. 2. Test it with whatever pads the owner has. If I still fit, great.. If not, then I know that a thinner pad will probably allow me to fit. 3. Research the availability of thinner pads for the glider described in #2 above. As long as I don't have to pay $2k for some custom-stitched job, I can get along. Now parachutes are another story. Unless I have an acro bird, I do not plan to wear one. I hate them. And the thickness of a chute is likely to create insurmountable fit problems. Does anyone want to rebut these points? Or do I seem reasonable? The roomiest cockpit by far (for modern gliders) is the DG-1000 / DG-1001 two-seater. Aerobatic with the 18 m tips, better performance of course with the 20 m tips. Even with a chute, it should be no problem at all. DG1000 is very roomy in the back, but a bit narrow in the front! I've sometimes contemplated throwing a bunch of ballast in the front and flying it solo from the back. But I've always managed to find a victim willing to sit in the front... Are there many DG1000's available for less than $30,000? You might get a quarter or fifth share or so in one, depending on how it was set up :-) |
I am 6'3". The grob 103 is comfortable without a parachute. But I don't fit with my parachute. A lark is a cheap two place ship if you can find one, but after an hour or so you'll be miserable.
For single place, an ASW19 is a great fit. You will need to remove the seat, which takes about 30 seconds. Its comfortable for at least 5 1/2 hours. The asw20 cockpit is the same design, so that might be a good fit also. |
I'm 6'4" 175 lb. I co-owned a Twin Lark wit a couple of big tall guys, one my height but 190 lbs and one 6'2" 200 lbs. We could all fit in both cockpits, although it was a bit snug fo flights longer than 3 hors.
Branko |
Sooo ... Glider pilots DO make good jet pilots! | AS | Soaring | 2 | November 30th 15 09:02 AM |
Good news for pilots - retirement age | Greg Farris | Piloting | 48 | January 29th 07 01:57 AM |
About Good Pilots and Bad Pilots | Dudley Henriques | Piloting | 96 | February 23rd 06 01:19 AM |
Are pilots really good or just lucky??? | Icebound | Instrument Flight Rules | 68 | December 9th 04 01:53 PM |
Tall pilots in Helo's... | BEEPER708 | Rotorcraft | 5 | September 5th 03 05:05 AM |
