Good sailplanes for tall pilots?
Old September 12th 16, 02:19 PM posted to rec.aviation.soaring
kirk.stant
Default Good sailplanes for tall pilots?
On Monday, September 12, 2016 at 2:23:47 AM UTC-5, wrote:
canopy closed.
As for chutes, since I don't intend to fly in competitions and the Grob hasn't had the AD mod to be flown acro, I feel no urgent need to get one.
OT: That's like saying you don't wear seatbelts in your car because you don't intend to have an accident.
Funny how some countries mandate chute wear in gliders. Wonder what they know that we don't...
But I'm being a hypocrite - when I fly club ships I only wear a chute when doing acro. Since I usually only fly the club ships to give rides and the club doesn't have a chute for the passenger, I don't wear mine. But in my glider? Every time; even for a pattern tow.
BOT: You might try an LS3/4/8/6. Lots of rudder pedal adjustment. Ventus Bs also have long cockpits - and the Cirrus is the same shape, I believe?
Good luck with your search!
Kirk
66
Old September 12th 16, 03:04 PM posted to rec.aviation.soaring
You should consider the LS4/6/8.
Large pilots usually completely remove the adjustable seat back. The rear cockpit bulkhead is flat and sloped just like a seatback. The LS series is designed to fly with a parachute.
Old September 12th 16, 03:54 PM posted to rec.aviation.soaring
Dan Daly[_2_]
In the lower price range, the Standard Jantar usually has PU paint and has a very lengthy cockpit - second biggest cockpit (after the Genesis) I've seen. Long arms would be a bonus - instrument pod is well forward. Usually one on Wings and Wheels.
The HpH304 Shark is also very big, but way out of your stated price range.
Ka6 - I'm 5'10" and found the Ka-6e to be snug for my height - had a 1/3 share for a year. 1-26's were bigger inside (though not particularly comfortable after an hour or two).
Old September 12th 16, 07:45 PM posted to rec.aviation.soaring
A Genesis 2 would be a good choice. Single seater though.holds a 155-242 lb. Pilot and is very roomy..
Sooo ... Glider pilots DO make good jet pilots! AS Soaring 2 November 30th 15 09:02 AM
Good news for pilots - retirement age Greg Farris Piloting 48 January 29th 07 01:57 AM
About Good Pilots and Bad Pilots Dudley Henriques Piloting 96 February 23rd 06 01:19 AM
Are pilots really good or just lucky??? Icebound Instrument Flight Rules 68 December 9th 04 01:53 PM
Tall pilots in Helo's... BEEPER708 Rotorcraft 5 September 5th 03 05:05 AM
