Good sailplanes for tall pilots?
Old September 12th 16, 03:04 PM posted to rec.aviation.soaring
Default Good sailplanes for tall pilots?
You should consider the LS4/6/8.
Large pilots usually completely remove the adjustable seat back. The rear cockpit bulkhead is flat and sloped just like a seatback. The LS series is designed to fly with a parachute.
Old September 12th 16, 03:54 PM posted to rec.aviation.soaring
Dan Daly[_2_]
In the lower price range, the Standard Jantar usually has PU paint and has a very lengthy cockpit - second biggest cockpit (after the Genesis) I've seen. Long arms would be a bonus - instrument pod is well forward. Usually one on Wings and Wheels.
The HpH304 Shark is also very big, but way out of your stated price range.
Ka6 - I'm 5'10" and found the Ka-6e to be snug for my height - had a 1/3 share for a year. 1-26's were bigger inside (though not particularly comfortable after an hour or two).
Old September 12th 16, 07:45 PM posted to rec.aviation.soaring
A Genesis 2 would be a good choice. Single seater though.holds a 155-242 lb. Pilot and is very roomy..
Sooo ... Glider pilots DO make good jet pilots! AS Soaring 2 November 30th 15 09:02 AM
Good news for pilots - retirement age Greg Farris Piloting 48 January 29th 07 01:57 AM
About Good Pilots and Bad Pilots Dudley Henriques Piloting 96 February 23rd 06 01:19 AM
Are pilots really good or just lucky??? Icebound Instrument Flight Rules 68 December 9th 04 01:53 PM
Tall pilots in Helo's... BEEPER708 Rotorcraft 5 September 5th 03 05:05 AM
