On Tuesday, September 13, 2016 at 10:48:40 AM UTC-5, waremark wrote:
Yes, without connection it is only able to work from gps altitude and the gps chip is not accurate when circling tightly. Ideally it should be connected to an external gps source as well as a smart vario to get both vario and position data more accurately. I found it useless without external data. In the old days of Winpilot the thermal maximiser was only available in the pro version which required smart vario data. "Old days"? What Old Days? I'm still flying with WinPilot Pro and 302 and do not feel handicapped vs. the newer systems. Especially the Climb Maximizer is something of a secret weapon (don't tell anyone!). |
On Wednesday, September 14, 2016 at 7:24:17 AM UTC-6, wrote:
"Old days"? What Old Days? Commonly referred to as "Back in the day", "Old school", "When you were just a sparkle in your mothers eye", or for those less sophisticated, "When you were still an itch in your daddy's pants". Hope this helps. SYM will use the GPS position from your logger and pressure altitude from your instrument. There is a partial list here http://www.cumulus-soaring.com/software-pda.htm and I believe winds and TAS can also be input to SYM from certain instruments. |
On Wednesday, September 14, 2016 at 12:31:11 PM UTC-5, K m wrote:
On Wednesday, September 14, 2016 at 7:24:17 AM UTC-6, wrote: "Old days"? What Old Days? Commonly referred to as "Back in the day", "Old school", "When you were just a sparkle in your mothers eye", or for those less sophisticated, "When you were still an itch in your daddy's pants". Hope this helps. SYM will use the GPS position from your logger and pressure altitude from your instrument. There is a partial list here http://www.cumulus-soaring.com/software-pda.htm and I believe winds and TAS can also be input to SYM from certain instruments. Now that was really helpful, KM, thanks so very much. My limited command of the English language is again very notable. As I understand it, WinPilot uses the very data you mention (from the 302) to determine immediate (vector) wind and precise position and pressure altitude for determining other parameters. SYM has nothing new over WinPilot. Btw., at my younger age (and in my "old days") we made the vario tone with a recorder that we carried. |
On Wednesday, September 14, 2016 at 1:44:27 PM UTC-6, wrote:
On Wednesday, September 14, 2016 at 12:31:11 PM UTC-5, K m wrote: On Wednesday, September 14, 2016 at 7:24:17 AM UTC-6, wrote: "Old days"? What Old Days? Commonly referred to as "Back in the day", "Old school", "When you were just a sparkle in your mothers eye", or for those less sophisticated, "When you were still an itch in your daddy's pants". Hope this helps. SYM will use the GPS position from your logger and pressure altitude from your instrument. There is a partial list here http://www.cumulus-soaring..com/software-pda.htm and I believe winds and TAS can also be input to SYM from certain instruments. Now that was really helpful, KM, thanks so very much. My limited command of the English language is again very notable. As I understand it, WinPilot uses the very data you mention (from the 302) to determine immediate (vector) wind and precise position and pressure altitude for determining other parameters. SYM has nothing new over WinPilot. Yea, Ive heard good things about the thermal assist on WinPilot. I used to like the thermal assist on SYM until I used the thermal assist on my S7. It is easily twice as accurate and displays the wind vector. Great for centering! What do you use to run WinPilot? I was on the WP site and they show the software for Iphone and Ipad but does anyone know if an Ipad (Or Mini)is sunlight readable? Thanks |
It's interesting as this topic keeps on popping up.
I too keep going back to Windows version of WinPilot. I also am very familiar with and used frequently SYM, XCSOAR but keep going back to Win Pilot which unfortunately is no longer supported. There are more reasons than just the Thermal Assist here,although this feature is just more straight forward. Both with SYM and XCSOAR running the Thermal Assist requires looking at the instrument, not with WP through . I can simply rely on the chime and glance at the arrow once about every turn or so if and when using this feature. I have WP running on the now also discontinued Vertica2 PNA, something similar to the Oudie unit. I suppose you could also run WP on an Oudie, however I'm not sure. (I know you can run XCSOAR on it but you can say goodbye to SYM than). Than of course there is the Win Pilot IOS version whichhe keeps on changing. I never heard of anyone running it through. It would be nice to hear feedback but after the poor customer support, I guess people avoid it like the plaque. |
I'll surely offend someone here :-).
There are better solutions out there now. I used the 302 + WinPilot combo in 2008. It worked fine. I gave up on WP when it became clear that Jerry wasn't going to fix some issues that were truly vexing and wouldn't answer email from a paying subscriber. I did miss the thermal optimizer... I never really bonded with the 302 vario by itself. If you are allergic to anything that smacks of commercial content, go ahead and turn the page now please... ClearNav CNv's response is such that you probably don't need a centering tool at all. It's nearly "seat of the pants" fast, but doesn't get jittery like many electronic varios do when set to small time constants. You really have to see this in action to appreciate how good it is. If you do want/like a thermal centering device, there's one built into CNvXC that works very well indeed. WP was in my opinion "the centering tool that actually worked"... and CNvXC is better still. As with WP, there are audio cues for centering. Ask anyone that owns one (best with most recent updates). Evan Ludeman @ CNi |
On Thursday, September 15, 2016 at 1:14:16 PM UTC-5, Tango Eight wrote:
I'll surely offend someone here :-). There are better solutions out there now. I used the 302 + WinPilot combo in 2008. It worked fine. I gave up on WP when it became clear that Jerry wasn't going to fix some issues that were truly vexing and wouldn't answer email from a paying subscriber. I did miss the thermal optimizer... I never really bonded with the 302 vario by itself. If you are allergic to anything that smacks of commercial content, go ahead and turn the page now please... ClearNav CNv's response is such that you probably don't need a centering tool at all. It's nearly "seat of the pants" fast, but doesn't get jittery like many electronic varios do when set to small time constants. You really have to see this in action to appreciate how good it is. If you do want/like a thermal centering device, there's one built into CNvXC that works very well indeed. WP was in my opinion "the centering tool that actually worked"... and CNvXC is better still. As with WP, there are audio cues for centering. Ask anyone that owns one (best with most recent updates). Evan Ludeman @ CNi Evan, I actually agree with my many friends and ClearNav afficionados (BB is one of them) that you have an excellent product. I sometimes get beaten by them flying the dreaded Area Task which ClearNav seems to handle beautifully, WinPilot not so much. Maybe in my next glider - but my wife thinks I'm doing just fine in the one I fly, have to land out more! Herb |
On Thursday, September 15, 2016 at 3:38:59 PM UTC-4, wrote:
On Thursday, September 15, 2016 at 1:14:16 PM UTC-5, Tango Eight wrote: I'll surely offend someone here :-). There are better solutions out there now. I used the 302 + WinPilot combo in 2008. It worked fine. I gave up on WP when it became clear that Jerry wasn't going to fix some issues that were truly vexing and wouldn't answer email from a paying subscriber. I did miss the thermal optimizer... I never really bonded with the 302 vario by itself. If you are allergic to anything that smacks of commercial content, go ahead and turn the page now please... ClearNav CNv's response is such that you probably don't need a centering tool at all. It's nearly "seat of the pants" fast, but doesn't get jittery like many electronic varios do when set to small time constants. You really have to see this in action to appreciate how good it is. If you do want/like a thermal centering device, there's one built into CNvXC that works very well indeed. WP was in my opinion "the centering tool that actually worked"... and CNvXC is better still. As with WP, there are audio cues for centering. Ask anyone that owns one (best with most recent updates). Evan Ludeman @ CNi Evan, I actually agree with my many friends and ClearNav afficionados (BB is one of them) that you have an excellent product. I sometimes get beaten by them flying the dreaded Area Task which ClearNav seems to handle beautifully, WinPilot not so much. Maybe in my next glider - but my wife thinks I'm doing just fine in the one I fly, have to land out more! Herb Hi Herb, Thanks for the kind words. Btw, just to clarify (because it'll be counter intuitive to a WP user): the thermal assistant I refer to above is part of our variometer, not the flight computer. See you at New Castle. I'll do my best to bring some good weather. -Evan |
I just updated my 29 panel this spring from an SN10/Ilec vario linked to an Oudie to a new panel with a CN2 with the CN NAV vario (square with red buttons) and a LXNav S10 (new all in one, Nav, Task, Flarm, AHRS, IGC Oogger, etc) as a "backup." Backup is a silly description as the S10 is extremely capable as well in a 57mm package.
I have experience with the butterfly vario, V7, 302, XCSoar, of course the SN10 and several others not worth mentioning. The CN "Nav" Vario (again, the square one with red buttons) is absolutely incredible. Simple to use, extremely accurate and seems very stable in bubbly, gusty, difficult thermals. I seem to be climbing better and more importantly, running much better. To me this means more accurate netto and speed to fly. It's the best vario I have ever used. I can't say exactly why I believe this, but I believe it. The S10 Vario is also very good, but I favor the cn vario as it integrates well with the CN2 and is very intuitive. I also had a small technical problem with the S10 (one of the very first delivered) that caused me to disregard it and favor the CN vario (which was flawless). So I don't have the same confidence in the LXNav S10 yet other than to say it is really cool and does anything and everything I could ever need. The thermal centering tool is incredible on the CN Vario (and the S10). The Oudie is OK at best. It MUST be tied into a pressure sensor to be worth anything at all. I was sceptacle of these "full" soaring computers such as the LX9000 and CN2 before switching. But it has been an eye opener for me. Sure there was learning curve. In my case the CN2 is very easy to learn (unlike the LX9000...just ask anyone who uses one, they'll tell you). But once you do master these instrument/flight computers you will have a much more relaxed flight with quicker access to better information. The SN10 is probably still the best overall simple navigation instrument for the money (I have one for sale, ;-)) although it also can be a challenge to learn and master. But it's ILEC vario (ILEC) leaves something to be desired in comparison to the CN Vario (or the LX). Hopefully this has some value for someone out there. Sean |
On Thursday, September 15, 2016 at 6:53:38 PM UTC-6, Sean wrote:
I just updated my 29 panel this spring from an SN10/Ilec vario linked to an Oudie to a new panel with a CN2 with the CN NAV vario (square with red buttons) and a LXNav S10 (new all in one, Nav, Task, Flarm, AHRS, IGC Oogger, etc) as a "backup." Backup is a silly description as the S10 is extremely capable as well in a 57mm package. I have experience with the butterfly vario, V7, 302, XCSoar, of course the SN10 and several others not worth mentioning. The CN "Nav" Vario (again, the square one with red buttons) is absolutely incredible. Simple to use, extremely accurate and seems very stable in bubbly, gusty, difficult thermals. I seem to be climbing better and more importantly, running much better. To me this means more accurate netto and speed to fly. It's the best vario I have ever used. I can't say exactly why I believe this, but I believe it. The S10 Vario is also very good, but I favor the cn vario as it integrates well with the CN2 and is very intuitive. I also had a small technical problem with the S10 (one of the very first delivered) that caused me to disregard it and favor the CN vario (which was flawless). So I don't have the same confidence in the LXNav S10 yet other than to say it is really cool and does anything and everything I could ever need. The thermal centering tool is incredible on the CN Vario (and the S10). The Oudie is OK at best. It MUST be tied into a pressure sensor to be worth anything at all. I was sceptacle of these "full" soaring computers such as the LX9000 and CN2 before switching. But it has been an eye opener for me. Sure there was learning curve. In my case the CN2 is very easy to learn (unlike the LX9000...just ask anyone who uses one, they'll tell you). But once you do master these instrument/flight computers you will have a much more relaxed flight with quicker access to better information. The SN10 is probably still the best overall simple navigation instrument for the money (I have one for sale, ;-)) although it also can be a challenge to learn and master. But it's ILEC vario (ILEC) leaves something to be desired in comparison to the CN Vario (or the LX). Hopefully this has some value for someone out there. Sean For the record, I agree with Sean 100% on the CN LCD Vario with the thermal assistant. This is the first season I used it and I knew pretty quickly that it was going to be the BEST vario I have ever used. I have been at this sport for awhile, having owned 6 sailplanes and having experience with many varios over 4+ decades, and the CN LCD Vario has proven itself to be truly outstanding. I definitely need all the help I can get and this vario really helps me out especially on those days when those New Mexico thermals are rough and difficult to center. So, if you are in the market, you will not go wrong with this vario. Thanks - Renny |
Oudie IGC | Dave Springford | Soaring | 4 | November 12th 13 08:52 PM |
Oudie | Peter von Tresckow | Soaring | 2 | December 18th 11 01:31 PM |
Oudie and 302 | Stephen[_3_] | Soaring | 9 | November 2nd 11 05:07 AM |
Oudie | Steve Hunt | Soaring | 2 | July 8th 11 12:19 AM |
oudie | Steve Hunt[_2_] | Soaring | 0 | July 7th 11 08:58 AM |
