OUDIE
Old September 14th 16, 11:57 PM posted to rec.aviation.soaring
6PK
Default OUDIE
It's interesting as this topic keeps on popping up.
I too keep going back to Windows version of WinPilot.
I also am very familiar with and used frequently SYM, XCSOAR but keep going back to Win Pilot which unfortunately is no longer supported.
There are more reasons than just the Thermal Assist here,although this feature is just more straight forward.
Both with SYM and XCSOAR running the Thermal Assist requires looking at the instrument, not with WP through . I can simply rely on the chime and glance at the arrow once about every turn or so if and when using this feature.
I have WP running on the now also discontinued Vertica2 PNA, something similar to the Oudie unit.
I suppose you could also run WP on an Oudie, however I'm not sure. (I know you can run XCSOAR on it but you can say goodbye to SYM than).
Than of course there is the Win Pilot IOS version whichhe keeps on changing. I never heard of anyone running it through. It would be nice to hear feedback but after the poor customer support, I guess people avoid it like the plaque.
Old September 15th 16, 07:14 PM posted to rec.aviation.soaring
Tango Eight
Default OUDIE
I'll surely offend someone here :-).
There are better solutions out there now.
I used the 302 + WinPilot combo in 2008. It worked fine. I gave up on WP when it became clear that Jerry wasn't going to fix some issues that were truly vexing and wouldn't answer email from a paying subscriber. I did miss the thermal optimizer... I never really bonded with the 302 vario by itself.
If you are allergic to anything that smacks of commercial content, go ahead and turn the page now please...
ClearNav CNv's response is such that you probably don't need a centering tool at all. It's nearly "seat of the pants" fast, but doesn't get jittery like many electronic varios do when set to small time constants. You really have to see this in action to appreciate how good it is. If you do want/like a thermal centering device, there's one built into CNvXC that works very well indeed. WP was in my opinion "the centering tool that actually worked"... and CNvXC is better still. As with WP, there are audio cues for centering.
Ask anyone that owns one (best with most recent updates).
Evan Ludeman @ CNi
Old September 15th 16, 08:38 PM posted to rec.aviation.soaring
Default OUDIE
Evan Ludeman @ CNi
Evan, I actually agree with my many friends and ClearNav afficionados (BB is one of them) that you have an excellent product. I sometimes get beaten by them flying the dreaded Area Task which ClearNav seems to handle beautifully, WinPilot not so much. Maybe in my next glider - but my wife thinks I'm doing just fine in the one I fly, have to land out more!
Herb
Old September 15th 16, 09:45 PM posted to rec.aviation.soaring
Tango Eight
Default OUDIE
Evan Ludeman @ CNi
Herb
Hi Herb,
Thanks for the kind words. Btw, just to clarify (because it'll be counter intuitive to a WP user): the thermal assistant I refer to above is part of our variometer, not the flight computer.
See you at New Castle. I'll do my best to bring some good weather.
-Evan
Old September 16th 16, 01:53 AM posted to rec.aviation.soaring
Sean[_2_]
Default OUDIE
I just updated my 29 panel this spring from an SN10/Ilec vario linked to an Oudie to a new panel with a CN2 with the CN NAV vario (square with red buttons) and a LXNav S10 (new all in one, Nav, Task, Flarm, AHRS, IGC Oogger, etc) as a "backup." Backup is a silly description as the S10 is extremely capable as well in a 57mm package.
I have experience with the butterfly vario, V7, 302, XCSoar, of course the SN10 and several others not worth mentioning.
The CN "Nav" Vario (again, the square one with red buttons) is absolutely incredible. Simple to use, extremely accurate and seems very stable in bubbly, gusty, difficult thermals. I seem to be climbing better and more importantly, running much better. To me this means more accurate netto and speed to fly. It's the best vario I have ever used. I can't say exactly why I believe this, but I believe it. The S10 Vario is also very good, but I favor the cn vario as it integrates well with the CN2 and is very intuitive. I also had a small technical problem with the S10 (one of the very first delivered) that caused me to disregard it and favor the CN vario (which was flawless). So I don't have the same confidence in the LXNav S10 yet other than to say it is really cool and does anything and everything I could ever need. The thermal centering tool is incredible on the CN Vario (and the S10).
The Oudie is OK at best. It MUST be tied into a pressure sensor to be worth anything at all. I was sceptacle of these "full" soaring computers such as the LX9000 and CN2 before switching. But it has been an eye opener for me. Sure there was learning curve. In my case the CN2 is very easy to learn (unlike the LX9000...just ask anyone who uses one, they'll tell you). But once you do master these instrument/flight computers you will have a much more relaxed flight with quicker access to better information.
The SN10 is probably still the best overall simple navigation instrument for the money (I have one for sale, ;-)) although it also can be a challenge to learn and master. But it's ILEC vario (ILEC) leaves something to be desired in comparison to the CN Vario (or the LX).
Hopefully this has some value for someone out there.
Sean
Old September 16th 16, 04:21 AM posted to rec.aviation.soaring
Renny[_2_]
Default OUDIE
Sean
For the record, I agree with Sean 100% on the CN LCD Vario with the thermal assistant. This is the first season I used it and I knew pretty quickly that it was going to be the BEST vario I have ever used. I have been at this sport for awhile, having owned 6 sailplanes and having experience with many varios over 4+ decades, and the CN LCD Vario has proven itself to be truly outstanding. I definitely need all the help I can get and this vario really helps me out especially on those days when those New Mexico thermals are rough and difficult to center. So, if you are in the market, you will not go wrong with this vario.
Thanks - Renny
Old September 16th 16, 04:40 AM posted to rec.aviation.soaring
xcnick
Default OUDIE
I am happy with the CNv. Flew my whole life (40,000 miles) with steam gauges so that is all I have for experience. When I bought my new glider with the 302 I always envied I thought there was something wrong with me for not liking it. I was so confused I turned it off when low. Traded in the 302 after 80 hours of frustration and am happy with the CNv XC right out of the box. I also have the oudie and xcsoar on the phone... meh. Maybe if I flew new places a map would be good.
Old September 16th 16, 03:54 PM posted to rec.aviation.soaring
Matt Johnston
Default OUDIE
Sorry to hijack slightly but to those of you who own an Oudie would
you recommend it? I'm looking to buy one early next year as I need a
navigation unit that I can easily transfer between gliders.
Old September 16th 16, 04:09 PM posted to rec.aviation.soaring
K m
Default OUDIE
Matt,
Ive owned the Oudie since they were first sold in this country. Alot depends on what you are trying to do and what software you are running. Many people purchase the SYM lifetime license (And I think you can get a break on See You if you purchase at the same time).
The "Sunlight" Oudie is popular and works well for people who fly a number of ships.
Old September 17th 16, 01:53 PM posted to rec.aviation.soaring
HGXC[_4_]
Default OUDIE
Yes I would. I have one and like it very much. Its provides me with all the info I need, allows me to customize my screen and is very durable.
I first tried the Dell streak/XC soar but the streak is very vulnerable to breaking with that crazy 32 pin plug right at your knee.
Dennis
Oudie IGC Dave Springford Soaring 4 November 12th 13 08:52 PM
Oudie Peter von Tresckow Soaring 2 December 18th 11 01:31 PM
Oudie and 302 Stephen[_3_] Soaring 9 November 2nd 11 05:07 AM
Oudie Steve Hunt Soaring 2 July 8th 11 12:19 AM
oudie Steve Hunt[_2_] Soaring 0 July 7th 11 08:58 AM
