Cub Driver writes: On Tue, 15 Jun 2004 17:22:32 -0400, (Peter Stickney) wrote: Sea Level 35,000' Notes Vmax Vmax Mmax Vmax Vmax Mmax (Placard Limits, etc.) KTAS KEAS KTAS KEAS F-86H 600 600 0.91 545 304 0.94 Amazing. Is the same true at an intermediate altitude, say 20,000 ft? Pretty much so, depending on the shapes of the thrust and drag curves of that particular airplane. I've got a longer, (and possibly Caffeine-Deprived) reply to John Carrier's reply that goes into more detail. This reverses the WWII piston-engine experience, where the max airspeed was always at higher altitudes (though falling off well below 35,000) That's due to something a bit different. The piston engines on WW 2 airplanes are, of course, all supercharged, so that they produce their maximum power at some point above Sea Level. This means that the thrust produced by the propeller doesn't decay. Propeller Thrust is ((Engine Horsepower/True Airspeed) * Propeller Efficiency) 1,000 HP is 1,000 HP, whether it's at Sea Level, or 20,000'. With a controllable pitch propeller, the prop's going to vary its pitch so that the force exerted on the air is equal to the torque by the engine at some particular RPM. This gives the same thrust for a particular airspeed regardless of altitude - until the engine is at a higher altitude than the supercharger can deliver its full output, and power (torque) drops off. (Torque is proportional to Manifold Pressure. On an airplane with a controllable prop, the prop controls RPM, and the Throttle controls MAP (Torque). Constant speed props use governers to automatically vary the prop pitch to match the RPM commanded by the Pilot or Flight Engineer operating the engines. (Much easier workload)) The drag decreases with the decrease in air pressure as you increase altitude. So, if the power remains constant, and you've got less drag, you can go faster. The rub is that since thrust is proportional to Power / Speed, teh faster you go, the less thrust you have. 1 HP = 3.75 # of thrust at 100 mph, 1.88# of thrust at 200 MPH, 1.35# of thrust at 300 MPH, 0.94# at 400 mph, and 0.75# at 500 mph. This means that using a propeller to fly fast requires bucketloads of horsepower, with the increases in engine size and fuel burn that go with it. When you factor in teh decrease in propeller efficiency as the airflow over teh prop goes supersonic, you can see that props aren't very good for poing anywhere fast. But they do produce buckets of excess thrust at low speed, which is good for takeoff adn climb performance. Indeed, one of the hopes for the jet engine was that speed would increase (and fuel burn decrease) as the planes went higher and higher. Whittle believed that. Or at least I believed that he believed it. http://www.warbirdforum.com/whittle.htm That's becasue a jet produces a fairly constant thrust across teh speed range, instead of constant power. This means that teh faster you go, the more power you have. Since the thrust of a jet decreases more slowly with altitude than the drag is decreasing, you get a higher top speed (discounting transonic effects) the higher you go. Whittle wasn't teh only one who believed it - others did as well. There's a report on the feasibility and tradeoffs of jet proulsion from 1924 on the NACA Tech Reports server: Jet propulsion for airplanes Buckingham, Edgar , National Bureau of Standards (Washington, DC, United States) NACA Report 159, 18 pp. , 1924 This report is a description of a method of propelling airplanes by the reaction of jet propulsion. Air is compressed and mixed with fuel in a combustion chamber, where the mixture burns at constant pressure. The combustion products issue through a nozzle, and the reaction of that of the motor-driven air screw. The computations are outlined and the results given by tables and curves. The relative fuel consumption and weight of machinery for the jet, decrease as the flying speed increases; but at 250 miles per hour the jet would still take about four times as much fuel per thrust horsepower-hour as the air screw, and the power plant would be heavier and much more complicated. Propulsion by the reaction of a simple jet can not compete with air screw propulsion at such flying speeds as are now in prospect. http://naca.larc.nasa.gov/reports/1924/naca-report-159/ Updated/Added to NTRS: 2003-08-19 So - the potentials were understood, and there were people working on the problem for quite a while - notably Dr. Griffith of teh Royal Aircraft Establishment. Griffith was big on producing complicated, baroque designs that were well beyond the ability of anyone in the 1920s and 1930s to build - multispool contrarotating reverse-flow axial compressors, for example. Whittle determined that things could be much, much simpler, and came up with his simple centrifugal designs. They weren't theoretically the most efficient, but they were simple, and tolerant of off-design conditions. When Whittle first presented his ideas to the RAF and the RAE, they consulted their tame expert, Griffith, who advised them that Whittle's ideas were impracticable. Whether this was due to personal jealousy, or Griffith being unable to wrap his mind around the idea that the complicated solutions to the problem that he was working on were unnecessary is something I havent' been able to figure out. With a bit more researchm, there could be a story, there. Whittle adn von Ohain weren't the first to run Gas Turbines, btw. The credit for that goes to Brown-Boverei Engineering in Switzerland, who began building stationary Gas Turbines for use as industrial powerplants in the 1920s. This didn't give them any insight into aircraft Gas Turbines, however. Allis-Chalmers, which was Brown-Boverei's licensee in the U.S. was a notable failure in the Jet Race, completely dropping the ball on their homegrown turbofan development begun in 1941, and in their licensed production of teh DeHavilland Goblin as the J36 later in the War. Luckily, we had GE and Westinghouse on the ball. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
GPS Altitude with WAAS | Phil Verghese | Instrument Flight Rules | 42 | October 5th 03 12:39 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
#1 Jet of World War II | Christopher | Military Aviation | 203 | September 1st 03 03:04 AM |
Aircraft engine certification FAR's | Corky Scott | Home Built | 4 | July 25th 03 06:46 PM |
