Jim's a retired USAF test pilot, so I'm sure understands all the intricacies of flying near Vne.
I'm not an aerodynamicist so here's my lay understanding. A glider's Vne is the true airspeed as indicated IAS at typically 3000m. If I recall, my ASH-26E redline was 146 KIAS which worked out to 160-ish TAS. The chart Schleicher provides for Vne above 3000m drops the IAS to keep the TAS at or below 160. My ASW-27 chart is: 10K 151 knots 16.5K 133 knots 23K 119 knots etc... In the '26 I flew a 100 km triangle in wave between 14 and 18K MSL so limited my IAS to a conservative 120 knots, which I maintained nearly the whole time. The achieved speed for the triangle was a bit over 130 knots. So TAS is your friend even below 18K! If repeating this in the '27 I would again use 120 as a "safe" Vne for below 18K. 5Z On Wednesday, September 21, 2016 at 6:59:10 PM UTC-7, howard banks wrote: Every glider flight manual I studied made it clear that the flight tested limits laid out applied up to 3000 meters ... over that you are relying on a combination of theory, over-design, excessive build over required standards, and it always seemed to me good fortune. I have no idea if such applied to the Arcus M used by Payne. |
2200k at 194.66kph is this a speed record? | joesimmers[_2_] | Soaring | 4 | May 5th 12 04:05 AM |
sailcar speed record | bagmaker | Soaring | 7 | April 1st 09 10:47 PM |
New world speed record: 534 km/h! | [email protected] | Soaring | 8 | September 23rd 06 02:25 PM |
speed record set by scramjet - fair? | Don French | Piloting | 55 | November 28th 04 01:57 PM |
F-106 Speed record questions.... | David E. Powell | Military Aviation | 67 | February 25th 04 06:13 AM |
