AA Butterfly versus CNv LCD wind calculation
Old September 28th 16, 12:48 AM posted to rec.aviation.soaring
Dan Marotta
Default AA Butterfly versus CNv LCD wind calculation
We tried for wave today and all we got was high on the engine. Since I
was in smooth air, I tried pushing over and pulling up and found the
Winter mechanical vario in my Stemme to be very well compensated.
Likewise the CNv was well compensated. Checking its setup, I found that
it is set for electronic compensation, I did not look at the percentage.
On 9/26/2016 4:43 PM, Dan Marotta wrote:
Thanks Evan, I was gonna try that. I already have the TCs set at 0.5
sec. I'll report back if I see any difference.
Dan
On 9/26/2016 12:14 PM, Tango Eight wrote:
On Monday, September 26, 2016 at 1:19:46 PM UTC-4, Dan Marotta wrote:
On 9/26/2016 10:15 AM, Tango Eight wrote:
snip
Mechanical varios don't play well with modern pressure transducer
type varios and should not share TE sources with them.
Evan Ludeman / T8
I have a 57 mm Winter mechanical and a CNvXC connected to the triple
probe in my Stemme. The needles on each track perfectly with each
other.
Which illustrates what goes wrong :-).
The effect of the mechanical vario is to slow the whole system down
to its own speed.
If you are using the triple probe pitot and static for CNv's pitot
and static inputs, and the static source is not shared with any
mechanical instrument (pitot source may be shared with an ASI since
the pitot aneroid volume is small), try setting CNv to "no probe" and
see if you don't like the response of the instrument better. I
suggest setting the audio & pointer time constants to 0.5 sec.
best,
Evan for CNi
Dan, 5J
302 wind calculation AK Soaring 21 April 3rd 10 01:27 PM
302 wind calculation 5Z Soaring 1 March 26th 10 11:56 AM
302 wind calculation Darryl Ramm Soaring 0 March 26th 10 03:04 AM
302 wind calculation AK Soaring 0 March 26th 10 02:47 AM
Vector Wind, Relative Wind calculation C 302/303 [email protected] Soaring 2 December 9th 08 07:23 PM
