It's ironic that the I received an email from the Utah Soaring Association indicating yesterday telling about one of our Grob Astir's had a hard landing a few weeks ago that ripped off the disk brake caliper. The damage inspection found this is not the first time this has happened as the caliper hangs down at the 6 o'clock position. The Utah board is looking at taking it back to the original drum brake design for better hard landing durability.
On Wednesday, September 28, 2016 at 7:37:29 AM UTC-7, John wrote:
It's ironic that the I received an email from the Utah Soaring Association indicating yesterday telling about one of our Grob Astir's had a hard landing a few weeks ago that ripped off the disk brake caliper. The damage inspection found this is not the first time this has happened as the caliper hangs down at the 6 o'clock position. The Utah board is looking at taking it back to the original drum brake design for better hard landing durability. I guess someone didn't read my post from January -- recommending the ten ply tire... and smooooooth landings. Sorry for their troubles. Pilot training issues, usually. More training. I side with Mike O -- leave me all the tools. Then I can choose which to use, or what parts to sacrifice. Cindy B |
At 09:59 28 September 2016, Don Johnstone wrote:
At 06:46 19 February 2016, wrote: Have you tried rebuilding the drum brake? My club used to have a Twin Astir= retractable and the drum - tiny though it looked - always did a fair job o= f stopping the ship. It was strong enough to make rubbing the underside of = the nose on the runway a concern. Very true, the original Grob 103 Twin Astir had no nosewheel so a super efficient brake is not a good idea, unless of course you want to grind off the gel coat, or even worse the underlying structure under the nose. The Grob103 Acro did have a nosewheel and therefore the more efficient disc brake was not a problem. I always wonder if people actually think through the implications of making something "better". Perhaps there was a reason why the original design did not have a super efficient brake. Duct tape can't fix stupid, it can muffle the noise. The Twin Astir Trainer (fixed gear version) came with a standard hydraulic disc brake from the factory. The ones which people are retrofitting are the more numerous retractable gear versions. There was a problem with that disc being too thin and deforming, but TOST put out a retrofit kit to fix that issue last year. I view the extra stopping power of the disc brake as another tool in my toolbox of flight controls. I don't use all of its capabilities under normal conditions, but if a situation occurs where I need that power, I want to be able to access it NOW. For example, if I have a low altitude rope break and am forced into a situation where there is not much room to stop, I (personally) would rather get on the brake hard (even if it means scraping the nose) in order to avoid being forced to make an intentional ground loop (and breaking the tail boom +) to avoid a looming obstacle. I flew professionally for 42 years, and it always grated on me when someone took a useful tool out of my toolbox "for my own good". Whether one is a pilot, cabinet maker, electrician or whatever, one has tools to ply one's trade. Some of those tools will have the capability to kill or maim. It is the responsibility of the OPERATOR to use those provided tools with skill, accuracy and judgement. Don't blame the tool, when the problem is in reality an inept operator.... RO |
On Thursday, September 29, 2016 at 3:15:10 PM UTC+13, Michael Opitz wrote:
At 09:59 28 September 2016, Don Johnstone wrote: At 06:46 19 February 2016, wrote: Have you tried rebuilding the drum brake? My club used to have a Twin Astir= retractable and the drum - tiny though it looked - always did a fair job o= f stopping the ship. It was strong enough to make rubbing the underside of = the nose on the runway a concern. Very true, the original Grob 103 Twin Astir had no nosewheel so a super efficient brake is not a good idea, unless of course you want to grind off the gel coat, or even worse the underlying structure under the nose. The Grob103 Acro did have a nosewheel and therefore the more efficient disc brake was not a problem. I always wonder if people actually think through the implications of making something "better". Perhaps there was a reason why the original design did not have a super efficient brake. Duct tape can't fix stupid, it can muffle the noise. The Twin Astir Trainer (fixed gear version) came with a standard hydraulic disc brake from the factory. The ones which people are retrofitting are the more numerous retractable gear versions. There was a problem with that disc being too thin and deforming, but TOST put out a retrofit kit to fix that issue last year. I view the extra stopping power of the disc brake as another tool in my toolbox of flight controls. I don't use all of its capabilities under normal conditions, but if a situation occurs where I need that power, I want to be able to access it NOW. For example, if I have a low altitude rope break and am forced into a situation where there is not much room to stop, I (personally) would rather get on the brake hard (even if it means scraping the nose) in order to avoid being forced to make an intentional ground loop (and breaking the tail boom +) to avoid a looming obstacle. I flew professionally for 42 years, and it always grated on me when someone took a useful tool out of my toolbox "for my own good". Whether one is a pilot, cabinet maker, electrician or whatever, one has tools to ply one's trade. Some of those tools will have the capability to kill or maim. It is the responsibility of the OPERATOR to use those provided tools with skill, accuracy and judgement. Don't blame the tool, when the problem is in reality an inept operator.... Y'know ... when I learned to fly, we were *taught* to use the nose of the Blanik on the ground for extra braking in an emergency. It's a long time ago, but I seem to recall it may even have been demonstrated. |
At 02:02 29 September 2016, Michael Opitz wrote:
At 09:59 28 September 2016, Don Johnstone wrote: At 06:46 19 February 2016, wrote: Have you tried rebuilding the drum brake? My club used to have a Twin Astir= retractable and the drum - tiny though it looked - always did a fair job o= f stopping the ship. It was strong enough to make rubbing the underside of = the nose on the runway a concern. Very true, the original Grob 103 Twin Astir had no nosewheel so a super efficient brake is not a good idea, unless of course you want to grind off the gel coat, or even worse the underlying structure under the nose. The Grob103 Acro did have a nosewheel and therefore the more efficient disc brake was not a problem. I always wonder if people actually think through the implications of making something "better". Perhaps there was a reason why the original design did not have a super efficient brake. Duct tape can't fix stupid, it can muffle the noise. The Twin Astir Trainer (fixed gear version) came with a standard hydraulic disc brake from the factory. The ones which people are retrofitting are the more numerous retractable gear versions. There was a problem with that disc being too thin and deforming, but TOST put out a retrofit kit to fix that issue last year. I view the extra stopping power of the disc brake as another tool in my toolbox of flight controls. I don't use all of its capabilities under normal conditions, but if a situation occurs where I need that power, want to be able to access it NOW. For example, if I have a low altitude rope break and am forced into a situation where there is not much room to stop, I (personally) would rather get on the brake hard (even if it means scraping the nose) in order to avoid being forced to make an intentional ground loop (and breaking the tail boom +) to avoid a looming obstacle. I flew professionally for 42 years, and it always grated on me when someone took a useful tool out of my toolbox "for my own good". Whether one is a pilot, cabinet maker, electrician or whatever, one has tools to ply one's trade. Some of those tools will have the capability to kill or maim. It is the responsibility of the OPERATOR to use those provided tools with skill, accuracy and judgement. Don't blame the tool, when the problem is in reality an inept operator.... RO I would agree with you IF gliders, especially 2 seat gliders were always flown by pilots experience as you and I. Truth is they are not, they are frequently flown by very inexperienced and sometimes inept pilots, that is the nature of gliding. The wheel brake on a glider is not a mission critical item, unlike a powered aircraft the brakes are not tested before taxiing, in most cases we only find they do not work on landing which is why I never rely on them. I accept a good brake may be best in the situation you describe but that occurs rarely. The risk of damage by a nose over is much greater and more common. One of those cases where the cure is worse than the disease. I do accept that the Twin Astir is very tail heavy and almost impossible to nose down with the OEM brake, not so with a more efficient disc brake. |
On 9/29/2016 6:55 AM, Don Johnstone wrote:
At 02:02 29 September 2016, Michael Opitz wrote: At 09:59 28 September 2016, Don Johnstone wrote: Snip... Very true, the original Grob 103 Twin Astir had no nosewheel so a super efficient brake is not a good idea, unless of course you want to grind off the gel coat, or even worse the underlying structure under the nose. The Grob103 Acro did have a nosewheel and therefore the more efficient disc brake was not a problem. I always wonder if people actually think through the implications of making something "better". Perhaps there was a reason why the original design did not have a super efficient brake. Duct tape can't fix stupid, it can muffle the noise. Snip... I view the extra stopping power of the disc brake as another tool in my toolbox of flight controls. I don't use all of its capabilities under normal conditions, but if a situation occurs where I need that power, want to be able to access it NOW. For example, if I have a low altitude rope break and am forced into a situation where there is not much room to stop, I (personally) would rather get on the brake hard (even if it means scraping the nose) in order to avoid being forced to make an intentional ground loop (and breaking the tail boom +) to avoid a looming obstacle. I flew professionally for 42 years, and it always grated on me when someone took a useful tool out of my toolbox "for my own good". Whether one is a pilot, cabinet maker, electrician or whatever, one has tools to ply one's trade. Some of those tools will have the capability to kill or maim. It is the responsibility of the OPERATOR to use those provided tools with skill, accuracy and judgement. Don't blame the tool, when the problem is in reality an inept operator.... RO I would agree with you IF gliders, especially 2 seat gliders were always flown by pilots experience as you and I. Truth is they are not, they are frequently flown by very inexperienced and sometimes inept pilots, that is the nature of gliding. The wheel brake on a glider is not a mission critical item, unlike a powered aircraft the brakes are not tested before taxiing, in most cases we only find they do not work on landing which is why I never rely on them. I accept a good brake may be best in the situation you describe but that occurs rarely. The risk of damage by a nose over is much greater and more common. One of those cases where the cure is worse than the disease. I do accept that the Twin Astir is very tail heavy and almost impossible to nose down with the OEM brake, not so with a more efficient disc brake. Hmmm...Izziss (i.e. inexperience/incompetency/inattention/etc.) why anti-skid brake technology on motor vehicles has become so popular? Would it not be simpler/cheaper/better to have weaker brakes on motor vehicles? Ah, for the good ol' days of drum brakes all around and no power assist. Thanks for helping me belatedly realize weak, fading brakes on my first tow vehicle were actually a safety *asset!* ![]() In this particular "religious argument" I cast my vote for "overly powerful," easily modulatable, glider wheel brakes. My 2nd high-performance single seater (purchased w. me having a whopping 200 hours stick time) actually had this combination...and some 39 years later I still have difficulty imagining anything better. Bob W. |
I learned the hard way that automobile antiskid brakes do not shorten braking distance. They only improve handling during heavy braking.
Paul A. Jupiter, FL Treasure Coast Soaring |
.... And 4-wheel-drive simply gets you in deeper before you get stuck.
I think I'll slink off to my safe place now and hide so I don't feel uncomfortable any more. On 9/29/2016 11:33 AM, Paul Agnew wrote: I learned the hard way that automobile antiskid brakes do not shorten braking distance. They only improve handling during heavy braking. Paul A. Jupiter, FL Treasure Coast Soaring -- Dan, 5J |
![]() The Twin Astir Trainer (fixed gear version) came with a standard hydraulic disc brake from the factory. The ones which people are retrofitting are the more numerous retractable gear versions. There was a problem with that disc being too thin and deforming, but TOST put out a retrofit kit to fix that issue last year. I view the extra stopping power of the disc brake as another tool in my toolbox of flight controls. I don't use all of its capabilities unde normal conditions, but if a situation occurs where I need that power, want to be able to access it NOW. For example, if I have a low altitude rope break and am forced into a situation where there is not much room to stop, I (personally) would rather get on the brake hard (even if it means scraping the nose) in order to avoid being forced to make an intentional ground loop (and breaking the tail boom +) to avoid a looming obstacle. I flew professionally for 42 years, and it always grated on me when someone took a useful tool out of my toolbox "for my own good". Whether one is a pilot, cabinet maker, electrician or whatever, one has tools to ply one's trade. Some of those tools will have the capability to kill or maim. It is the responsibility of the OPERATOR to use those provided tools with skill, accuracy and judgement. Don't blame the tool, when the problem is in reality an inept operator.... RO I would agree with you IF gliders, especially 2 seat gliders were alway flown by pilots experience as you and I. Truth is they are not, they ar frequently flown by very inexperienced and sometimes inept pilots, that i the nature of gliding. The wheel brake on a glider is not a missio critical item, unlike a powered aircraft the brakes are not tested befor taxiing, in most cases we only find they do not work on landing which i why I never rely on them. I accept a good brake may be best in th situation you describe but that occurs rarely. The risk of damage by a nos over is much greater and more common. One of those cases where the cure i worse than the disease. I do accept that the Twin Astir is very tail heav and almost impossible to nose down with the OEM brake, not so with a mor efficient disc brake. The Twin Astir was the Duo Discus of its day. Training was done in K-7's and K-13's, and the inept pilots were not allowed to fly the "sacred cow" higher performance Twin Astirs. The Twins were used for the more experienced pilots enjoyment, and to teach XC. This is evident in how the two Twin Astirs which our club operates were kept in absolute pristine condition for 30+ years. The Twin II was designed for training, but had a low max gross weight, and a lower payload than the Twin Astir. Fast forward a few decades, and most of the Twin II's have been crashed and repaired to the point that the seat load is no longer very usable (except in England where you have a higher gross weight agreement with Grob). So now, due to prices and seat loads being what they are, people are starting to try and use the Twin Astir for primary training. There are trade-offs because this glider wasn't designed with this purpose in mind. Ground handling is one trade- off, and the wheel brake is another. To your point of a low altitude rope break being rare, well we had a towplane engine failure at about 50' three years ago. The glider wound up in the bushes off the end of the runway with significant damage. These scenarios do happen. The more likely scenario in the Northeast USA is that the inept pilot gets low too far away from home, and then has to land off airport in one of our small hilly fields. In that case, I would still want the inept pilot to have a strong wheel brake to stand the glider on its nose if he/she has to. The philosophy here is that even though the field may look good, one stops the glider right away for fear of ripping the gear off due to falling into an unseen gopher hole, etc. Most fields here are short enough that there is usually no question about the need to get it stopped immediately anyway. If they are going to be allowed to fly a Twin Astir, the inept people need to be taught not to yank on the dive brake handle (during a normal landing) as though they have a death wish... Obviously, you people can operate your gliders as you see fit. I had thought of using the automotive technology argument, but someone else already brought that up. We have chosen to upgrade our equipment to the newer technology, (that most new gliders come equipped with) and are happily operating our Twins with it. If you want to take a useful tool out of your pilot's toolbox, that is your decision. I will keep that useful tool in mine though... RO |
For sale: Grob Twin Astir | [email protected] | Soaring | 3 | April 8th 14 05:29 PM |
Grob 103 Twin Astir tailwheel axle? | Roger Worden[_2_] | Soaring | 3 | June 26th 13 05:27 AM |
Tailwheel For GROB Twin Astir | Mike J. | Soaring | 2 | December 3rd 12 04:49 PM |
Grob Twin Astir Tailshaking | Peter | Soaring | 11 | January 14th 07 11:54 PM |
Grob Twin Astir 1 Manual / Flughandbuch | Sebastian Schroeter | Soaring | 2 | June 14th 04 11:41 AM |
