First flight of Jet Arcus
Old September 29th 16, 05:56 PM posted to rec.aviation.soaring
Jim White[_3_]
Default First flight of Jet Arcus
At 00:40 29 September 2016, wrote:
Bob Carlton (
www.desertaerospace.com) made the first flight of the Jet
powe=
red Schempp-Hirth Arcus (N887DT) today from Moriarty Airport (0E0) in New
M=
exico. Launch conditions at 0938 MDT were 3-5 kt. N winds. Field
elevation
is 6,200 ft. MSL. Density Altitude was 7,800 ft. Bob flew solo, as per
Operating Limitations specified by the FAA for Phase 1 flight tests.
Initial climb was from Takeoff (6,200 ft. MSL) to 10,000 ft. MSL at an
aver=
age speed of 95 kts. TAS. Time from liftoff to 10,000 ft. MSL was 6
minutes=
, 10 seconds, for an average climb rate of a bit over 6 kts.
Bob flew for just under an hour, shutting down the engine in flight,
retrac=
ting it into the fuselage and then extending it again for restart. After
so=
me cruise performance checks at various speeds, he again shut the engine
do=
wn and stowed it for landing as a conventional glider.
All initial flight parameters were met, so now it is on to the next four
ho=
urs of Phase 1 flight to gather more performance data, explore the flight
e=
nvelope (including maneuvers) and gain familiarity with the systems
before
turning it over to the customer.
(This glider was on display at the 2016 SSA Convention in Greenville, SC)
Is this the PSR unit or a US development?
Old September 29th 16, 07:27 PM posted to rec.aviation.soaring
JS
One look at who is test flying it would be a dead giveaway!
http://www.desertaerospace.com/about-us
http://www.pbsvb.com/customer-indust...urbojet-engine
I looked at the PSR retrofit a couple of years ago and thought it of limited use in mountainous terrain. The Arcus will be operating in mountainous terrain.
Old September 29th 16, 08:29 PM posted to rec.aviation.soaring
If I did the math right, roughly 5 gallons for a launch from 6k to 10k. Just need capacity for 10 gallons.. ideally optional up to 15 gallons and its a SLMG with good range for self retrieve.
Old September 30th 16, 12:42 AM posted to rec.aviation.soaring
waremark
Names not familiar to me. Is there any chance that this could ever be a certified aircraft in Europe?
Old September 30th 16, 12:57 AM posted to rec.aviation.soaring
On Thursday, September 29, 2016 at 1:00:06 PM UTC-4, Jim White wrote:
Bob Carlton (www.desertaerospace.com) made the first flight of the Jet
powe=
M=
elevation
YouTube with audio please. Will it fit DB?
Old September 30th 16, 01:44 AM posted to rec.aviation.soaring
Sorry, but I deleted the original post. Apparently I jumped the gun on making this public. As soon as more data are collected and some permissions are granted, we will do a press release with videos, photos and actual analysis of climb and cruise performance, along with fuel consumption numbers.
Old September 30th 16, 02:38 AM posted to rec.aviation.soaring
Darryl Ramm
It's USENET, you can't delete anything... (Google Groups may give you the illusion you can, but you can't).
Arcus owners not monitoring the Arcus newsgroup... Dave Nadler Soaring 14 August 30th 16 05:54 PM
Arcus E (electric) first flight ! Dave Nadler Soaring 5 September 22nd 10 01:13 PM
Arcus M maiden flight ventus2[_2_] Soaring 1 July 4th 10 03:36 PM
Maiden flight of the Arcus Nick Olson[_2_] Soaring 30 April 21st 09 12:09 AM
[PICTURES] Arcus 1st flight fred Soaring 0 April 8th 09 06:38 PM
