"John Carrier" writes: After some research concerning those aircraft that were decidedly subsonic in level flight (no pushover from altitude to gain greater speed), it would appear mach effect is the overriding concern. The last low altitude record before the transition to high (F-100, with several ... F-86, F-4D ... previous to that) were all done at the Salton Sea. Hi temp (higher TAS for mach) and low altitude (-227 MSL), delayed transonic drag rise. Quite so - they discovered that a pushover into teh course for teh records didn't make any difference - the drag increase was so great that it just didn't matter. We weren't teh only ones to use this - The Brits made a record attempt with a slightly modified Hunter over the Dead Sea. IIRC. That would be the only Speed Record set below Sea Level. The PsubS bulge doesn't occur until you get into the cleraly supersonic designs. Then it behooves a "low altitude" record to occur as high above MSL as possible. Hence the sageburner and later Greenamyer efforts in the high desert (less IAS, more TAS, 988 mph for Darryl ... great film by the way). I agree. The biggest deal there is that an afterburning turbojet really denifits from Ram Compressionwhich gets really large above Mach 1. You get a lot more thrust, without the penalty of more Ram Drag. Bottom line, in our running discussion, I now find your argument compelling. I was incorrect. I don't think that we were disagreeing on all that much, really. Sometimes in my efforts to put things into non-technical terms, I over-simplify. If you think I'm off, or not explaining properly, please do jump in with a correction or an improved explanation. Thank you for the questions, and helping me to improve my focus. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
records didn't make any difference - the drag increase was so great that it just didn't matter. We weren't teh only ones to use this - The Brits made a record attempt with a slightly modified Hunter over the Dead Sea. IIRC. That would be the only Speed Record set below Sea Level. Actually, pushovers not allowed. The aircraft was prohibited from exceeding 300 meters altitude for the duration of the flight and had to be at 100 meters or less for the 4 passes on the 3-5 km course. Salton Sea is slightly below sea level if my sources are correct. R / John |
GPS Altitude with WAAS | Phil Verghese | Instrument Flight Rules | 42 | October 5th 03 12:39 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
#1 Jet of World War II | Christopher | Military Aviation | 203 | September 1st 03 03:04 AM |
Aircraft engine certification FAR's | Corky Scott | Home Built | 4 | July 25th 03 06:46 PM |
