Trailer weight distribution demonstration
Old October 16th 16, 03:33 PM posted to rec.aviation.soaring
Default Trailer weight distribution demonstration
Higher mileage Jeeps are also know for the "Jeep death shake/weave" on their own, even without a trailer. Not a good choice unless worn suspension bits are replaced.
Yes, we owned a 1998 Cherokee Sport for a couple years, lots of bottom bits were replaced.
High CG, tall tires, worn bits, shortish wheel base for its height.
A good tow vehicle should be sorta heavy, long, low (think 60's & 70's US station wagons). Yes, other vehicles can tow (I crewed, about 1979, driving a VW Beetle towing a plywood ASW-15 trailer, it had a hard time doing 55MPH on flat ground.....empty!), but some vehicles have an easier time with ANY trailer.
Old October 16th 16, 11:58 PM posted to rec.aviation.soaring
JS
Is there much point in comparing worn out cars? In my case the boxy '87 Cherokee was bought new, and its first road trip was a 4-day drive to pick up an LS4.
Took a lot of messing around with the trailer and car to find the real fix.
Old October 17th 16, 01:11 AM posted to rec.aviation.soaring
kirk.stant
On Sunday, October 16, 2016 at 9:33:32 AM UTC-5, Charlie M. (UH & 002 owner/pilot) wrote:
You can tow with a Jeep Cherokee, but you have to have everything setup correctly: upmarket tires at max PSI, air shocks on rear axle, proper tongue weight, trailer tires at correct pressure and type. With that, my old 1997 Cherokee Sport with 230K miles tows fine up to 70 mph (15m Cobra with trailer tires). But it took a while to sort it out! (and the brakes are marginal going down long hills...)
But a longbed pickup - or an RV? Can't even tell there is a trailer behind....
Now when you have to pull that trailer out of the middle of a huge disced field in the middle of nowhere at 2 AM - that 4WD Cherokee is nice to have around, warts and all. Which is why it's still in my garage.
Horses for courses, is the saying I believe.
Kirk
66
Trailer weight distribution demonstration bumper[_4_] Soaring 0 October 5th 16 07:54 AM
weight of an Eberle trailer raymond herr Soaring 3 November 27th 11 06:20 PM
Trailer Weight rlovinggood Soaring 8 November 1st 07 12:22 AM
747 weight distribution Robin General Aviation 25 June 22nd 05 03:53 AM
