If you use a magnetic reed switch, there's some more things to consider.
First you'll need to determine if the gear warning sounds when the switch is open, or closed. Both types of switch are available, with magnet present a switch may be closed (the most common type of reed switch) or it may be open with the magnet present (there being a tiny biasing magnet within the switch that closes the reed when the external magnet is moved away. Then there are "wide gap" reed switches too. These are magnet polarity sensitive, so the external magnet needs to be positioned so the correct pole approaches the switch (these switches will still operate if the external magnet is positioned incorrectly - they will just revert to a very small gap). If the magnet is to be mounted on steel (as in tubing etc.) then better performance will be had if the magnet is not mounted directly to the steel. |
ASW-20C Gear Warning Switch Placement | Jim Kellett | Soaring | 3 | May 16th 09 01:20 AM |
Stall warning switch for Cessna 206? | [email protected] | Owning | 1 | February 20th 07 09:16 PM |
Gear Warning | Gadget Guy | Soaring | 118 | November 30th 05 10:43 PM |
Gear Warning | Gordon Schubert | Soaring | 11 | November 22nd 05 03:27 AM |
gear warning plus | K.P. Termaat | Soaring | 0 | September 8th 03 08:33 AM |
