One would think if the blow holes did not add much a pencil pusher at the factory would realize they could have lots of man hours ($) by just using dimple tape.
On Monday, October 24, 2016 at 11:30:06 AM UTC-7, soarin wrote: At 16:50 24 October 2016, Jim White wrote: Herr Waibel has been quoted as saying of the ASW27 that "there is a 50/5 chance that the blow holes improve performance by 1/2 point". Possibl apocryphal. Easy to clean with a piece of copper wire and a vacuum cleane but tedious beyond belief. jim I once got a DG300 in for insp and found that the blow holes on one wing were inop (apparently the seal of the internal blow hole channel had failed). The factory said a fix was problematic and to go ahead and install dimple tape as it works just as well. No telling how many years the glider flew with one wing turbulated and the other not. The owner was oblivious to any degradation in handling or performance before and after installing the dimple tape. ME |
On Monday, October 24, 2016 at 1:49:18 PM UTC-5, Jonathan St. Cloud wrote:
One would think if the blow holes did not add much a pencil pusher at the factory would realize they could have lots of man hours ($) by just using dimple tape. Another claimed, but I don't know if it was ever proven, benefit of the blow holes is that even if they are behind the leading edge of the laminar bubble, they can still "blow out far enough to burst the bubble and get the advantage of not having the high drag, laminar bubble" whereas, turbulator tape inside the bubble does nothing at all for you. It is all about how much are you willing to do to get that last half percent. |
On Monday, October 24, 2016 at 10:14:25 PM UTC+3, Steve Leonard wrote:
On Monday, October 24, 2016 at 1:49:18 PM UTC-5, Jonathan St. Cloud wrote: One would think if the blow holes did not add much a pencil pusher at the factory would realize they could have lots of man hours ($) by just using dimple tape. Another claimed, but I don't know if it was ever proven, benefit of the blow holes is that even if they are behind the leading edge of the laminar bubble, they can still "blow out far enough to burst the bubble and get the advantage of not having the high drag, laminar bubble" whereas, turbulator tape inside the bubble does nothing at all for you. It is all about how much are you willing to do to get that last half percent. Half a percent? One minute on a three hour race? Plenty are won and lost by less than that. It won't make any meaningful difference to whether you can stay up, or even whether you can complete a task. |
On Monday, October 24, 2016 at 3:14:25 PM UTC-4, Steve Leonard wrote:
On Monday, October 24, 2016 at 1:49:18 PM UTC-5, Jonathan St. Cloud wrote: One would think if the blow holes did not add much a pencil pusher at the factory would realize they could have lots of man hours ($) by just using dimple tape. Another claimed, but I don't know if it was ever proven, benefit of the blow holes is that even if they are behind the leading edge of the laminar bubble, they can still "blow out far enough to burst the bubble and get the advantage of not having the high drag, laminar bubble" whereas, turbulator tape inside the bubble does nothing at all for you. It is all about how much are you willing to do to get that last half percent. If the airfoil is designed to use blowing, the gains may well be more than that. Listen to the noise on a '27 when in the wrong flap position and you know something is going on. UH |
Thanks Steve, I do remember now reading about that. Makes sitting down with a tiny drill bit and a six pack seem worth it.
On Monday, October 24, 2016 at 12:14:25 PM UTC-7, Steve Leonard wrote: On Monday, October 24, 2016 at 1:49:18 PM UTC-5, Jonathan St. Cloud wrote: One would think if the blow holes did not add much a pencil pusher at the factory would realize they could have lots of man hours ($) by just using dimple tape. Another claimed, but I don't know if it was ever proven, benefit of the blow holes is that even if they are behind the leading edge of the laminar bubble, they can still "blow out far enough to burst the bubble and get the advantage of not having the high drag, laminar bubble" whereas, turbulator tape inside the bubble does nothing at all for you. It is all about how much are you willing to do to get that last half percent. |
On Monday, October 24, 2016 at 2:16:19 PM UTC-6, Jonathan St. Cloud wrote:
Thanks Steve, I do remember now reading about that. Makes sitting down with a tiny drill bit and a six pack seem worth it. On Monday, October 24, 2016 at 12:14:25 PM UTC-7, Steve Leonard wrote: On Monday, October 24, 2016 at 1:49:18 PM UTC-5, Jonathan St. Cloud wrote: One would think if the blow holes did not add much a pencil pusher at the factory would realize they could have lots of man hours ($) by just using dimple tape. Another claimed, but I don't know if it was ever proven, benefit of the blow holes is that even if they are behind the leading edge of the laminar bubble, they can still "blow out far enough to burst the bubble and get the advantage of not having the high drag, laminar bubble" whereas, turbulator tape inside the bubble does nothing at all for you. It is all about how much are you willing to do to get that last half percent. I get these on Ebay. Works good on my 29. I find that inflight dust and bugs do get in and I do clean them several times a year. If you drop them, they do break rather easily. ..024" 0.60mm #73 - Five Carbide Drill Bits - Best. Tom #711. |
Jonathan St. Cloud wrote on 10/24/2016 11:49 AM:
One would think if the blow holes did not add much a pencil pusher at the factory would realize they could have lots of man hours ($) by just using dimple tape. Schleicher has used blow holes from at least 1984 on the ASW20C and B. The holes were thin metal tubes on the wing bottom, and looked like they might be costly. My ASH 26 E does not use the tubes on the wings; instead, the blow holes are drilled into the the bottom of the flaps and ailerons. That's not on the wing, but on the control surface! My guess is the boundary layer is too thick on the control surfaces for zig zag tape to work, unless it was stacked two or three high. Drilled holes are probably cheap enough, and installing the tiny NACA scoops is easy, too. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 - "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm http://soaringsafety.org/prevention/...anes-2014A.pdf |
On Wednesday, 26 October 2016 03:26:21 UTC+3, Eric Greenwell wrote:
My guess is the boundary layer is too thick on the control surfaces for zig zag tape to work, unless it was stacked two or three high. If the function of blowholes is to trip laminar flow into turbulent, how can laminar flow be "thick"? |
krasw wrote on 10/26/2016 12:33 AM:
On Wednesday, 26 October 2016 03:26:21 UTC+3, Eric Greenwell wrote: My guess is the boundary layer is too thick on the control surfaces for zig zag tape to work, unless it was stacked two or three high. If the function of blowholes is to trip laminar flow into turbulent, how can laminar flow be "thick"? I'm not sure what you are asking, but in general, laminar flow has a thicker boundary layer than turbulent flow, and when it grows too thick, it separates from the airfoil into a "laminar separation bubble" that is high drag. The cure is to trip the laminar flow into turbulent flow, which "sticks" better to the airflow. Schleicher uses two layers of zig-zag tape just in front of the NACA inlets that pressurize the control surface blowholes. A single layer is not thick enough to trip the laminar flow that far back on the airfoil. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 - "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm http://soaringsafety.org/prevention/...anes-2014A.pdf |
On Wednesday, 26 October 2016 21:20:09 UTC+3, Eric Greenwell wrote:
Schleicher uses two layers of zig-zag tape just in front of the NACA inlets that pressurize the control surface blowholes. A single layer is not thick enough to trip the laminar flow that far back on the airfoil. Ok. Blow holes seems amazingly expensive and complicated construction when compared to simple tape. I have very hard time believing that Waibel, Heide et al. did this without any benefits. I have to confess that I have more believe in their collective aerodynamic wisdom than this groups', no doubt impressive it might also be. |
Another Blow to Airbus | a[_3_] | Piloting | 52 | August 19th 10 10:49 AM |
To blow or not to blow... | Dallas | Piloting | 50 | February 15th 08 12:57 PM |
oil blow out IO-360 | Robert M. Gary | Piloting | 18 | July 17th 06 04:44 PM |
oil blow out IO-360 | Robert M. Gary | Owning | 18 | July 17th 06 04:44 PM |
When Poorboys drill holes ...was: Drilling holes in steel tubing | wright1902glider | Home Built | 4 | November 4th 05 01:19 AM |
