World Contest - 15m class
Old November 23rd 16, 05:29 PM posted to rec.aviation.soaring
krasw
Default World Contest - 15m class
On Wednesday, 23 November 2016 18:16:58 UTC+2, Sean wrote:
The 26 is a beautiful glider so at least they have good taste.
Agreed. No matter what the story is (there is always two sides of coin), AS did not willingly donate the aerodynamic shape of '26 fuselage to competing manufacturer.
So, the ASG29 was not truly new when it was released ten years ago. My registration actually says ASG 27-18
That is just paperwork. Factory has to pay annually to EASA for every type-certificate data sheet it owns. Schleicher has over 20 of these, Airbus only four. So they decided to use '27 data sheet for '29. Sure it inherits a lot from '27, but it is still different animal. I think it was 29 and 18m tips that revealed the full potential of Waibel's original design.
Today, SH designed what is essentially a "new wing" for the V2 and aptly calls it V3! Ta da! The wing is much thinner than the V2s and is intended to run "extremely well" compared to the V2 based on contest flying behavior research. But will it climb effectively in weaker conditions? The same fuselage as the V2 appears to have been used for the V3. This calls into question how large the improvement "can be" as the V2 was already a step behind the 29 and JS1 in most conditions. The V2 fuselage is, obviously, VERY FAT (lots of wetted area) and therefore so is the V3 fuselage. Results of the V3 design strategy are still largely unknown.
Using same fuselage for different types is quite normal. LS1-f/LS6/LS7/LS8/LS10, ASW24/27/28/ASG29, Ventus a/2a/3a/Discus a/2a, ASH26/JS1 etc. I think the Ventus 3 has flown only with a-cockpit, which has lowest wetted area of anything because it is so small. You are confusing Schempp's big b/c-model fuselage with small a-model. Your speculation about V3 wing is based on what exactly?
Old November 23rd 16, 06:30 PM posted to rec.aviation.soaring
Bruce Hoult
The same canopy fits a mid 1970s Janus and a modern Duo Discus!
Old November 24th 16, 03:55 PM posted to rec.aviation.soaring
Sean[_2_]
The Ventus 3 is not represented yet on the Schempp Hirth website...
https://www.schempp-hirth.com/en.html
Interesting.
The general design brief for the V3 (wing only) is, therefore, not well marketed (or even formally published) although I suspect that a purchase of the SH presentation from the recent SSA convention from 'Wings and Wheels' would discuss the V3 design brief in great detail. Take a look at DVD #14 he http://wingsandwheels.com/pilot-supp...tion-dvd..html
It essentially goes like this: "by studying flight traces (glide/climb ratios, speeds, climb rates, etc) from actual competition flights, they believe the current airfoils are not optimized (essentially to thick, too high drag) so the adopted a new airfoil (thinner essentially) optimized for better high speed glide performance and (likely) slightly less performance in climb. In other words they cite that competition gliders are flying faster than optimum (for their current V2 airfoils) and climbing less that predicted.. So they have built a new wing optimized for the speeds and climb percentages that are actually being flown in real competition."
This design strategy is well known among the SH community and is the basis for the arguement that the V3 will have exceptional performance in competition. It has also resulted in a large book of pre-orders.
We shall see the results of the new wing shortly.
Sean
Old November 24th 16, 04:50 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Interesting that the Quintus is listed on their web site, even after they updated it last year. The Quintus is not in production and since SH never went through any of the certification process they cannot build any more of the quintus, too bad the world needs another true open class gliders with long wings.
Interesting.
Old November 24th 16, 05:21 PM posted to rec.aviation.soaring
Tom Kelley #711
Interesting.
The general design brief for the V3 (wing only) is, therefore, not well marketed (or even formally published) although I suspect that a purchase of the SH presentation from the recent SSA convention from 'Wings and Wheels' would discuss the V3 design brief in great detail. Take a look at DVD #14 he http://wingsandwheels.com/pilot-supp...ntion-dvd.html
It essentially goes like this: "by studying flight traces (glide/climb ratios, speeds, climb rates, etc) from actual competition flights, they believe the current airfoils are not optimized (essentially to thick, too high drag) so the adopted a new airfoil (thinner essentially) optimized for better high speed glide performance and (likely) slightly less performance in climb. In other words they cite that competition gliders are flying faster than optimum (for their current V2 airfoils) and climbing less that predicted. So they have built a new wing optimized for the speeds and climb percentages that are actually being flown in real competition."
Sean
Well, the V3 has already been raced. UK 18 Meter Nationals Aug 20 thru 26th..
Steve Jones is one of the best.
I cut this link(may not work) but full results are here.
http://www.soaringspot.com/en_gb/tibenham-18m-.
1 565 Brian Birlison ASG 29E 1,918
2 80 Andy Davis JS1c Evo 1,915
3 E1 Russell Cheetham JS1c Evo 1,822
4 E11 Stephen Ell ASG 29E 1,812
5 10 Gary Stingemore ASG 29E 1,806
6 N1 Peter Harvey JS1c 1,763
7 601 Tim Jenkinson ASG29E 1,752
8 9 Rory Ellis ASG 29E 1,695
9 3V Steve Jones Ventus 3 1,681
10 XS Richard Browne JS1c 1,629
Bet. Tom #711.
Old November 24th 16, 05:56 PM posted to rec.aviation.soaring
Sean[_2_]
Interesting Tom. Schempp Hirth would have been all over these results (social media, etc) if they were favorable. News of the V3 has been fairly difficult to find. They probably still have a bit of tuning left to do. Let's hope, for their sake, the glider ends up performing better than that.
Old November 28th 16, 08:42 PM posted to rec.aviation.soaring
ND
let's not forget that the pilot is a big factor in all of this and that he could have f@#$%'d up... it's not like we haven't all done that...
Also, in speaking with those guys at the convention they mentioned not wanting to race the V3 because of the temporary restricted VNE imposed because of certification stuff. not sure if that was a factor or not, but they at least made comments about skewed perception. I am interested to see how it performs as well.
Old November 24th 16, 06:02 PM posted to rec.aviation.soaring
Sean[_2_]
Looks like this was a really weak comment test. Only 1900 points in 5 days. But weak is what worries me about the V3
http://www.soaringspot.com/en_gb/tib...-18m-nationals
Old November 25th 16, 04:07 AM posted to rec.aviation.soaring
Renny[_2_]
Interesting.
Sean
Bet. Tom #711.
A Ventus 3T competed at the FAI Sailplane Grand Prix in Musbach Germany in August 2016. The Ventus 3T, flown by Mario Kiessling, finished in 3rd place out of 19 competitors. Here's the link to the results:
http://www.sgp.aero/germany2016/resu...ontestID=16082
We should know even more on the performance of the Ventus 3 after the WGCs in Benalla in January. There will be 7 Ventus 3s competing in the 18 meter class...Thanks!
Old November 25th 16, 04:11 PM posted to rec.aviation.soaring
Sean[_2_]
Yep. That was a much stronger contest. The other contest was weaker (like east coast USA) and it clearly struggled.
The 29 won both events. Hmmm. One trick pony?
Potential Club Class (US Sports Class) World Team Selection Policy Changes John Godfrey (QT)[_2_] Soaring 84 September 27th 10 08:03 PM
Potential Club Class (US Sports Class) World Team SelectionPolicy Changes Andy[_10_] Soaring 0 September 19th 10 10:33 PM
world class contest [email protected] Soaring 0 July 23rd 08 05:38 AM
World Class PW-5 Contest at Marfa, TX Burt Compton - Marfa Soaring 13 June 22nd 06 07:00 PM
Region 7 contest attracts former Open Class World Champion Rich Carlson Soaring 2 May 14th 04 06:04 AM
