If you use external power you do not need batteries in the Portable Powerflarm.
If you do use batteries please read the following. Rechargeable internal Batteries The device features an internal NiMH battery charger only active when the device is turned off. When the device is turned off and electrically connected to the vehicle or aircraft battery (either via “Power” socket or power pins on the RJ45 socket), inserted batteries will be charged if the ambient temperature lies within the allowed range for charging NiMH batteries. If non-rechargeable batteries are fitted to the device, never connect your device to an external power source (e.g. aircraft or vehicle battery)! The internal batteries may only be charged if the device is resting on a non-flammable, dry base. When the device is being recharged, never allow it to remain unsupervised. The integrated charging circuit will only charge batteries at an ambient temperature of up to about 40 °C (104 °F). If possible, charge your batteries in a cool, dry environment. This is all in the manual. Richard www.craggyaero.com |
Power for the Portable Powerflarm.
Ensure any external power source is only connected in case no or only rechargeable batteries are in the device. External power might damage non-rechargeable batteries (risk of leakage). Supplied power must be 12 V DC nominal at 500mA (between 8V and 27V DC, 24V DC nominal may require an additional adapter). This power socket mates with a PP-012 connector (DigiKey part# CP-012-ND or power can be supplied thru the RJ45 port. This is all in the manual. Richard www.craggyaero.com |
Richard,
You are the first person to acknowledge the possibility of external power which I've stated over and over again. I inserted weak rechargeables simply to generate a log file at home. To repeat for the last time - the PF Portable is powered externally via the ship's DC bus in practice and, with external power it does not find any satellites. I assure everyone, I've read the manual over and over. I've used screws considerably shorter than the 10 mm maximum stated in the manual. And, for the last time, I've run the unit with external power, rechargeable batteries, and alkaline batteries and it still does not find any satellites. Maybe I can find an external GPS antenna and see if it'll work that way. I emailed Flarm support on Friday but have had no response. I'll try again... On 11/27/2016 6:28 PM, Richard wrote: If you use external power you do not need batteries in the Portable Powerflarm. If you do use batteries please read the following. Rechargeable internal Batteries The device features an internal NiMH battery charger only active when the device is turned off. When the device is turned off and electrically connected to the vehicle or aircraft battery (either via “Power” socket or power pins on the RJ45 socket), inserted batteries will be charged if the ambient temperature lies within the allowed range for charging NiMH batteries. If non-rechargeable batteries are fitted to the device, never connect your device to an external power source (e.g. aircraft or vehicle battery)! The internal batteries may only be charged if the device is resting on a non-flammable, dry base. When the device is being recharged, never allow it to remain unsupervised. The integrated charging circuit will only charge batteries at an ambient temperature of up to about 40 °C (104 °F). If possible, charge your batteries in a cool, dry environment. This is all in the manual. Richard www.craggyaero.com -- Dan, 5J |
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie | Michael Marshall[_2_] | Soaring | 3 | April 10th 16 04:13 AM |
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie | Michael Marshall[_2_] | Soaring | 0 | April 8th 16 08:57 PM |
Information for all users of Flarm, OEM FLARM supplier and Flarm PowerFlarm | [email protected] | Soaring | 28 | March 12th 16 04:31 AM |
Flarm IGC files on non-IGC certified Flarm? | Movses | Soaring | 21 | March 16th 15 09:59 PM |
Flarm in the US | Steve Freeman | Soaring | 163 | August 15th 10 12:12 AM |
