Thanks, Tim, but I don't think so. I was shutting down the unit with
the knob when those lines were written. When I have it externally powered for an hour it still does not receive satellites. And thanks for taking the time to review the log. Dan On 11/27/2016 3:42 PM, Tim Newport-Peace wrote: Dan, I am not familiar with the log file, but the last lines of the log file read: 00336.753 ERROR Insufficient supply voltage, shutting down 00336.754 ERROR Battery type: alkaline 00336.754 ERROR Battery voltage: 4.28 00336.755 ERROR External supply voltage: 0.00 Could this be a clue? Best regards, Tim. -- Dan, 5J |
On Mon, 28 Nov 2016 09:15:15 -0700, Dan Marotta wrote:
Thanks, Tim, but I don't think so. I was shutting down the unit with the knob when those lines were written. When I have it externally powered for an hour it still does not receive satellites. And thanks for taking the time to review the log. Did you have internal batteries installed during this externally powered trial? If so, what type were they? -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
No batteries were installed during use with external power connected
since the manual stated that alkaline batteries could leak with external power connected and I don't have any rechargeables which are in decent condition. My wife compared the log file generated when the unit was working to the log file generated after the unit failed and she found what looks like some unexplained differences. I'm going back to square one to generate a new FLARMcfg.TXT file and will try again with fresh batteries installed since I'm at home and don't have access to external power. I'll report back what I find... On 11/28/2016 10:04 AM, Martin Gregorie wrote: On Mon, 28 Nov 2016 09:15:15 -0700, Dan Marotta wrote: Thanks, Tim, but I don't think so. I was shutting down the unit with the knob when those lines were written. When I have it externally powered for an hour it still does not receive satellites. And thanks for taking the time to review the log. Did you have internal batteries installed during this externally powered trial? If so, what type were they? -- Dan, 5J |
On Monday, November 28, 2016 at 2:50:59 PM UTC-5, Dan Marotta wrote:
No batteries were installed during use with external power connected since the manual stated that alkaline batteries could leak with external power connected and I don't have any rechargeables which are in decent condition. My wife compared the log file generated when the unit was working to the log file generated after the unit failed and she found what looks like some unexplained differences. I'm going back to square one to generate a new FLARMcfg.TXT file and will try again with fresh batteries installed since I'm at home and don't have access to external power. I'll report back what I find... On 11/28/2016 10:04 AM, Martin Gregorie wrote: On Mon, 28 Nov 2016 09:15:15 -0700, Dan Marotta wrote: Thanks, Tim, but I don't think so. I was shutting down the unit with the knob when those lines were written. When I have it externally powered for an hour it still does not receive satellites. And thanks for taking the time to review the log. Did you have internal batteries installed during this externally powered trial? If so, what type were they? -- Dan, 5J Hi Dan. You might also want to reset the thing from scratch. See https://groups.google.com/forum/#!searchin/rec.aviation.soaring/luke$20reset%7Csort:relevance/rec.aviation.soaring/hYQ8WNFITbA/Hzx35EMpDQAJ , in particular Luke's Aug 1 post. I was having problems, redid firware, flarmcfg, nothing worked until I saw this and reset (obviously you have to redo firmware etc after reset. Works a treat now. Also did this for a club glider and it fixed that too. Going to do it every winter. Dan 2D still expect it is the antenna |
I'll give it a shot, Dan. Lord knows, I've tried everything else.
Currently it's sitting out in my driveway in a zip-lock bag (since it's snowing) and has fresh alkaline batteries installed. It has the original CFG file and has been running for about 10 minutes with zero satellites found. I believe it's the antenna, but will try your suggestion in another 10 minutes... Dan On 11/28/2016 1:35 PM, Dan Daly wrote: On Monday, November 28, 2016 at 2:50:59 PM UTC-5, Dan Marotta wrote: No batteries were installed during use with external power connected since the manual stated that alkaline batteries could leak with external power connected and I don't have any rechargeables which are in decent condition. My wife compared the log file generated when the unit was working to the log file generated after the unit failed and she found what looks like some unexplained differences. I'm going back to square one to generate a new FLARMcfg.TXT file and will try again with fresh batteries installed since I'm at home and don't have access to external power. I'll report back what I find... On 11/28/2016 10:04 AM, Martin Gregorie wrote: On Mon, 28 Nov 2016 09:15:15 -0700, Dan Marotta wrote: Thanks, Tim, but I don't think so. I was shutting down the unit with the knob when those lines were written. When I have it externally powered for an hour it still does not receive satellites. And thanks for taking the time to review the log. Did you have internal batteries installed during this externally powered trial? If so, what type were they? -- Dan, 5J Hi Dan. You might also want to reset the thing from scratch. See https://groups.google.com/forum/#!searchin/rec.aviation.soaring/luke$20reset%7Csort:relevance/rec.aviation.soaring/hYQ8WNFITbA/Hzx35EMpDQAJ , in particular Luke's Aug 1 post. I was having problems, redid firware, flarmcfg, nothing worked until I saw this and reset (obviously you have to redo firmware etc after reset. Works a treat now. Also did this for a club glider and it fixed that too. Going to do it every winter. Dan 2D still expect it is the antenna -- Dan, 5J |
Well, nothing has worked. Here's the GPS applicable stuff from the
latest log file: 00001.678 INFO Initializing GPS 00001.678 INFO river\lea5.c:427 Starting to scan baud rate 00001.678 INFO river\lea5.c:780 Trying 9600 00001.690 INFO river\lea5.c:435 GPS connected at rate: 9600 00002.697 INFO river\lea5.c:459 Initializing for PowerFLARM Portable 00002.697 INFO river\lea5.c:886 Applying Antenna 00002.739 INFO river\lea5.c:886 Applying Rate 00002.751 INFO river\lea5.c:886 Applying Time pulse 00002.769 INFO river\lea5.c:886 Applying Navigation 00002.787 INFO river\lea5.c:886 Applying SBAS 00002.799 INFO river\lea5.c:886 Applying POSLLH message 00002.811 INFO river\lea5.c:886 Applying VELNED message 00002.823 INFO river\lea5.c:886 Applying STATUS message 00002.835 INFO river\lea5.c:886 Applying SVINFO message 00002.847 INFO river\lea5.c:886 Applying DOP message 00002.859 INFO river\lea5.c:886 Applying TIMEUTC message 00002.877 INFO river\lea5.c:886 Applying GGA message 00002.889 INFO river\lea5.c:886 Applying RMC message 00002.901 INFO river\lea5.c:886 Applying HW message 00002.913 INFO OK That looks to me like the GPS is working, but no satellites are being found. Looks like I'll be sending it in... Thanks to everyone who tried to help. Dan On 11/28/2016 2:24 PM, Dan Marotta wrote: I'll give it a shot, Dan. Lord knows, I've tried everything else. Currently it's sitting out in my driveway in a zip-lock bag (since it's snowing) and has fresh alkaline batteries installed. It has the original CFG file and has been running for about 10 minutes with zero satellites found. I believe it's the antenna, but will try your suggestion in another 10 minutes... Dan On 11/28/2016 1:35 PM, Dan Daly wrote: On Monday, November 28, 2016 at 2:50:59 PM UTC-5, Dan Marotta wrote: No batteries were installed during use with external power connected since the manual stated that alkaline batteries could leak with external power connected and I don't have any rechargeables which are in decent condition. My wife compared the log file generated when the unit was working to the log file generated after the unit failed and she found what looks like some unexplained differences. I'm going back to square one to generate a new FLARMcfg.TXT file and will try again with fresh batteries installed since I'm at home and don't have access to external power. I'll report back what I find... On 11/28/2016 10:04 AM, Martin Gregorie wrote: On Mon, 28 Nov 2016 09:15:15 -0700, Dan Marotta wrote: Thanks, Tim, but I don't think so. I was shutting down the unit with the knob when those lines were written. When I have it externally powered for an hour it still does not receive satellites. And thanks for taking the time to review the log. Did you have internal batteries installed during this externally powered trial? If so, what type were they? -- Dan, 5J Hi Dan. You might also want to reset the thing from scratch. See https://groups.google.com/forum/#!searchin/rec.aviation.soaring/luke$20reset%7Csort:relevance/rec.aviation.soaring/hYQ8WNFITbA/Hzx35EMpDQAJ , in particular Luke's Aug 1 post. I was having problems, redid firware, flarmcfg, nothing worked until I saw this and reset (obviously you have to redo firmware etc after reset. Works a treat now. Also did this for a club glider and it fixed that too. Going to do it every winter. Dan 2D still expect it is the antenna -- Dan, 5J |
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie | Michael Marshall[_2_] | Soaring | 3 | April 10th 16 04:13 AM |
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie | Michael Marshall[_2_] | Soaring | 0 | April 8th 16 08:57 PM |
Information for all users of Flarm, OEM FLARM supplier and Flarm PowerFlarm | [email protected] | Soaring | 28 | March 12th 16 04:31 AM |
Flarm IGC files on non-IGC certified Flarm? | Movses | Soaring | 21 | March 16th 15 09:59 PM |
Flarm in the US | Steve Freeman | Soaring | 163 | August 15th 10 12:12 AM |
