Low cost ADS-B Options
Old December 8th 16, 02:53 PM posted to rec.aviation.soaring
Default Low cost ADS-B Options
On Thursday, December 8, 2016 at 8:28:17 AM UTC-6, Mike Schumann wrote:
This is somewhat misleading. PowerFlarm doesn't actually let you "see" mode C and S transponders. It warns you if a transponder equipped aircraft is in your vicinity. It tells you the altitude and an approximate range, but you have absolutely no idea if the aircraft is in front of you, behind, you etc.
If the PowerFlarm guys had bothered to implement TIS-B, it would be be able to tell you exactly where the transponder equipped aircraft is. Similarly, you get absolutely no visibility for UAT equipped aircraft or drones.
This may be an acceptable product for Europe, but definitely a half baked solution for the US market.
I can direct the 'misleading' label right back at you, Mike. You failed to mention that the transponder traffic I'm talking about is only visible if it also is equipped with an ADS-B out system. With just a transponder heading for you, you see bumpkes on your ADS-in screen.
But as long as you can bad-mouth PFlarm, what does it matter?
Herb
Insurance Options? Jonathan St. Cloud Soaring 2 October 22nd 15 01:25 AM
What Options? gpick Piloting 12 September 3rd 10 01:57 AM
LED options Ken Gage Home Built 2 November 8th 07 12:01 AM
A Preliminary Assessment of the Potential Cost and Cost-Effectiveness of Space-Based Weapons. Mike[_7_] Naval Aviation 0 November 2nd 07 03:18 PM
Options [email protected] Soaring 32 March 14th 05 05:33 PM
