Low cost ADS-B Options
Old December 9th 16, 03:50 AM posted to rec.aviation.soaring
kirk.stant
Default Low cost ADS-B Options
On Thursday, December 8, 2016 at 8:22:00 PM UTC-6, Andrzej Kobus wrote:
Kirk, your PowerFlarm does not even come close to traffic awareness ADS-B out/in installation provides. Before I installed ADS-B Out/In, I was in situations, e.g. in a thermal, when I got a warning from PowerFlarm about another aircraft a mile away at my altitude. How do you find that aircraft? You only see part of the sky and not for too long, plus it might be coming from the sunny side. One 360 turn takes 20 seconds and if you miss the other aircraft it may take considerable amount of time before you see that part of the sky again. Flying with PowerFlarm in areas with considerable power traffic is simply stressful.
TIS-B service gives me total situation awareness. I know exactly where the other transponder equipped traffic is as well as his direction of travel and speed.
I still have PowerFlarm to see other gliders, but saying that PowerFlarm is better than ADS-B out/in is a stretch.
You might not be able to install it in a certified glider but you can sure install it now in any experimental glider.
Also why would you want ADS-B system to cost $500 when PowerFlarm costs around $1,500? You are not being fair.
Andrej, I completely understand the limitations of PF vs ADS-B - but something that is available is better that something that isn't. What is your setup? How much? Is it likely that other glider owners will equip?
There is no technological reason why a VFR only ADS-B system should cost more than $500, IT THE INTENT WAS TO PROVIDE UNIVERSAL TRAFFIC AWARENESS. But ADS-B is about replacing SSR radars - not freebie traffic info for the small guys.
Hey, it's great that you have a working ADS-B system in you glider. In my club, we have 2 transponders, 2 PFs, and nothing else - out of around 20 gliders on the field. So ADS-B is a TOTAL FAIL in our environment.
Cheers,
Kirk
66
Old December 9th 16, 09:41 PM posted to rec.aviation.soaring
Andrzej Kobus
Cheers,
Kirk
66
Kirk, you are flying an experimental glider so you can install ADS-B out now. You can install a reasonably priced system today. I started with a very expensive position sensor, but moved to Garmin 20A that works very well in a glider, the cost $845 plus antenna. This position sensor works with Trig 22 transponder. If I had a choice between a transponder and PowerFlarm I would always pick a transponder. Anyway, the cost is not huge. My ADS-B in is a dual band Stratus 2s paired to ForeFlight.
Old December 9th 16, 11:20 PM posted to rec.aviation.soaring
kirk.stant
Andrej, I have to disagree with you on priorities. Given the choice between a transponder and PF, I chose PF. Meets my current needs better. If I was still flying out west, I would probably find a way to squeeze a Trig into my panel.
What do you fly and how do you display your ADS-B in? In my LS6 I really don't have room for another display - and having a ipad mini strapped to my leg is less than ideal.
And again, cost wise, you are talking TT22 ($2600?) plus GPS ($845) plus dual band Stratus ($900) plus iPad ($500) plus Foreflight ($100). Thats damn near $5000 BEFORE installation.
Thanks, I'll stick to my PF (which cost me about $1100) and do clearing turns when the PCAS function alerts me to a transponder threat co-altitude.
Kirk
66
Old December 9th 16, 11:30 PM posted to rec.aviation.soaring
Andrzej Kobus
Kirk
66
ForeFlight runs on iPhone. I can't fit anything else in my panel either and I have a regular glider cockpit so no space for anything else.
Old December 9th 16, 11:35 PM posted to rec.aviation.soaring
Dan Marotta
Kirk,
I agree with most of what you say, however the PCAS (only) equipped
gliders in your area will not see you unless you have a transponder. I
also noted to my great satisfaction that, after installing a
transponder, I didn't see other aircraft up close any more, except for
that one guy who had a flarm only. Neither ATC nor I ever saw him
(except visually).
Dan
Kirk
66
Dan, 5J
Old December 10th 16, 03:02 AM posted to rec.aviation.soaring
kirk.stant
On Friday, December 9, 2016 at 5:35:10 PM UTC-6, Dan Marotta wrote:
Kirk,
(except visually).
Dan
Not a problem for me, since the ONLY other glider with a transponder also has PowerFLARM. We see each other fine!
Chances of the other gliders equipping with $5000 worth of ADS-B?
Not bloody likely! Well, one new glider might...
Chance of more PF installs, for just under $2K? Maybe...
Kirk
66
Old December 10th 16, 03:21 PM posted to rec.aviation.soaring
Dan Marotta
Not talking about the other glider at your club, nor am I talking about
ADS-B (despite the subject line). I'm talking about Joe Farmer bopping
along in his 172 and staring at his new-fangled GPS. Remember that guy
that got run over by an F-16 a few months back...? Now admittedly, you
wouldn't expect either of them to have FLARM (in this country), and
ATC's warnings didn't convey the urgency to the F-16 pilot.
I recall leading a visitor to Colorado on a flight southwest from Black
Forest back in the 90s when an A-7 blasted by on our left about the time
we were crossing Pike's Peak. I told him to watch out as they didn't
travel alone. The other one went by on our right. That wouldn't have
happened if either one of us had had a transponder but it /_would_/ have
happened nonetheless even had both of us been FLARM equipped.
Just sayin'
Kirk,
(except visually).
Dan
Kirk
66
Dan, 5J
Old December 10th 16, 05:36 PM posted to rec.aviation.soaring
kirk.stant
about ADS-B (despite the subject line).Â* I'm talking about Joe
Farmer bopping along in his 172 and staring at his new-fangled GPS.Â*
Remember that guy that got run over by an F-16 a few months
back...?Â* Now admittedly, you wouldn't expect either of them to have
FLARM (in this country), and ATC's warnings didn't convey the
Actually - your scenario is EXACTLY why I prefer PF (remember, it's basically FLARM plus PCAS plus ADS-B from 1090ES) to a transponder, in MY low alt environment. Joe Farmer VFR may be squawking 1200 and talking to nobody, and doesn't have ADS-B. I'll get a warning on PF (PCAS). Or, Joe Doctor is VFR in his Cirrus with fancy ADS-B (mode S). I'll see him on my PF.
Now, if I replace my PF with a nice TT-21 (for about the same price): Joe Farmer doesn't see me, and Joe Doctor might get me via TIS-B. I don't get ANY warning about EITHER of them.
I like my way better - because in the air, I don't trust ANYONE!
And sure, it would be nice to have a cheap simple ADS-B out...BUT RIGHT NOW IT DOESN'T EXIST!!!! Thank you FAA for completely blowing off the small guy.
Kirk
66
Old December 10th 16, 05:42 PM posted to rec.aviation.soaring
kirk.stant
Black Forest back in the 90s when an A-7 blasted by on our left
about the time we were crossing Pike's Peak.Â* I told him to watch
out as they didn't travel alone.Â* The other one went by on our
right.Â* That wouldn't have happened if either one of us had had a
transponder but it would have happened nonetheless
Wait, how would you having a transponder have prevented a VFR A-7 (not talking to center) from hitting you at low level? Unless A-7s had IFF interrogators, he wouldn't see you. When I used to fly low levels in F-4s the only way we knew about low level traffic was by using our radar and IFF interrogator - we were on a tactical freq and not talking to anyone.
But yes, if you fly where there is a lot of airline/bizjet traffic, a transponder is a REALLY GOOD THING TO HAVE, no argument there. I just disagree that in all environments it's more valuable than a PF.
Kirk
Insurance Options? Jonathan St. Cloud Soaring 2 October 22nd 15 01:25 AM
What Options? gpick Piloting 12 September 3rd 10 01:57 AM
LED options Ken Gage Home Built 2 November 8th 07 12:01 AM
A Preliminary Assessment of the Potential Cost and Cost-Effectiveness of Space-Based Weapons. Mike[_7_] Naval Aviation 0 November 2nd 07 03:18 PM
Options [email protected] Soaring 32 March 14th 05 05:33 PM
