Winch Launch - Fatal
Old December 10th 16, 12:26 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Default Winch Launch - Fatal
On Fri, 09 Dec 2016 20:19:18 -0800, Bill.Daniels wrote:
Three, wing "runners" sometimes mishandle the situation. If they are
accustomed to aero tow, they will be surprised how quickly the tip must
be released.
Two additional points (which you may already do):
-train the wing runner to hold the tip from behind (NEVER with
fingers round the leading edge).
This makes it much less likely that the
wing runner can deflect the glider before letting go.
-teach wing runners to BALANCE the glider on its wheel, raising or
lowering the tip a bit to counter the forces generated by a cross-wind.
Done right, you need little more than a finger and thumb on either side
of the TE to keep the wing balanced despite gusts.
If the wing runner is forcing the wing level against a cross wind, then
a wing-drop is almost guaranteed when the tip is released.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old December 10th 16, 02:53 PM posted to rec.aviation.soaring
be released.
org |
Yes, balancing the wing and never just "leveling" it is always a better method - for both winch and aero tow.
Winch Launch School Karl Striedieck[_2_] Soaring 1 January 7th 16 03:10 PM
Winch Launch Fatality Nyal Williams[_2_] Soaring 89 June 27th 09 08:45 PM
Winch Launch Fatality Ed Gaddy[_2_] Soaring 3 June 23rd 09 11:15 PM
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? Bill Daniels Soaring 20 December 27th 04 12:33 AM
Winch launch M B Soaring 0 October 30th 03 07:33 PM
