self contained streamlined strobe?
Old December 14th 16, 09:09 PM posted to rec.aviation.soaring
Tango Eight
Default self contained streamlined strobe?
The Cree XML T6 LED is used in many currently available "bright lights".
http://www.cree.com/~/media/Files/Cr...g/XLampXML.pdf
About 1000 lm ea at max power. There are many bike lights available that use 2 or more of these, and they are great for seeing where you are going (about like a single car headlight), most have a flash mode for daytime. I have one that's typical of the breed.
None of these are going to be useful for blue sky collision avoidance in aviation. Bright as they are, they simply aren't bright enough.
Medium and high intensity obstruction lighting strobes give some indication of what it takes to be clearly visible on bright days at aviation-useful distance.
For instance:
http://www.flightlight.com/airportli...2.3/5.2.3.html
best,
Evan Ludeman / T8
Old December 14th 16, 10:31 PM posted to rec.aviation.soaring
Andrzej Kobus
For instance:
best,
Evan Ludeman / T8
Before ordering my newest glider (delivered in 2016) I asked quite a few European pilots about usefulness of Schleicher's strobe lights. I got universal thumb down.
As a result my glider has ADS-B in and out instead as well as PowerFlarm. I might add 3M reflective tape to some surfaces to reflect sun. This is a much better solution than low intensity strobe light.
Some glider pilots in Europe use this type of reflective tape ("mirror tape"). I saw it available at one of the European gliding stores online. I need to find it again and order it before spring. DG website has an article about this solution; a summary of a study by a University in Europe, if I remember correctly. It was a good read.
Old December 15th 16, 12:11 AM posted to rec.aviation.soaring
Tango Eight
The Cree XML T6 LED is used in many currently available "bright lights"..
For instance:
best,
Evan Ludeman / T8
Mirror tape is an interesting idea -- you can get that at Uline for example..
Or just stick this on your tail bolt http://tinyurl.com/js3ye33
Evan
Old December 15th 16, 12:21 AM posted to rec.aviation.soaring
Andrzej Kobus
About 1000 lm ea at max power. There are many bike lights available that use 2 or more of these, and they are great for seeing where you are going (about like a single car headlight), most have a flash mode for daytime.. I have one that's typical of the breed.
For instance:
best,
Evan Ludeman / T8
Evan
Yes, for Christmas it would work well in a hangar instead of a tree.
Old December 15th 16, 12:24 AM posted to rec.aviation.soaring
Steve L[_2_]
For instance:
best,
Evan Ludeman / T8
I'm also a RC glider pilot and have used mirror tape on my models. Don't remember which RC source I got it from ,but it works great! You can see it when the plane disappears in one of those great thermals you've been searching for...
Old December 15th 16, 01:56 PM posted to rec.aviation.soaring
For instance:
best,
Evan Ludeman / T8
Model covering- Trim Monokote is available in chrome and is adhesive backed and quite thin.
UH
Old December 15th 16, 03:51 PM posted to rec.aviation.soaring
Dan Marotta
https://www.amazon.com/ABN-DOT-C2-Tr...eflective+tape
Unfortunately, I couldn't find the thickness of the tape...
For instance:
best,
Evan Ludeman / T8
Dan, 5J
Old December 15th 16, 05:02 PM posted to rec.aviation.soaring
Here's another 2.1 mm thickness
https://www.amazon.com/JVCC-MPF-01-M.../dp/B003ZCSJIK
Where would you put to have max effect with min aerodynamic penalty? I think I read a study that said control surfaces were effective.
Old December 15th 16, 06:20 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Err, it actually said 2.1 mils, not mm, for the overall thickness (carrier
+adhesive). You had to scroll down a long way to find that.
IIRC 'mil' is a USAian engineering unit (1/1000"), so 2.1 mils is
0.0021", or 0.0535 mm in SI units
https://www.amazon.com/JVCC-MPF-01-M...irror-Like/dp/
B003ZCSJIK
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old December 15th 16, 08:42 PM posted to rec.aviation.soaring
Yes, you are correct that a "mil" is 0.001" US. I would hate to put a 1.5mm tape on a sailplane.
(USA, Arizona) Luke SATR now contained in FAA NFD Tuno Soaring 2 May 18th 10 03:40 AM
Self Contained Cambridge FAI Recorder For Sale ContestID67 Soaring 3 April 6th 07 06:26 PM
Self Contained Cambridge Recorder For Sale ContestID67 Soaring 0 February 19th 07 04:55 AM
Portable GPS: receiver and laptop/palm or selft contained unit picopirate Owning 11 May 16th 04 11:37 PM
