self contained streamlined strobe?
Old December 15th 16, 09:11 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Default self contained streamlined strobe?
On Thu, 15 Dec 2016 12:42:53 -0800, Charlie M. (UH & 002 owner/pilot)
Yes, you are correct that a "mil" is 0.001" US. I would hate to put a
1.5mm tape on a sailplane.
Curiosity: I wonder how Monokote Trim sheet compare for durability and
thickness? My guess is that the Monocote would be thinner and lighter,
but quite a lot more expensive:
Monocote is $3.99 for 5" x 1yd
Amazon's JVCC MPF-01 is $13.68 for 1" x 72yds
I'm sure you wanted to know that dept:
Solarfilm's Solartrim white self-adhesive film works well as cover disks
for the access holes in a Libelle rudder. Cut disks from the sheet, stick
them on. They stayed on, undamaged, for 9 years and peeled off easily the
last time I needed to take the rudder off.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old December 15th 16, 09:12 PM posted to rec.aviation.soaring
On Thursday, December 15, 2016 at 1:22:22 PM UTC-5, Martin Gregorie wrote:
On Thu, 15 Dec 2016 09:02:17 -0800, mdfadden wrote:
Here's another 2.1 mm thickness
Err, it actually said 2.1 mils, not mm, for the overall thickness (carrier
+adhesive). You had to scroll down a long way to find that.
IIRC 'mil' is a USAian engineering unit (1/1000"), so 2.1 mils is
0.0021", or 0.0535 mm in SI units
https://www.amazon.com/JVCC-MPF-01-M...irror-Like/dp/
B003ZCSJIK
org |
Monokote UH described measures just under .002 inches including adhesive.
Available in many hobby shops or hobby mail order sources. Sheet is 5 by 36 inches.
FWIW.
UH
(USA, Arizona) Luke SATR now contained in FAA NFD Tuno Soaring 2 May 18th 10 03:40 AM
Self Contained Cambridge FAI Recorder For Sale ContestID67 Soaring 3 April 6th 07 06:26 PM
Self Contained Cambridge Recorder For Sale ContestID67 Soaring 0 February 19th 07 04:55 AM
Portable GPS: receiver and laptop/palm or selft contained unit picopirate Owning 11 May 16th 04 11:37 PM
