JS3 chatter
Old December 15th 16, 04:32 PM posted to rec.aviation.soaring
Tony[_5_]
Default JS3 chatter
It was noted on Facebook that the Vne chart on the panel lists 15m and 18m spans. Jump to your own conclusions...
Old December 15th 16, 05:15 PM posted to rec.aviation.soaring
krasw
Default JS3 chatter
My calculator says 267 kg empty with 8,7m2 wing.
Old December 16th 16, 01:43 PM posted to rec.aviation.soaring
Default JS3 chatter
Polydihedral wing already has an increased roll stability, moving the wing upward increase further roll stability.
I don't know if this is an advantage.
Old December 16th 16, 04:39 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Default JS3 chatter
More to the point, tip dihedral and polyhedral both give more stability
that a single panel dihedralled wing for a given tip rise jjust as a gull
wing gives less stability.
Whether you get more or less stability from a given dihedral schema
depends on both the amount of wing sweepback and the hight of the tip
above the root.
The JS3 and Arcus both use sweepback as well as polyhedral, so can use
less dihedral to achieve the required lateral stability.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Cockpit Chatter and Groundcrew Gripes Andie Ankey-Upcuff General Aviation 1 June 9th 05 02:57 AM
