JS3 chatter
Old December 31st 16, 08:59 PM posted to rec.aviation.soaring
Justin Couch
Default JS3 chatter
On Saturday, 31 December 2016 12:56:12 UTC+11, JS wrote:
On Tuesday, December 27, 2016 at 7:42:26 PM UTC-8, Sean wrote:
The rumor is that the JS3's arrived at the Sydney airport yesterday. They should be in Benalla today or tomorrow. It will be fun to watch this all play out.
Apparently they are both registered in Australia and one is registered VH-VJS.
Steve Leonard will be pleased to know he has a JS3. He bought VH-VJS a few years ago.
Not quite
http://www.regosearch.com/aircraft/au/VJS
Both registered to the aussie agent here. They're also just a bit short of paperwork. CofA not issued yet due to some messed up paperwork from RSA is what I've been hearing through the grapevine. I believe it's related to serial numbers messed up/swapped. GFA is madly scrambling to get it all resolved ASAP.
Old December 31st 16, 10:30 PM posted to rec.aviation.soaring
JS
Default JS3 chatter
Not quite
Aww, no need to spoil the fun, Justin!
Know Todd very well, my second VH-VJS flown was his JS1B.
Todd grabbed the registration when the Nimbus 3 was shipped to Steve in the USA. VJS is still on the glider, there never was a VH-.
A photo link to the JS3s and a Ventus 3 in Benalla, posted by AJ Wesley on [Aus-Soaring].
https://www.instagram.com/johanjbosman/
Old December 31st 16, 11:30 PM posted to rec.aviation.soaring
Chris Davison[_3_]
Default JS3 chatter
I hope the JS3 vs Ventus 3 battle takes place as it will help me to decided
which Libelle to buy next.
Chris
Old January 1st 17, 12:23 AM posted to rec.aviation.soaring
Dan Daly[_2_]
Default JS3 chatter
Chris
JS3 flying in 15m, V3 in 18m.
Old January 1st 17, 02:13 AM posted to rec.aviation.soaring
Casey[_2_]
Default JS3 chatter
Quite diverse in pilot rankings.
Old January 1st 17, 06:25 AM posted to rec.aviation.soaring
krasw
Default JS3 chatter
Uys presenting JS3:
https://www.youtube.com/watch?v=C8UmGiBrJ7o
Old January 1st 17, 08:39 PM posted to rec.aviation.soaring
Renny[_2_]
Default JS3 chatter
On Saturday, December 31, 2016 at 11:25:56 PM UTC-7, krasw wrote:
Uys presenting JS3:
More info via Sean....
Thanks, Sean!
https://www.youtube.com/watch?v=QnGP...ature=youtu.be
Old January 2nd 17, 02:07 PM posted to rec.aviation.soaring
Default JS3 chatter
More info on air venting inside the cockpit ?
I've seen the central channel and the sealed hole for instruments cooling but I don't see any vent directing air flow to the pilot.
How can the pilot avoid boiling in the Australian hot weather ? Only the slide window ?
Old January 2nd 17, 05:56 PM posted to rec.aviation.soaring
Default JS3 chatter
I like that they relocated the wheel brake on the stick, uncoupling it from the airbrake. That and the airbrake locking mechanism should simplify the landing roll.
CG
Old January 2nd 17, 07:22 PM posted to rec.aviation.soaring
Dan Marotta
Default JS3 chatter
Wish I had the airbrake locking feature on the Stemme. Currently I have
to have my wife dump the flaps after landing. If I let go of the
airbrake lever to retract the flaps (to increase weight on the gear),
the brakes are as likely to close as not. In cross winds that can be a
problem with a wing wanting to lift.
CG
Dan, 5J
Cockpit Chatter and Groundcrew Gripes Andie Ankey-Upcuff General Aviation 1 June 9th 05 02:57 AM
