The maximum spacing between runway edge lights is 200'. Airport operators
are unlikely to spend the extra money for tighter spacing. 200' hopefully is enough space to stop the glider from a speed where you still have aerodynamic control. On your first glider landing on pavement you will discover a longer ground roll, especially if there's a downhill gradient. I was thinking I could steer the glider off between the lights but ran out of energy as the slow speed passing the last light was not enough to get off the side. But there's other nasty stuff that can lurk alongside paved runways. Those with better skills can turn off onto a taxiway - watch out for props. Better to stop on the runway and assess where you can safely pull off the glider. It helps to know the local airports and which ones are not suitable. |
I've got a better idea to solve the runway light problem... Let's put a push-button switch on the left and the right side of the control column. If holding the stick hard over is not seeming sufficient to raise a wing over a runway light, then push the button on the down wing side of the stick for additional lifting force.
The push-button controls a solenoid valve that releases a jet of compressed gas through a nozzle on the underside of the wing that needs lifting. Most of us out west already carry a bottle of compressed gas that is used for another purpose. All that would be needed is plumbing in the wings as well as a nozzle outboard on each wing. The nozzle could be taped over to avoid adding drag. Such cold gas thrusters have been used for space vehicle attitude and other purposes; there is a body of design information on the subject. Besides solving the runway light problem, a wing thruster could be used to address various other matters of urgency related to low speed roll control during takeoff and landing and might also be used to facilitate safe take off without a wing runner. (you heard it first on RAS) |
On Wednesday, January 4, 2017 at 11:27:26 AM UTC-5, Steve Koerner wrote:
I've got a better idea to solve the runway light problem... Let's put a push-button switch on the left and the right side of the control column. If holding the stick hard over is not seeming sufficient to raise a wing over a runway light, then push the button on the down wing side of the stick for additional lifting force. The push-button controls a solenoid valve that releases a jet of compressed gas through a nozzle on the underside of the wing that needs lifting. Most of us out west already carry a bottle of compressed gas that is used for another purpose. All that would be needed is plumbing in the wings as well as a nozzle outboard on each wing. The nozzle could be taped over to avoid adding drag. Such cold gas thrusters have been used for space vehicle attitude and other purposes; there is a body of design information on the subject. Besides solving the runway light problem, a wing thruster could be used to address various other matters of urgency related to low speed roll control during takeoff and landing and might also be used to facilitate safe take off without a wing runner. (you heard it first on RAS) I think your idea blows! LOL Full development of the idea would automate so that it is actuated when the stick is at a specified position, say 90% of available motion, and speed below a specified level, say 40 mph or so. UH |
On Wednesday, January 4, 2017 at 8:27:26 AM UTC-8, Steve Koerner wrote:
I've got a better idea to solve the runway light problem... Let's put a push-button switch on the left and the right side of the control column. If holding the stick hard over is not seeming sufficient to raise a wing over a runway light, then push the button on the down wing side of the stick for additional lifting force. The push-button controls a solenoid valve that releases a jet of compressed gas through a nozzle on the underside of the wing that needs lifting. Most of us out west already carry a bottle of compressed gas that is used for another purpose. All that would be needed is plumbing in the wings as well as a nozzle outboard on each wing. The nozzle could be taped over to avoid adding drag. Such cold gas thrusters have been used for space vehicle attitude and other purposes; there is a body of design information on the subject. Besides solving the runway light problem, a wing thruster could be used to address various other matters of urgency related to low speed roll control during takeoff and landing and might also be used to facilitate safe take off without a wing runner. (you heard it first on RAS) Haha! Perhaps Steve got the calendar mixed up 1/4 versus 4/1. Jim |
I've got a better idea to solve the runway light problem... Let's put a push-button switch on the left and the right side of the control column. If holding the stick hard over is not seeming sufficient to raise a wing over a runway light, then push the button on the down wing side of the stick for additional lifting force. The push-button controls a solenoid valve that releases a jet of compressed gas through a nozzle on the underside of the wing that needs lifting. Most of us out west already carry a bottle of compressed gas that is used for another purpose. All that would be needed is plumbing in the wings as well as a nozzle outboard on each wing. The nozzle could be taped over to avoid adding drag. Such cold gas thrusters have been used for space vehicle attitude and other purposes; there is a body of design information on the subject. Besides solving the runway light problem, a wing thruster could be used to address various other matters of urgency related to low speed roll control during takeoff and landing and might also be used to facilitate safe take off without a wing runner. (you heard it first on RAS) NASA calls that RCS (Reaction Control System). Might be useful during flight in the atmosphere too. I'm thinking about all those times when I realized I'd rolled into the thermal in the wrong direction... ;-) 9B |
ILS Runway 1, Visual approach runway 4 KMEI - Video | [email protected] | Instrument Flight Rules | 0 | July 4th 09 06:12 PM |
Looking for older runway light fixtures | Ron Lee[_2_] | Piloting | 4 | December 10th 08 02:56 AM |
pda screen protector films | Alicase Workshop | Soaring | 1 | March 27th 07 11:36 AM |
COBRA Skin Trailer Protector - Commercial | John Seaborn | Soaring | 0 | July 20th 04 04:38 PM |
Runway light intensity | John Mireley | Simulators | 0 | September 18th 03 03:17 PM |
