On Wednesday, January 4, 2017 at 10:24:09 AM UTC-8, Doug B wrote:
I'm replacing the batteries in an old ELT this March in my Discus CS. Alternately, I was thinking of installing a fully self contained ELT with GPS. Looking for advice on what others are doing including manufacturers and models, antenna placement issues and practicality. Thanks in advance! The older ELTs do not communicate with the newer satellite systems (406MHz) and the older 121.5 frequency is unmonitored, except by ground stations. Check out this link for all the details: https://www.aopa.org/training-and-sa...nsmitters-elts Mike |
At 21:52 04 January 2017, SoaringXCellence wrote:
On Wednesday, January 4, 2017 at 10:24:09 AM UTC-8, Doug B wrote: I'm replacing the batteries in an old ELT this March in my Discus CS. Alternately, I was thinking of installing a fully self contained ELT with GPS. Looking for advice on what others are doing including manufacturers and models, antenna placement issues and practicality. Thanks in advance! The older ELTs do not communicate with the newer satellite systems (406MHz) and the older 121.5 frequency is unmonitored, except by ground stations. Check out this link for all the details: https://www.aopa.org/training-and-sa...ts/safety-and- technique/operations/emergency-locator-transmitters-elts Mike a new installation has to be 406Mhz Vern |
You might want to consider a PLB - 406 + 121.5 with GPS.
If you have to use your chute and have a PLB in your pocket, it will do you more good than an ELT signal from wherever the glider ends up. I bought one of these: http://www.mcmurdogroup.com/mcmurdo-...urdo-fastfind- ranger/ |
100 LL Replacement? | Dave[_5_] | Piloting | 2 | November 20th 07 01:54 AM |
737 Replacement | john smith | Piloting | 26 | October 22nd 06 05:21 AM |
Advice needed- 1-34 tow hook replacement | Kurt | Soaring | 3 | July 16th 04 03:23 AM |
F-15J Replacement | Prowlus | Military Aviation | 8 | April 28th 04 02:16 PM |
EP-3 replacement? | user | Naval Aviation | 23 | December 6th 03 09:46 PM |
