First TSO-C199 "TABS" device
Old January 5th 17, 10:03 PM posted to rec.aviation.soaring
Default First TSO-C199 "TABS" device
It seems to me the real benefit of adsb will come when gliders can have a sunlight-readable adsb-traffic display in the panel (I find ipad and iphone displays too hard to read in sunlight). I did find a European instrument that seems promising: its the Funke TM250. It seems to be a combined GPS, adsb-in receiver and panel-mounted traffic display for transponder, flarm and adsb targets. Price is about $1200. I'm not sure if its suitable for the USA, but it shows the sort of combined flarm/adsb plus display instruments that will be coming for gliding. This uncertain future path makes me hesitant to buy a TN72.
Old January 6th 17, 12:52 AM posted to rec.aviation.soaring
Jonathan St. Cloud
Depends on the computer. My 7" screen on the LX9070 displays traffic beautifully, really helps with situational awareness. Traffic is well displayed on many varios too i.e., Butterfly LXnav 80,8, 10,etc.
Old January 6th 17, 02:04 AM posted to rec.aviation.soaring
Dan Marotta
Same with the ClearNav II. ...But all ADS-B targets are displayed with
a B-52 silhouette!
Dan, 5J
Old January 6th 17, 04:01 PM posted to rec.aviation.soaring
Sarah[_2_]
Just to clarify ... all the people chiming in about traffic display options (LX, CNV, Oudie...) have a powerflarm ADSB/Flarm receiver, right?
I have very limited room. Adding TN72 is possible, but adding a powerflarm also would be very difficult. Maybe I could if I take out my varios.
Old January 6th 17, 04:14 PM posted to rec.aviation.soaring
Dan Marotta
Hi Sarah,
Think about stalk mounting off panel. A cheap universal automotive cell
phone cradle works great! Cut off the base and attach it to the top or
side of your panel with two Adel clamps. Here's a picture of how I
mounted a Dell Streak in my crowded LAK-17a:
https://www.dropbox.com/s/d61t34oz6x...panel.jpg?dl=0
BTW, the ClearNav does not have a built-in FLARM receiver. I mounted a
PowerFLARM portable to the top of the glare shield of my Stemme and feed
the ClearNav via serial cable. I have a friend who mounts his PF
portable AND an LX9000 (I think) on stalks in his LAK-17bfes. Maybe
he'll share a picture.
Good luck!
Dan
Dan, 5J
Old January 6th 17, 04:37 PM posted to rec.aviation.soaring
Renny[_2_]
On Friday, January 6, 2017 at 9:14:54 AM UTC-7, Dan Marotta wrote:
Hi Sarah,
Good luck!
Dan
Dan, 5J
Indeed, Dan is correct..You can see my LX9000 on a RAM mount here...
http://www.cumulus-soaring.com/lxnav...AM-Renny-1.jpg
A RAM mount also supports my PowerFlarm. You can see that photo at this link. Please note that the Oudie 2 was replaced by the LX9000 in this older photo...
http://farm9.staticflickr.com/8381/8...5941fafc_o.jpg
Old January 6th 17, 04:40 PM posted to rec.aviation.soaring
jfitch
If your tactical computer display has good depiction of Flarm and ADSB targets, I see no reason for the dedicated Flarm display. It is simply duplicating what is already in front of you. No extra panel space is necessary, though some space behind the panel is.
Old January 6th 17, 05:05 PM posted to rec.aviation.soaring
Tango Eight
Sure there is. The nav computer map display is best set to show (roughly) what you can glide to. The Flarm & adsb targets you care about -- the close ones -- won't be resolvable.
2nd display solves that problem.
Evan Ludeman / T8
Old January 6th 17, 05:41 PM posted to rec.aviation.soaring
Richard[_9_]
Evan Ludeman / T8
The Ultimate Le/Le57 running SeeYou PNA gives you text and voice warnings for the close in targets and you have seen the target coming for quite a while. I believe the large display is much better for traffic avoidance than many small flarm displays.
Air Avionics has a new display the Air Traffic Display that is one of the best small displays on the market.
http://www.craggyaero.com/atd.htm
http://www.craggyaero.com/ultimates.htm
Richard
www.craggyaero.com
Old January 7th 17, 05:06 PM posted to rec.aviation.soaring
jfitch
Evan Ludeman / T8
Again, if the display has a "good depiction of Flarm and ADSB targets", you don't need the Flarm display in my opinion. Close target are automatically made more noticeable, and very close targets are warned of with audio and graphics. This is *substantially* more obvious on my tactical display than on the Flarm display. A good tactical display will be context sensitive and take care of this for you. It really shouldn't be showing you all the places you can glide to, if you are about to hit a 737.
"Do It Yourself" airborne proximity warning device Linar Yusupov Soaring 101 September 2nd 19 02:41 AM
TABS Peter von Tresckow Soaring 1 March 11th 16 08:31 PM
5.7" Mirasol Android Device Craig Funston[_2_] Soaring 10 March 3rd 12 10:02 PM
Guitar Chords/Tabs for "Ridge Runner" [email protected] Soaring 3 November 20th 08 05:00 AM
"View Limiting Device" recommendations please [email protected] Instrument Flight Rules 27 February 4th 08 02:25 AM
