ELT replacement advice?
Old January 6th 17, 12:54 AM posted to rec.aviation.soaring
Jonathan St. Cloud
Default ELT replacement advice?
Here is another great example of why I would prefer a tracker, Spot or InReach, over an ELT, Flight MH370!!!!
On Wednesday, January 4, 2017 at 8:48:41 PM UTC-8, wrote:
I have a Kannad Integra installed in my Discus CS. The fiberglass fuselage does not require an antenna of any sort in addition to the built in antenna in the unit. It works fine, I have tested it. It's an easy install and good insurance. Installation of the remote panel controls is a good idea, and also not particularly difficult.
I also have a SPOT attached to my parachute harness. I use it mostly for live tracking but it's a good backup.
I personally do not understand why people would choose a PLB over a properly installed ELT. Modern ELT work very well and are automatically activated. Assuming that you are gong to be conscious after a crash hard enough to set off an ELT is not valid in my opinion. If you are conscious, then great, manually set off your SPOT/InReach and your ELT as well!
100 LL Replacement? Dave[_5_] Piloting 2 November 20th 07 01:54 AM
737 Replacement john smith Piloting 26 October 22nd 06 05:21 AM
Advice needed- 1-34 tow hook replacement Kurt Soaring 3 July 16th 04 03:23 AM
F-15J Replacement Prowlus Military Aviation 8 April 28th 04 02:16 PM
EP-3 replacement? user Naval Aviation 23 December 6th 03 09:46 PM
