https://en.wikipedia.org/wiki/Cold_gas_thruster
run the numbers on specific impulse. best, Evan Damn. I knew somebody would do that to me. OK then, here goes some crude top level physics... I'll start with my own guesstimation that 15 lbf near the wingtip for 3 seconds will be enough to get over the runway light. That's an impulse requirement of 45 lb * sec. I don't know anything about designing nozzles but for the sake of argument, I will send my gas out at 89% of the speed of sound = 1000 ft/sec. Impulse relates to change of momentum as J = delta m * v. Solving for the mass of gas flow required: m = J/v = 45/1000 = .045 slug. The density of plain air at seal level is .00238 slug/cu ft. But sense we're using oxygen instead of air, we get a bit more density, like .0027. So to relate the required mass to the sizing of oxygen bottles as we are normally familiar with: .045 slug / (.0027 slug/cu ft) = 16.7 cu ft. Doable! You saved your wing for the cost of an oxygen refill. |
Steve, the wing's full of water, so mix some of that in with the O2 and you'll have a more massive jet.
-Tom On Saturday, January 7, 2017 at 10:55:39 AM UTC-8, Steve Koerner wrote: https://en.wikipedia.org/wiki/Cold_gas_thruster run the numbers on specific impulse. best, Evan Damn. I knew somebody would do that to me. OK then, here goes some crude top level physics... I'll start with my own guesstimation that 15 lbf near the wingtip for 3 seconds will be enough to get over the runway light. That's an impulse requirement of 45 lb * sec. I don't know anything about designing nozzles but for the sake of argument, I will send my gas out at 89% of the speed of sound = 1000 ft/sec. Impulse relates to change of momentum as J = delta m * v. Solving for the mass of gas flow required: m = J/v = 45/1000 = .045 slug. The density of plain air at seal level is .00238 slug/cu ft. But sense we're using oxygen instead of air, we get a bit more density, like .0027. So to relate the required mass to the sizing of oxygen bottles as we are normally familiar with: .045 slug / (.0027 slug/cu ft) = 16.7 cu ft. Doable! You saved your wing for the cost of an oxygen refill. |
That's right, Tom. I was thinking of that on my way back from the airport just now. I logged into RAS to say what you said.
If we incorporated a little ballast water to the mix we can operate at lower pressure which would be good for a number of reasons and also consume much less gas. Maybe a large CO2 cartridge in the wing would do the trick. In which case the system wouldn't necessitate a pressure connection across the wing root, which would also be a good thing. |
ILS Runway 1, Visual approach runway 4 KMEI - Video | [email protected] | Instrument Flight Rules | 0 | July 4th 09 06:12 PM |
Looking for older runway light fixtures | Ron Lee[_2_] | Piloting | 4 | December 10th 08 02:56 AM |
pda screen protector films | Alicase Workshop | Soaring | 1 | March 27th 07 11:36 AM |
COBRA Skin Trailer Protector - Commercial | John Seaborn | Soaring | 0 | July 20th 04 04:38 PM |
Runway light intensity | John Mireley | Simulators | 0 | September 18th 03 03:17 PM |
