One problem I've seen is getting low away from a landable area following
flight in very cold air, e.g., wave. Whereas my Stemme has very little increase in drag during engine start, and it starts quickly and reliably, there's a requirement not to use much power until the oil temperature reaches a certain level. Even with cowl flaps closed, that can take 5 minutes or more to achieve. Fortunately, with power just above idle, the Stemme has little to no decent. Having flown turbojets in Alaska and turbofans in the lower 48, I don't recall any cautions about oil temperature, though good sense should prevail. There should be enough temperature for oil to circulate. The jets would start and run just fine at -40 deg F. On 1/7/2017 11:31 AM, Paul Ruskin wrote: On Wednesday, January 4, 2017 at 3:48:53 PM UTC, Dan Marotta wrote: Jets are cool, no doubt, and highly reliable, but they're very noisy and, at the speeds gliders fly, very inefficient. I don't know how they cost compared with a Wankel or piston engine, but I wouldn't have one. The novelty will wear off. Noise can certainly be an issue, and you wouldn't want to use them much near your home site. But for us glider pilots, efficiency is not a big issue (we don't use it enough to worry). However, they have a very distinct advantage over a piston or wankel, and that's the lack of drag when you extend them. That means that your commit height is much lower - people I know with conventional engines have to start them above 1000 ft AGL (some use considerably higher) and be downwind on a suitable landing area in case they don't start. With a jet, there's effectively no extra drag, so waiting until 500 ft AGL is perfectly feasible - or you can be further away from the field. That's the difference between completing a flight and not doing so, surprisingly often. For me, at the moment it's a toss up between jet and FES - though I suspect within a few years FES will win out as battery technology gets better. Paul -- Dan, 5J |
On Saturday, January 7, 2017 at 3:10:38 PM UTC-5, Dan Marotta wrote:
One problem I've seen is getting low away from a landable area following flight in very cold air, e.g., wave. Whereas my Stemme has very little increase in drag during engine start, and it starts quickly and reliably, there's a requirement not to use much power until the oil temperature reaches a certain level. Even with cowl flaps closed, that can take 5 minutes or more to achieve. Fortunately, with power just above idle, the Stemme has little to no decent. Having flown turbojets in Alaska and turbofans in the lower 48, I don't recall any cautions about oil temperature, though good sense should prevail. There should be enough temperature for oil to circulate. The jets would start and run just fine at -40 deg F. Dan, as far as I know, the small jets we are talking about here or at east the one I looked at seriously in an ASW-20CLJ do not have any oil circuit. The main bearings are lubricated by the jet fuel which is fortified by turbine oil. Uli |
Oh! Learn something new every day. That's a good thing!
On 1/7/2017 4:13 PM, AS wrote: On Saturday, January 7, 2017 at 3:10:38 PM UTC-5, Dan Marotta wrote: One problem I've seen is getting low away from a landable area following flight in very cold air, e.g., wave. Whereas my Stemme has very little increase in drag during engine start, and it starts quickly and reliably, there's a requirement not to use much power until the oil temperature reaches a certain level. Even with cowl flaps closed, that can take 5 minutes or more to achieve. Fortunately, with power just above idle, the Stemme has little to no decent. Having flown turbojets in Alaska and turbofans in the lower 48, I don't recall any cautions about oil temperature, though good sense should prevail. There should be enough temperature for oil to circulate. The jets would start and run just fine at -40 deg F. Dan, as far as I know, the small jets we are talking about here or at east the one I looked at seriously in an ASW-20CLJ do not have any oil circuit. The main bearings are lubricated by the jet fuel which is fortified by turbine oil. Uli -- Dan, 5J |
Motor Glider Wanted-Ohio | [email protected] | Soaring | 0 | December 2nd 13 05:46 AM |
Engine maintenance of a motor glider | kd6veb | Soaring | 0 | October 13th 13 05:57 PM |
shipping glider to NZ-advice on securing glider in trailer | November Bravo | Soaring | 6 | November 1st 06 02:05 PM |
wanted prop and motor | popeye | Home Built | 0 | March 15th 06 08:46 AM |
FIRST MOTOR GLIDER ? | Vorsanger1 | Soaring | 3 | March 31st 04 06:03 AM |
