Advice on motor glider wanted - FES - Jet - Engine
Old January 7th 17, 11:13 PM posted to rec.aviation.soaring
AS
Default Advice on motor glider wanted - FES - Jet - Engine
On Saturday, January 7, 2017 at 3:10:38 PM UTC-5, Dan Marotta wrote:
One problem I've seen is getting low away from a landable area following
flight in very cold air, e.g., wave. Whereas my Stemme has very little
increase in drag during engine start, and it starts quickly and
reliably, there's a requirement not to use much power until the oil
temperature reaches a certain level. Even with cowl flaps closed, that
can take 5 minutes or more to achieve. Fortunately, with power just
above idle, the Stemme has little to no decent.
Having flown turbojets in Alaska and turbofans in the lower 48, I don't
recall any cautions about oil temperature, though good sense should
prevail. There should be enough temperature for oil to circulate. The
jets would start and run just fine at -40 deg F.
Dan, as far as I know, the small jets we are talking about here or at east the one I looked at seriously in an ASW-20CLJ do not have any oil circuit. The main bearings are lubricated by the jet fuel which is fortified by turbine oil.
Uli
Motor Glider Wanted-Ohio [email protected] Soaring 0 December 2nd 13 05:46 AM
Engine maintenance of a motor glider kd6veb Soaring 0 October 13th 13 05:57 PM
shipping glider to NZ-advice on securing glider in trailer November Bravo Soaring 6 November 1st 06 02:05 PM
wanted prop and motor popeye Home Built 0 March 15th 06 08:46 AM
FIRST MOTOR GLIDER ? Vorsanger1 Soaring 3 March 31st 04 06:03 AM
