On Tuesday, January 10, 2017 at 8:50:49 AM UTC-8, wrote:
...Which was it, over-temperature, or under-voltage? These are two very different things. Not necessarily. I=V/R says that as the battery voltage goes down, the amperage required for specific power level is greater. So when you have a computer-controlled system trying to maintain a commanded power level by regulating current upwards, you can get a situation where low voltage is the direct cause of overheating of specific parts of the system. Full disclosu I'm not an FES expert, but I am an FES reseller. --Bob K. |
The bottom line: Did the FES overheat before the battery was exhausted? CJ, can you give us an answer?
Hi Ben,
Sometimes work has to come befor gliding (and RAS). An abhorrent thought, I know ![]() I apologize for the ambiguity but battery temperature leading to shutdown was the reason given to me by an individual involved in the incident review. However, that's not to say the situation wasn't misunderstood. Thus, the only way to be sure is to ask the pilot himself which I'm happy to do but that will take time as we're not expected to catch up for a while. If you reply with the portion of your email address that's between the 'hir' and the @ I'll email you his response. FES are very open with their documentation. Have you reviewed their manuals? Available at http://www.front-electric-sustainer.com/download.php , they specify the temperature limitations for motor and battery, among others. Note that the level to shutdown the system to prevent battery damage occurs prior to battery exhaustion. CJ |
Thanks, CJ. The FCU manual states that temperature is monitored for each battery pack, the motor, and motor controller. It's possible any one of them overheated. There's no rush, but if you could get more detail from the pilot, that would be great. Please post it here so others can benefit as well.
Motor Glider Wanted-Ohio | [email protected] | Soaring | 0 | December 2nd 13 05:46 AM |
Engine maintenance of a motor glider | kd6veb | Soaring | 0 | October 13th 13 05:57 PM |
shipping glider to NZ-advice on securing glider in trailer | November Bravo | Soaring | 6 | November 1st 06 02:05 PM |
wanted prop and motor | popeye | Home Built | 0 | March 15th 06 08:46 AM |
FIRST MOTOR GLIDER ? | Vorsanger1 | Soaring | 3 | March 31st 04 06:03 AM |
