inReach message latency
Old January 13th 17, 08:29 PM posted to rec.aviation.soaring
RR
Default inReach message latency
I just "upgraded" from spot to inReach mostly for the ability to compose and address a message in the field (perhaps literally). When using it while fishing in the everglades, I found that texts never made it, and emails could be delayed by hours. The device would confirm that a message was sent typically inside of 10min, but not get to the recipient in some cases 6hrs later. Not what I was hoping for. I don't know if it was a system issue, or if any other inReach users had the same issue. The tracking seems up to the minute, but the messaging is not. Is it working for you?
Rick
Old January 13th 17, 09:23 PM posted to rec.aviation.soaring
Renny[_2_]
Rick
Rick - I have used it for 2 years and the messages go out quickly with no delay issues. I would try it in town and in some other locations and hopefully, the messages will go out a lot quicker. If not, you may want to contact them to see what they say and recommend. I really do like the inReach so hopefully, any issues you have will be resolved quickly. Good luck! Renny
Old January 14th 17, 02:47 AM posted to rec.aviation.soaring
jfitch
Rick
I haven't used the email facility very much, but when I first got it I tried a couple and they arrived within a few minutes. Texts, too.
Old January 14th 17, 02:50 AM posted to rec.aviation.soaring
It's always a good idea to report such problems especially if you can provide specific times. Their tech support is quite responsive.
-Tom
InReach SE for sale ($200, vs $300 new) Sean Fidler Soaring 2 August 21st 15 04:57 PM
Inreach best way to mount? joesimmers[_2_] Soaring 7 April 5th 14 03:34 PM
What device to use with the InReach? Eric Greenwell[_4_] Soaring 17 March 19th 13 04:54 AM
DeLorme inReach Paul Remde Soaring 8 February 12th 13 07:26 PM
Latency 150flivver Soaring 1 August 6th 11 01:33 AM
