Op donderdag 12 januari 2017 15:13:23 UTC+1 schreef krasw:
There was a mid-air collision in 18m class today. Both damaged gliders returned to airfield. Such routine is this at WGC level that it did not make news anywhere? If you look at the score sheet, LK and HK were involved in this occurrence I have put both igc files together in this GoogleEarth KML file https://dl.dropboxusercontent.com/u/...se4comfort.kmz It looks like LK turned inside HK during thermalling HK immediately returned in the direction of Benalla and landed on Baddaginnie (Earlston) airstrip. LK initially continued the task and flew back a little bit later to Benalla. This slide was shown during a safety briefing https://dl.dropboxusercontent.com/u/...ng-wgc2017.jpg |
At 11:10 14 January 2017, RuudH wrote:
Op donderdag 12 januari 2017 15:13:23 UTC+1 schreef krasw: There was a mid-air collision in 18m class today. Both damaged gliders returned to airfield. Matthew Scutter's Gliding https://www.facebook.com/MatthewScut...fref=hovercard |
At 12:32 14 January 2017, Jock Proudfoot wrote:
At 11:10 14 January 2017, RuudH wrote: Op donderdag 12 januari 2017 15:13:23 UTC+1 schreef krasw: There was a mid-air collision in 18m class today. Both damaged gliders returned to airfield. This the work of an ethics committee. 1) It is hard to argue that someone who gives up their race to assist another pilot in mortal trouble isn't doing the right thing 2) It is also hard to argue that the organisation that decides to cancel the race because said pilot gave up his race for noble reason and was so disadvantaged isn't doing the right thing yet note that the rules say that pilots involved in a mid air must suffer a technical land out at that point. I was not present in this rule making but presume that the reasoning is that this rule discourages pilots from continuing in potentially lethally compromised gliders. It also has a deterrent effect on rash pilot behaviour as the penalty is very high, even if not to life and limb. so 3) It is therefore possible to argue that the organisers who cancel the task, remove the points downside to the pilots from unsafe flying and that is wrong. Better to find a way to reward the good shepherd for his proper and humane decision? Always controversial, not always correct Jim |
At 14:29 14 January 2017, Jim White wrote:
At 12:32 14 January 2017, Jock Proudfoot wrote: At 11:10 14 January 2017, RuudH wrote: Op donderdag 12 januari 2017 15:13:23 UTC+1 schreef krasw: There was a mid-air collision in 18m class today. Both damaged gliders returned to airfield. This the work of an ethics committee. 1) It is hard to argue that someone who gives up their race to assis another pilot in mortal trouble isn't doing the right thing 2) It is also hard to argue that the organisation that decides to cance the race because said pilot gave up his race for noble reason and was s disadvantaged isn't doing the right thing yet note that the rules say that pilots involved in a mid air must suffe a technical land out at that point. I was not present in this rule makin but presume that the reasoning is that this rule discourages pilots fro continuing in potentially lethally compromised gliders. It also has a deterrent effect on rash pilot behaviour as the penalty is very high, eve if not to life and limb. The rule was, I believe, introduced after a mid-air (in cloud) in a UK Nationals in the late 1960's. One of the pilots flew on for about another 50 km with a couple of feet of wing missing. so 3) It is therefore possible to argue that the organisers who cancel th task, remove the points downside to the pilots from unsafe flying and tha is wrong. Better to find a way to reward the good shepherd for his proper an humane decision? Always controversial, not always correct Jim |
Strange thing is that for Task 2 in the 18 meter class where supposedly two gliders bumped with minimal damage...There are no two gliders scored with identical distance.
On Saturday, January 14, 2017 at 7:45:56 PM UTC-5, Tony wrote:
Strange thing is that for Task 2 in the 18 meter class where supposedly two gliders bumped with minimal damage...There are no two gliders scored with identical distance. 12 Jan; Day 3; two ASG29E's tied at 28.5 km. You can download the IGC files and replay the incident. Fairly aggressive pre-start between the two... |
Doh! Wrong day
On Saturday, January 14, 2017 at 4:53:39 PM UTC-8, Dan Daly wrote:
On Saturday, January 14, 2017 at 7:45:56 PM UTC-5, Tony wrote: Strange thing is that for Task 2 in the 18 meter class where supposedly two gliders bumped with minimal damage...There are no two gliders scored with identical distance. 12 Jan; Day 3; two ASG29E's tied at 28.5 km. You can download the IGC files and replay the incident. Fairly aggressive pre-start between the two... Where can I find the IGC files? Thanks |
On Sunday, January 15, 2017 at 3:02:51 PM UTC-5, wrote:
On Saturday, January 14, 2017 at 4:53:39 PM UTC-8, Dan Daly wrote: On Saturday, January 14, 2017 at 7:45:56 PM UTC-5, Tony wrote: Strange thing is that for Task 2 in the 18 meter class where supposedly two gliders bumped with minimal damage...There are no two gliders scored with identical distance. 12 Jan; Day 3; two ASG29E's tied at 28.5 km. You can download the IGC files and replay the incident. Fairly aggressive pre-start between the two.... Where can I find the IGC files? Thanks There are IGC files for each competitor; go to http://wgc2017.com/results(hidden)/d...Metre#dayStart ; then scroll down to contest IDs HK and LK; they're links, click on the ids to download. You should get . 12 Jan for the touch... they have not posted any IGC files for the day with the loss of gliders. This is consistent with the mid-air at WGC Uvalde, when the incident glider IGC files were not released. I think this is a pity; reconstruction would be useful at safety meetings. |
At 20:02 15 January 2017, wrote:
On Saturday, January 14, 2017 at 4:53:39 PM UTC-8, Dan Daly wrote: On Saturday, January 14, 2017 at 7:45:56 PM UTC-5, Tony wrote: Strange thing is that for Task 2 in the 18 meter class where supposedly two gliders bumped with minimal damage...There are no two gliders scored with identical distance. 12 Jan; Day 3; two ASG29E's tied at 28.5 km. You can download the IGC files and replay the incident. Fairly aggressive pre-start between the two... Where can I find the IGC files? Thanks You can find them here, http://www.soaringspot.com/en_gb/34t...alla-gld-2017/ Click, Task & results, then the, class you want to view, then the pilots comp (CN) number, it should then open up in whatever system you are using, See You etc. |
WGC 2017 - Benalla | Renny[_2_] | Soaring | 6 | October 26th 16 12:38 PM |
