![]() Jim Thomas wrote: I noted from the TV news reports that Mr. Melville was wearing only a flight suit and an oxygen mask (no full or partial pressure suit). Does anyone know whether the cockpit was pressurized? If not (and even if so) this was pretty risky. If he wasn't in a pressure suit, the cabin had to have been pressurized or he would not have been able to survive. George Patterson None of us is as dumb as all of us. |
![]() "G.R. Patterson III" wrote in message ... Jim Thomas wrote: I noted from the TV news reports that Mr. Melville was wearing only a flight suit and an oxygen mask (no full or partial pressure suit). Does anyone know whether the cockpit was pressurized? If not (and even if so) this was pretty risky. If he wasn't in a pressure suit, the cabin had to have been pressurized or he would not have been able to survive. During the post event news conference, I asked those questions. Mr. Melvill's responses we no, he does not wear anything other than flight suit, helmet, and parachute; yes, the cabin is pressurized [to 14 psi]; it is tested at 34 psi for a number of hours; the only leaks are at control interfaces and they are tiny; one pre-launch check item is cracking open a valve from an air-bottle to trickle air into the cabin. He said the dual pane windows and tight fit of the door are excellent and he does not consider depressurization a risk to consider. |
![]() "Casey Wilson" wrote in message ... During the post event news conference, I asked those questions. Mr. Melvill's responses we no, he does not wear anything other than flight suit, helmet, and parachute; yes, the cabin is pressurized [to 14 psi]; it is tested at 34 psi for a number of hours; the only leaks are at control interfaces and they are tiny; one pre-launch check item is cracking open a valve from an air-bottle to trickle air into the cabin. He said the dual pane windows and tight fit of the door are excellent and he does not consider depressurization a risk to consider. Yeah, and a DC-10 can't lose all it's hydraulics. |
spaceship one | Pianome | Home Built | 169 | June 30th 04 05:47 AM |
Hubble plug to be pulled | John Carrier | Military Aviation | 33 | March 19th 04 04:19 AM |
THOMAS MOORER, EX-JOINT CHIEFS CHAIR DIES | Ewe n0 who | Military Aviation | 2 | February 12th 04 12:52 AM |
OT (sorta): Bush Will Announce New Space Missions | Dav1936531 | Military Aviation | 0 | January 9th 04 10:34 AM |
Strategic Command Missions Rely on Space | Otis Willie | Military Aviation | 0 | September 30th 03 09:59 PM |
