Average OLC flown distance by glider
Old January 18th 17, 10:45 AM posted to rec.aviation.soaring
Jacopo Romei
Default Average OLC flown distance by glider
Hello DG300PI,
thanks for letting your concern emerge. This is key to validate my choices.
Interesting to see these figures but wat do they actually mean?
- the high-end gliders are more often flown by high-end pilots
I agree: as obvious as it may sound, no glider "gets there" alone and every ship is usually matched by a pilot with related skills.
This is *exactly* the information I want to show. GliderReview was born to help inexperienced pilots like me navigate the ocean of available gliders. According to this vision, knowing that a glider is usually flown far tells me at least two things:
- it is a glider capable of supporting a pilot able to get that far
- it is a glider that pilots *that* good *nowadays* choose to get that far
I expect both these measures to imply a higher price for the glider.
- what has to be taken into account is the number of gliders per type that are present in certain locations with good, average or less good gliding conditions.
We can re-apply by analogy the same logic he
if a glider has a high average because it is usually flown in Namibia, that means again that it is a glider worth bringing there, thus usually a higher-end ship.
For example, no one ships his/hers Ka8 to Namibia or Australia to fly distance records and you will typically find the more experienced pilots over there.
This is *the* point, not a counterargument: coherently you'll find Ka8 much cheaper than JS1 ;-)
To conclude: I don't need to understand the intimate cause-effect relationship between an indicator and a phenomenon, as long as it lets me understand *a part* of the effects.
As a recap: if a glider is usually flown shorter, it will tend to cost less.
Thank you again!
Would you like to write the review for the DG-300? :-)
Ciao
Jacopo
Old January 18th 17, 10:54 AM posted to rec.aviation.soaring
Bruce Hoult
On Wednesday, January 18, 2017 at 1:45:11 PM UTC+3, Jacopo Romei wrote:
Hello DG300PI,
Thank you again!
I dunno. Booming thermals, high cloudbase -- you could probably do 1000km in a PW5 in Namibia if you just took one there.
Old January 18th 17, 11:00 AM posted to rec.aviation.soaring
Jacopo Romei
You could, right.
But reality is narrower: usually no one does.
Last but not least: when coping with normal averages, still possible exceptions are averaged out, by definition.
What could happen in theory is one thing, I see your point. What *usually* happens is what I care most for GliderReview.
Old January 19th 17, 04:59 AM posted to rec.aviation.soaring
Mike the Strike
Arizona is not Namibia, but we do have some spectacular thermal soaring, often with high cloud base. One of our members, Mike Parker, flew a World Record distance in a PW5 of 626 km here about ten years ago. Not sure about 1000 km, but 850 km looks doable.
Mike
Distance wood has flown Robert Gaines Soaring 11 July 31st 14 03:18 PM
Shortest distance flown by wood?? :D [email protected] Soaring 25 May 7th 07 06:16 PM
Distance wood has flown Steve Leonard Soaring 4 April 17th 07 02:30 AM
Distance wood has flown Steve Leonard Soaring 0 April 15th 07 02:34 PM
Total cross country distance flown Bill Daniels Soaring 9 November 4th 05 11:53 AM
