Aerobatic Two Seat Gliders?
Old January 24th 17, 03:35 PM posted to rec.aviation.soaring
Eric Munk
Default Aerobatic Two Seat Gliders?
The Twin Astir is according to the FM approved for simple aerobatics only
(loops, stall turn, lazy 8, chandelle, spin).
t 20:44 23 January 2017, wrote:
"Service Bulletin SA-003 prohibits aerobatics in Schweizer gliders
overridi=
ng the POH (answering the question about an SGS-2-32)."
Actually, legally it doesn't. A service bulletin or note or advisory
about
an aircraft cannot override the approved flight manual or type
certificate
of an aircraft operated under the aegis of the FAA (Unless it was an
alert
service bulletin issued in order to get information out quickly while an
AD=
is being processed - it wasn't an alert service bulletin). For it to be
le=
gally binding they would have to get an airworthiness directive issued.
The=
y did not do this. Not to long ago one of the engine manufacturers tried
th=
is sort of tactic and got in a bit of trouble. Whether its a good idea to
d=
o aerobatics in a 2-32 being flown in the utility category is a different
m=
atter and one I don't have an opinion on seeing as how I've never flown
one=
or worked on one.
You can get a Grob Twin Astir or Twin II for a reasonable amount of money
b=
ut unless you can find a Twin II Acro which has had the rear fuselage
stren=
gthening modification you won't have a glider approved for inverted
flight
or slow rolls.
Old January 24th 17, 04:07 PM posted to rec.aviation.soaring
Tango Whisky
Le mardi 24 janvier 2017 16:45:06 UTC+1, Eric Munk a écritÂ*:
The Twin 1 is full aerobatics (but I don't know about flick rolls).
Old January 26th 17, 05:32 AM posted to rec.aviation.soaring
No, it's not. Simple aerobatics only: loop, stall turn, spin, chandelle.
Old January 26th 17, 10:23 AM posted to rec.aviation.soaring
Tango Whisky
Le jeudi 26 janvier 2017 06:32:07 UTC+1, a écritÂ*:
Sorry, my fault. The Twin II Acro is fully aerobatics, except snap rolls. The Twin I is simple aerobatics.
Old January 26th 17, 11:00 PM posted to rec.aviation.soaring
Eric Munk
=C3=A9crit=
=C2=A0:
=C3=A9crit=C2=A0:
aerobatics
only
=20
=20
chandelle.
T=
Twin II Acro is only fully aerobatic if TM 315-66 has been carried out.
Parachute use in single seat gliders [email protected] Soaring 13 May 20th 16 04:14 PM
AD note for G-103, Grob two seat gliders Robert M Soaring 13 November 3rd 15 04:45 AM
two seat motor gliders, feedback. John Firth Soaring 6 March 2nd 05 03:45 AM
Two seat self launch aerobatic glider Waduino Soaring 2 January 6th 05 06:51 PM
Commercial - New Data Splitter for 2-Seat Gliders John Giddy Soaring 3 September 17th 03 06:01 AM
