During my tour of VNam, I saw any number of these!
https://en.wikipedia.org/wiki/Douglas_A-26_Invader Specifications (A-26B-15-DL Invader) A-26B (44-34602), registered N167B at Duxford, UK July 2008 Reloading machine guns on an A-26B with a six-gun nose Data from McDonnell Douglas Aircraft Since 1920[5] General characteristics Crew: 3 Length: 50 ft 0 in (15.24 m) Wingspan: 70 ft 0 in (21.34 m) Height: 18 ft 3 in (5.64 m) Wing area: 540 ft² (50 m²) Empty weight: 22,850 lb (10,365 kg) Loaded weight: 27,600 lb (12,519 kg) Max. takeoff weight: 35,000 lb (15,900 kg) Powerplant: 2 × Pratt & Whitney R-2800-27 "Double Wasp" radial engine, 2,000 hp (1,500 kW) each Performance Maximum speed: 355 mph (308 kn, 570 km/h) Range: 1,400 mi (1,200 nmi, 2,300 km) Service ceiling: 22,000 ft (6,700 m) Rate of climb: 1,250 ft/min (6.4 m/s) Wing loading: 51 lb/ft² (250 kg/m²) Power/mass: 0.145 hp/lb (108 W/kg) Armament Guns: 6 or 8 0.50 in (12.7 mm) M2 Browning machine guns in solid, "all purpose" nose: or 2 0.50 in (12.7 mm) M2 machine guns in glass "bombardier" nose Up to 8 0.50 in (12.7 mm) M2 machine guns paired in four optional under wing pods: or 3 0.50 in (12.7 mm) M2 machine guns in each outer wing panel 2 0.50 in (12.7 mm) M2 machine guns in remote-controlled dorsal turret 2 0.50 in (12.7 mm) M2 machine guns in remote-controlled ventral turret Rockets: Up to 10 5-inch (12.7 cm) HVAR rockets on "zero length" launch pylons, five under each outer wing panel Bombs: Up to 6,000 lb (2,700 kg) capacity - 4,000 lb (1,800 kg) in the bomb bay plus 2,000 lb (910 kg) carried externally on underwing hardpoints go Warriors! |
"Miloch" wrote in message ...
During my tour of VNam, I saw any number of these! Yup. We flew 'em 'til the wings fell off |
On Mon, 13 Jun 2016 22:01:32 +0100, Byker wrote
(in article ): Yup. We flew 'em 'til the wings fell off Biggin Hill, 21 September 1981. All 7 people on board killed. There's an interesting (and quite long) discussion of this accident (and the aircraft's pilot) at: http://napoleon130.tripod.com/id250.html This crash apparently resulted in a 'no passengers' rule being brought in for flying displays in the UK. The attached picture shows the A-26 on its way down. |
"Netko" wrote in message
... The attached picture shows the A-26 on its way down. Old warbirds weren't built to take heavy G-forces forever, as water-tanker operators have found out recently. http://www.liveleak.com/view?i=a3f_1394451080 Wing fails at 2:01 |
Mustangs Of Old - A 36 Invader.jpg (1/1) | Mitchell Holman | Aviation Photos | 0 | December 29th 06 05:33 AM |
RAF Invader B Mk1 (A-26) | frank may | Military Aviation | 12 | August 18th 04 02:50 AM |
A-26 Invader | Mark Gaskell | Military Aviation | 4 | June 24th 04 01:52 PM |
A-26 Invader | Mark Gaskell | Restoration | 2 | June 24th 04 01:52 PM |
