Test results LiFePO4 glider batteries after 6 years
Old January 29th 17, 09:42 PM posted to rec.aviation.soaring
Tango Eight
Default Test results LiFePO4 glider batteries after 6 years
I guess this is the weekend to test batteries.
I have four seasons on my Bioenno 12AH LFP battery. It's down to 11.48 AH now, down from 12.05 last year and 12.1 when new. All measurements from an el cheapo imax B6 battery charger. For testing purposes I discharge to 11 volts. There is very little capacity remaining at that point.
With few exceptions, this battery has been stored with full charge.
best,
Evan Ludeman / T8
Old January 29th 17, 09:50 PM posted to rec.aviation.soaring
John Carlyle
T8, you're the reason I went with the Bioenno batteries. After reading the docs you posted, it seemed like the best value for money. Glad to hear that they're holding up for you. Do you know roughly how many charge cycles you have on them?
-John, Q3
Old January 29th 17, 10:05 PM posted to rec.aviation.soaring
Tango Eight
-John, Q3
Call it 150 cycles to 1/2 charge on average.
T8
Old January 29th 17, 10:52 PM posted to rec.aviation.soaring
John Carlyle
Thanks, T8. I've got about the same usage to the same level. Guess I should check my remaining capacity, too.
-John, Q3
T8
Old February 7th 17, 01:30 AM posted to rec.aviation.soaring
I have four seasons on my Bioenno 12AH LFP battery. It's down to 11.48 AH now, down from 12.05 last year and 12.1 when new. ...
T8-
Your battery seems to be holding up well. I also have a K2 battery that after 2 seasons is showing similar loss of capacity as SF and Steve Koerner describe. Its down to about 60% capacity. I am currently trying the extended charge cycle Steve described. I charge it with a 14.6V 2A switching charger made by Fuyuan - model FY1502000; bought it with the battery. Not sure that the charger would make that much difference if the voltage is adequate, but what type of charger do you routinely use to charge your Bioenno LFP battery? Perhaps the Bioenno has better cell balancing algorithm/hardware? I stored it at approximately half charge in the off season and always took it home for recharging when not flying.
Since I am in the market for a second LFP, trying to decide which brand to go with.
Thanks
Old February 7th 17, 01:55 AM posted to rec.aviation.soaring
Richard[_9_]
T8-
Thanks
I think you guys have a large dose of Hopeful.
All the batteries mentioned in this post including the BMS are made and sealed as a unit in China.
Just because you pay extra does not mean you get a better battery.
I got a batch of one of the above mentioned batteries that advertised 9 aH but only got 5 or 6 aH. They company did replace the low specification batteries when I complained.
The other issue you have is if power is reversed when charging or using the battery you will likely damage the battery or the BMS even if fused.
Richard
www.craggyaero.com
Old February 7th 17, 09:27 AM posted to rec.aviation.soaring
Jim White[_3_]
sea=
led as a unit in China. =20
Is that true od A123? The manufacturer claims that the design (and original
build) is American, the chemistry is failsafe, and that the BMS balances
each cell individually without needing to be on a charger.
The downside is that they also claim 5AH. I have been using these with
great results for 2 seasons now.
I also like the internal fuse feature.
Old February 7th 17, 08:35 PM posted to rec.aviation.soaring
I got the West Mountain Radio tester and ran my three K2 Energy 9.6 AH (two years old) One tested at 8.7 AH, the next at 8.5 AH, and the final one 7.3 AH. They are all charged using a dedicated LIFEPO4 charger. Not sure why the one should have so much less capacity. I will be giving K2 a call.
David
ASG29E BV
Old February 7th 17, 09:43 PM posted to rec.aviation.soaring
Tom Kelley #711
On Tuesday, February 7, 2017 at 1:35:42 PM UTC-7, wrote:
I got the West Mountain Radio tester and ran my three K2 Energy 9.6 AH (two years old) One tested at 8.7 AH, the next at 8.5 AH, and the final one 7..3 AH. They are all charged using a dedicated LIFEPO4 charger. Not sure why the one should have so much less capacity. I will be giving K2 a call.
David
ASG29E BV
What voltage are they showing when they come off these chargers?
Best. Tom.
Old February 7th 17, 11:59 PM posted to rec.aviation.soaring
I set the tester to cut off at 11 volts. At that point the voltage is dropping rapidly as is normal with the LIFEPO4's.
David
ASG29E BV
LifePO4 batteries for motorgliders - are we there yet? Chris Soaring 13 January 9th 16 03:43 PM
Bioenno Power LiFePO4 12V Glider Batteries Paul Remde Soaring 13 April 21st 15 04:35 PM
K2 vs. StarkPower LiFePo4 batteries Fox Two[_2_] Soaring 36 April 16th 15 05:14 PM
LiFePO4 Batteries vontresc Soaring 56 June 27th 14 07:25 PM
LiFePO4 batteries JS Soaring 26 October 15th 12 02:51 PM
