Test results LiFePO4 glider batteries after 6 years
Old January 30th 17, 02:32 PM posted to rec.aviation.soaring
Default Test results LiFePO4 glider batteries after 6 years
I think it would also be good to record ambient temperature of your test area when doing a capacity test. If it's always say 70*F +/- 3*F, then temperature is not a factor in AH.
A AH test in a 50*F area will yield a different AH value than a 80*F area. I know I can find a "temp compensation chart" for LA batteries pretty quick, not sure about LiFe batteries.
Same goes for charging, temp of the batteries have an effect on charge voltage and charge rate. In LA batteries, it's the inverse of temperature, I will assume LiFe is the same.
LifePO4 batteries for motorgliders - are we there yet? Chris Soaring 13 January 9th 16 03:43 PM
Bioenno Power LiFePO4 12V Glider Batteries Paul Remde Soaring 13 April 21st 15 04:35 PM
K2 vs. StarkPower LiFePo4 batteries Fox Two[_2_] Soaring 36 April 16th 15 05:14 PM
LiFePO4 Batteries vontresc Soaring 56 June 27th 14 07:25 PM
LiFePO4 batteries JS Soaring 26 October 15th 12 02:51 PM
