Test results LiFePO4 glider batteries after 6 years
Old January 31st 17, 10:36 PM posted to rec.aviation.soaring
Matt Herron Jr.
Default Test results LiFePO4 glider batteries after 6 years
There is another advantage to using the dual diode method for multiple batteries. You can mix chemistries without concern. for example I have 2 LiFePo4 packs and 2 gel cells. I can use a gel and a LiFePo4 on the same flight. Power is simply drawn from the pack with the highest voltage, until both are depleted. You can't do this if you wire the batteries together directly. You can, if you use two switches of course, but you run the risk of voltage spikes or drop outs on switch over. You also don't have to monitor voltage for when to switch from one to the other as no switching is needed.
I also second automotive blade fuses at the battery terminals. Additionally I use screw-type battery connectors (3 conductor type) as they are robust and lock in place with the threaded ring.
Matt H
LifePO4 batteries for motorgliders - are we there yet? Chris Soaring 13 January 9th 16 03:43 PM
Bioenno Power LiFePO4 12V Glider Batteries Paul Remde Soaring 13 April 21st 15 04:35 PM
K2 vs. StarkPower LiFePo4 batteries Fox Two[_2_] Soaring 36 April 16th 15 05:14 PM
LiFePO4 Batteries vontresc Soaring 56 June 27th 14 07:25 PM
LiFePO4 batteries JS Soaring 26 October 15th 12 02:51 PM
