Wing Loading / climb rate
Old February 2nd 17, 06:47 AM posted to rec.aviation.soaring
jfitch
Default Wing Loading / climb rate
On Wednesday, February 1, 2017 at 8:42:35 PM UTC-8, Bruce Hoult wrote:
On Thursday, February 2, 2017 at 5:12:27 AM UTC+3, Eric Greenwell wrote:
Chris Davison wrote on 2/1/2017 10:14 AM:
A questions that I should know the answer to but don't...in a
thermal, all things being equal, will a 15m glider and an 18m glider
with the same wing loading climb at the same rate?
I'm told thermal climb rate is related to "span loading" (weight/span),
while high speed performance is related to wing loading (weight/wing
area). In your example, the 18m glider will climb better.
Told by who, I wonder? :-)
Span is important to minimize induced drag, but that's a waste of time unless you have enough wing area to give an acceptable coefficient of lift or AoA at desired circling speeds and radii.
There is probably an intermediate cruising speed range where the dominant factor is wing loading / wing area / wetted area / span*chord. At a guess that might be from midway between min sink and best L/D speeds out to maybe 1.4 or 1.5 times best L/D speed.
At higher speed I'd have thought the dominant factor would be minimizing span*wing thickness, i.e. frontal area. That's what kills the 1960s 40:1 ships at high speed -- or newer short span ones such as the PW5.
In classical aerodynamics, induced drag dominates at low speeds (high lift coefficients), and that is inversely proportional to aspect ratio. However if you work through the math, area and wing loading cancel the wing chord out, hence the term span loading (which normalizes for wing loading in effect).
At high speeds profile (and parasitic) drag is dominant. Wing thickness is loosely related to profile drag, but the main thing that kills the 60's ships is the bad behavior of the laminar flow, not the thickness per se. Fuselages have gotten a little cleaner, but it is the wing sections and understanding of laminar flow that is the biggest difference I think.
Old February 2nd 17, 07:39 AM posted to rec.aviation.soaring
Bruce Hoult
Could you run through that math for me?
As I see it, wing area equals span times (average) chord. Wing loading equals weight divided by wing area, so weight/(span*chord). Not sure I see how chord cancels out of that?
Certainly I agree that for a given wing area and wing loading, more span and less chord is better. 10 sqm has been the traditional benchmark wing area for a single seater, getting smaller with time. Ka6 and Cirrus are both about 12; Std Libelle, Discus, LS8, even PW5 about 10; Diana 2 is 8. If you could build a single-seater with 50m span and 200mm chord (and no more than 20 - 30 mm thickness) without it breaking then it would probably go pretty well in a straight line.
So span loading is a useful figure if you hold the wing loading constant.
But you can't just pick a span loading you like and then reduce or increase the chord to whatever you feel like. A single seater with 15m span with 500mm - 800mm average chord works. 200mm or 2000m would be ridiculous, assuming you want to fly in the speed ranges we fly gliders in. 200mm chord might be interesting if you didn't mind a 70 knot stall speed and 90 knots thermalling :-)
Old February 2nd 17, 08:33 AM posted to rec.aviation.soaring
I worked some math out on page 15 of this PDF. The section is called drag.
http://spekje.snt.utwente.nl/~roeles/maccready.pdf
Old February 2nd 17, 08:45 AM posted to rec.aviation.soaring
Bruce Hoult
The requested URL /~roeles/maccready.pdf was not found on this server.
Old February 2nd 17, 09:06 AM posted to rec.aviation.soaring
Whoops
Make that
http://spekje.snt.utwente.nl/~roel/maccready.pdf
Old February 2nd 17, 09:08 AM posted to rec.aviation.soaring
Whoops
Make that
Old February 2nd 17, 09:49 AM posted to rec.aviation.soaring
Bruce Hoult
I worked some math out on page 15 of this PDF. The section is called drag..
Ok, good. What exactly do you wish to point to there?
I see that in general there are a lot of approximations, assuming small angles etc. I didn't check if that always looks like a good simplification, but this did jump out at me:
"Using this formula we can calculate both CD0 and e if we know some data
about the best L/D point of the polar. Since at this point the induced drag
should equal the parasitic drag"
That is certainly wrong.
It's true that in practice where you are looking for a minimum of two different ways to lose, the minimum is likely to be at a point where they are roughly equal, but it's only very rough. The two things could easily be different by, say, a factor or two, or more.
What *is* true at the minimum is that the *derivatives* of the two things are equal in magnitude, and opposite in sign.
Take, for example, the (positive) minimum of 1/x + x^2 (which is something similar in form to induced plus form drag). They are equal when x = 1, and both halves are 1 (so the total is 2).
But the minimum is at x = 1/cubeRoot(2) ~= 0.793701. At this point 1/x is 1.26 and x^2 is 0.63. So in fact the "induced drag" is twice the "form drag" at the minimum.
As you'll know, the derivative of 1/x is -1/x^2, while the derivative of x^2 is 2x. So at x = 0.793701 the derivatives are -1.5874 and +1.5874 (cube root of 4) -- equal and opposite.
At the minimum of a sum, the *slopes* are equal (and opposite), not the *values*.
Old February 2nd 17, 10:12 AM posted to rec.aviation.soaring
Thanks for the comments. I'll reply by email later on, as not to spoil the thread.
People were referring to the equations regarding drag,in turns .
Therefore I pointed to the drag formula in the pdf.
Why Isn't Vx The Best Rate Of Climb? RandyL Piloting 18 September 28th 06 07:50 PM
figuring Rate of Climb Michael Horowitz Home Built 1 June 19th 05 03:16 AM
Newbie question on Rate of Climb Wright1902Glider Home Built 0 August 17th 04 03:48 PM
Rate of climb Dillon Pyron Home Built 3 May 8th 04 01:08 PM
Climb Rate for DG-600M Steve B Soaring 5 August 25th 03 08:17 AM
