Low Cost Dual Band ADS-B Receiver
Old February 4th 17, 02:23 AM posted to rec.aviation.soaring
Tom BravoMike
Default Low Cost Dual Band ADS-B Receiver
If, theoretically, all those '10 or less in a gaggle' are equipped with ADS-B Out and In, and 'a good tactical display', will the information/warnings provided be still inferior to that of FLARM? Just curious...
Tom BravoMike
Old February 4th 17, 02:35 AM posted to rec.aviation.soaring
Absolutely. ADS-B only provides a 3D position, so all the nearby gliders in the thermal will be considered a threat. FLARM provides a position and a predicted future position, so only potential collisions produce an alert.
5Z
Old February 4th 17, 03:04 AM posted to rec.aviation.soaring
Tom BravoMike
If ADS-B/In provides the 3D information, which is next used in a variety of softwa ForeFlight, iFlyGPS, XCSoar (pending, hopefully), what can stop the programmers to calculate potential collisions and give similar alerts to those of FLARM? Isn't it all about universality of the system and availability of reliable data between ALL users of the airspace: powerplanes, gliders, trikes AND drones?
Tom BravoMike
Old February 4th 17, 11:07 AM posted to rec.aviation.soaring
Andrzej Kobus
Tom BravoMike
BraveMike, compute power is the only thing that might stop this , but I doubt it will since hardware performance is accelerating at high rate (maybe with the exception of WGC gaggles). PowerFlarm has very low compute power, probably to keep power consumption low and to keep hardware cost low (although that has not been passed onto a consumer). When PowerFlarm was invented hardware computing power was low so they made the best algorithm possible and it worked for many years.
The drones will probably drive this market. They will have to have technology to avoid collisions. I would also think that lower cost and energy efficient transponders are going to show up as well.
Just my opinion, I can't predict the future.
Old February 4th 17, 03:50 PM posted to rec.aviation.soaring
Frank Whiteley
Tom BravoMike
http://www.uavionix.com/products/ping2020/ UAV ADS-B transceiver. As it's available now, before the manned version, perhaps it validates what is driving this market. No particularly cheap.
Frank Whiteley
Old February 4th 17, 07:21 PM posted to rec.aviation.soaring
Tom BravoMike
Yes, ADS-B will be inferior for a variety of reasons:
1) ADS-B doesn't do path prediction on the transmit side (straight, turning, climbing, descending, etc.). FLARM does.
2) ADS-B doesn't provide collision warning. For glider scenarios, this is almost impossible to do without some form of #1. At best a computer using ADS-B could give traffic alerts based on proximity, which for glider scenarios would generate a lot of false alarms if you tried to use it for anything beyond simple proximity alerts.
3) Most of the collision warning processing is done by FLARM, not the display. Imagine the challenges and confusion potential if each display used its own collision warning algorithm. Since there is no provision in the ADS-B specification for anything other than absolute position display based on GPS location. FLARM sends RELATIVE position and collision warnings to all displays so there is no ambiguity. In addition, there is no plan to provide this functionality that I am aware of across display manufacturers.
4) FLARM de-duplicates FLARM and ADS-B 1090ES and Mode-S transponder traffic based on ICAO ID. If you go a la carte, you would need to do this within each display. There are no plans that I am aware of to do this.
I'm sure there are other challenges. I do think it would be useful to MUX UAT (and possibly TIS-B) traffic into a FLARM NMEA stream, but it has challenges. I'd take whatever FLARM provides natively first, add a transponder second and then see if I need anything else, like ADS-B Out, TIS-B, UAT, or FIS-B (for weather radar, TFRs, etc - but that's a whole new set of display challenges).
9B
Old February 4th 17, 07:52 PM posted to rec.aviation.soaring
The ADS-B specification requires transmitting 3D velocity vector along with absolute position.
Marc
Old February 4th 17, 09:34 PM posted to rec.aviation.soaring
John Carlyle
Andy, regarding doing a MUX of UAT data into a FLARM stream. While it would be nice to see UAT targets on my FlarmView, the question is: would an effort to accomplish this be worthwhile?
I spent a little time seeing if I could find the relative number of UAT boxes vs 1090 boxes. I found a 2014 estimate that said 33% of transponders were UAT, but I don't believe that. The RPi hobbyists using Dump1090 and Dump978 say they are getting maybe seeing 5 planes a day on 978.
-John, Q3
9B
Old February 4th 17, 10:14 PM posted to rec.aviation.soaring
Mike Schumann[_2_]
Tom BravoMike
9B
There is inherently no technical reason that an ADS-B based system can't provide just as sophisticated collision warnings as FLARM. Both systems rely on GPS position data transmitted once per second. I'm not an expert on this, but FLARM may transmit more predictive data that makes threat analysis in the receiver easier, but there is no inherent technical reason that an app connected to an ADS-B receiver can't track multiple threat targets and compute exactly the same trajectories that FLARM provides.
The BIG advantage of these ADS-B receivers is that they provide accurate position data for non ADS-B OUT, but transponder aircraft, received from ADS-B ground stations via TIS-B. Due to the half baked ADS-B IN implementation of PowerFlarm, which does not support TIS-B, transponder equipped aircraft can only be identified with an approximate range and altitude, so you have no idea if the target is in front of you, to the side, or behind you, nor which direction it is headed, etc...
Then of course PowerFlarm doesnt' provide weather radar, METARS, TAFs, and TFRs which are also standard with most ADS-B IN receivers.
Old February 5th 17, 02:35 AM posted to rec.aviation.soaring
jfitch
Tom BravoMike
9B
I guess you didn't read Andy's post above, which explained several technical reasons why ADS-B is unlikely to provide such warnings? ADS-B operates off of the same GPS data, but does not operate in anything like the same way. Perhaps the standard could be changed to operate in a similar way, but that is not likely to happen in our lifetimes.
A Preliminary Assessment of the Potential Cost and Cost-Effectiveness of Space-Based Weapons. Mike[_7_] Naval Aviation 0 November 2nd 07 03:18 PM
Who has fitted a TRI-band ELT to a TB20? Chris G. General Aviation 0 June 28th 05 03:21 PM
Radio band scanner Fritz General Aviation 3 October 14th 04 07:36 PM
Band of brothers ArtKramr Military Aviation 10 March 9th 04 10:44 PM
SSR Receiver Steven Archibald General Aviation 0 November 6th 03 09:41 AM
