On Thursday, February 9, 2017 at 9:21:16 AM UTC-8, wrote:
Speaking of technology I just watched a seminar by Infineon - they make sensors. In the pressure transducer they make for exercise trackers can have high definition to tell that someone is climbing or descending stairs or help determine what kind of activity they are doing. They can sense a air pressure difference of 50mm/2 inches!!! These were energy efficient for use with battery powered systems of course. Chris I remember being told that the sensors used in the LXNAV equipment measure 1cm or altitude 100 time per second. Richard www.craggyaero.com |
On Thursday, February 9, 2017 at 9:44:49 AM UTC-8, Richard wrote:
On Thursday, February 9, 2017 at 9:21:16 AM UTC-8, wrote: Speaking of technology I just watched a seminar by Infineon - they make sensors. In the pressure transducer they make for exercise trackers can have high definition to tell that someone is climbing or descending stairs or help determine what kind of activity they are doing. They can sense a air pressure difference of 50mm/2 inches!!! These were energy efficient for use with battery powered systems of course. Chris I remember being told that the sensors used in the LXNAV equipment measure 1cm or altitude 100 time per second. Richard www.craggyaero.com When I was testing an Air-Glide S on the bench, discovered it takes very little disturbance of the ISU to get readings. Jim |
OT 4 airport round robin - time lapsed / real time with ATC COMS -video | A Lieberma[_2_] | Owning | 0 | August 30th 09 12:26 AM |
OT 4 airport round robin - time lapsed / real time with ATC COMS -video | [email protected] | Instrument Flight Rules | 0 | August 30th 09 12:26 AM |
Rotor lift coefficient | devi | Rotorcraft | 1 | September 25th 05 01:17 AM |
about lift and drag coefficient for cessna C-160 | Grandss | Piloting | 9 | August 15th 05 06:15 PM |
Real-time real world air traffic in flight sims | Marty Ross | Simulators | 6 | September 1st 03 04:13 AM |
